Question about KitchenAid KEMC378 Electric Double Oven
Kitchen Aid ovens - error codes
What are the error codes for Kitchen Aid ovens (in this case, a KEMS378--are they all the same?) and what do they mean? I'm getting an F-3. The entire oven / microwave unit works (clock, light, display, microwave) except that the oven doesn't heat in any mode, and power at the breaker is correct. This occurred immediately after a successful self-cleaning. Thx so much.
  • 4 more comments
  • Anonymous Dec 22, 2008
    NO ERROR CODE, BAKE AND BROIL DO NOT WORK, AFTER A SUCCESSFUL AUTO OVEN CLEAN.
  • Anonymous Mar 14, 2014
    kitchen aid oven won't let me adjust temperature
  • Anonymous Mar 19, 2014
    select clean, push enter
    turned to clean, then enter nothing happened.
  • Anonymous Mar 20, 2014
    display panel is blank
  • Anonymous Mar 31, 2014
    the handle on my kitchen aid superba microwave broke off. how do i fix it?
I turned off the power to my house and turned it back on to reset my Uverse DVR, and Internet because I couldn't get the DVR to operate. After I did this, my Kitchenaid Microwave began shutting off within one second. Next a lost communication error code of F6EO appeared on the panel. I switched off the power to just the oven for about 5 minutes and then back on. It seems to have corrected the problem. I am beginning to hate computers.
Posted on Apr 20, 2013
  • KitchenAid Master
  • 19,396 Answers
Please visit the linke below with complete list of Kitchenaid error codes.
Troubleshooting KitchenAid oven, range and...
Regards.
Posted on Mar 27, 2010
    Sniper:
  • 68 Answers
The F-3 error code typically means you have sensor problem. The sensor is usually mounted in the oven space up near the top of the unit. The first thing to do is turn off the circuit breaker to the oven. Do you have an ohm meter? I suggest if you don't to purchase one. They are relatively inexpensive. Maybe you can borrow one from a friend. Disconnect the sensor from the electronic control and measure the resistance. There should be a wiring diagram in the top of the unit that will help you to locate the sensor wires. Most sensors should read around 1100 ohms at room temperature. If sensor reads as an open circuit or has a very high resistance, it must be replaced. If instead it reads very low, then there is a short in the wiring. Some units have a fuse in series with the sensor. Check to see that the fuse has not blown.
Posted on May 03, 2007
What does errer codes E6 and F2 on KitchenAid Superba oven mean
From the Site:
"F2-E6 - Cancel Key Line Open - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure. Select the 'cancel' function and wait 60 seconds. If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly. All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD)."
Kitchen Aid Appliance Fault Codes
Hope this helps!
Anthony
Mar 17, 2018 | KitchenAid Ovens
Tip
Kitchen Aid Oven / Stove Fault Codes
If your Kitchen Aid Oven is showing fault codes starting with F, the problems and solutions can be found at the following website.
CLICK HERE
on Feb 26, 2011 | Ovens
Kitchen Aid f3e2
F3 - E2 Oven temperature is too high (Cook mode)
Replace Oven temperature sensor (RTD)
Note:
This error code applies to all F3-E... faults.
Good luck.
Jul 21, 2011 | Ovens
We installed kitchen aid microwave convection oven model kems308. it is displaying error code F6E0, "Lost communication". Any idea on how to fix?
Turn the power to the oven off. It usually is not possible to unplug the power chord for the built-in appliances so go to the main switch board and just turn off the oven power for about 5 minutes and then turn on the switch. The error code should disappear. Mine did!
Chander Mehta
Jun 06, 2010 | KitchenAid 27 in. Built-in...
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 | Ovens
Kitchen Aid Oven - Superba Selectra- receive
Here is what Kitchen Aid says about F4:
F4 Meat probe shorted
1. Disconnect meat probe and measure probe resistance (78kω at 60° F [15.6° C],
37kω at 90° F [32.2° C]).
2. If resistance is not valid replace probe.
3. Insert probe and check for a firm connection between probe and jack (in oven cavity).
4. Check connection between jack and harness (in rear of oven).
It sounds like the probe jack may be bad or the wiring between the jack and the control board above.
May 10, 2010 | KitchenAid Architect Series KEMC308KSS...
Error code F2 E3 r:02 E:03
Kitchen Aid Error Code F2-E3
Called kitchen aid, they said you need a new control board part #9782455.
Mar 16, 2010 | KitchenAid KEBC107 Electric Single Oven
Kitchen aid oven is'nt working and giving code F2:E3 help what does it mean
Here is a page with all of the error codes for your oven.
http://www.appliancetimers.com/index.php?page=failure_code_page&manufacturer=ka&type=r
Your code is 2 parts, F2 is oven temp is too high, and the E0 wants you to test the relay contact operation. In simpler language make sure the connections are tight.
May 09, 2009 | KitchenAid Ovens
KitchenAid KEMC378 Electric Double Oven Logo
1,583 people viewed this question
Top KitchenAid Ovens Experts
Marvin
Marvin
Craig Butler
Craig Butler
Jim Goldsmith
Jim Goldsmith
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
