Question about Canon PIXMA MP600 all-In-One InkJet Printer
On power on get error code 5110 worked yesterday
Canon mp600 error code 5110. Have tried common fixes with power button and reset button and unplugging power
  • Greg Martin Dec 28, 2008
    Thank you. I suspected some kind of internel problem as during the night before it quit there was a power outage. The carriage was probably in the wrong place and is stuck. Will work on it when I get time. Thanks again. Greg.
  • 837 Answers
That is unfortunately a board or feed problem and needs to be serviced. If the printer is still under warranty send it back .. otherwise replace it
Posted on Dec 26, 2008
    President:
  • 2,110 Answers
5110 ERREOR is carraige cant life. this can be down to a few things, carriage is stuck on the purge unit or the logic board is at fault. best to take it to a Canon dealer for repair or contact a supporter dealer who can do a chargeable call for you. in the uk i have few contacts . hope this helps
  • 15,935 Answers
That error is factory service required. Sorry!
  • 1 more comment
  • blueextc3221
    blueextc3221 Dec 26, 2008
    Take out your catridges and slide the cart over towards the left a bit. You will need a little mirror for this. Look through the rectangular cutouts at the bottom of the carriage, and find what looks like 2 very tiny black sensors. I think these pick up the lights from the LEDs in the cartridge, and I spilt ink on these while refilling my carts. Take a cotton bud and clean these off. As soon as I did this the error went away and printer is 100% OK again. (This was an MP530 - but should be similar)
  • blueextc3221
    After talking with Canon Tech Support, they told me to return the printer and get a replacement
  • blueextc3221
    What I had to do was open the lid and turn the printer on. While the printer is going through its startup GENTLY push the print head and cartgridge tray to the right.
    What I think happened with mine, was it was turned off while the lid was open and an ink cartridge was out. When turned on it could not test or clean, hence the problem. So gently pushing to the right it was able to shift everything back into place for startup test.
What is the Canon MX850 Error Code 5110?
The paper goes in from the front, under the 'paper output' tray.
Feb 14, 2015 | Canon PIXMA Office Equipment & Supplies
Error 6502 on my canon MP600
That particular error Code appears generally after chaging a cartridge.
Solution:
  1. Unplug the printer.
  2. Remove the faulty Cartridge
  3. Plug in the printer and press and hold Power button
  4. Keep it held down. Press Resume twice, and this should reset the fault.
Apr 20, 2011 | Canon PIXMA MP600 all-In-One InkJet...
How can I reset canon Pixma MP600 error code 5B01 please?
pull out your ink carg and on your printer and then put back the cag and use your printer its work aone
Mar 15, 2011 | Canon PIXMA MP600 all-In-One InkJet...
Error Code 9000 on my mp600
its worth trying this aswell:
1, Power off the printer
2, Unplug the printer's power cord, wait 5 seconds then replug the power cord in.
3, Hold the Power button for 6 Beeps
4, Release the Power Button
This will reset the printer and should resolve incorrect cartridge detection problems
Error Code 9000
The USB Host VBUS is overloaded.
Replace Logic board
Feb 24, 2011 | Canon PIXMA MP600 all-In-One InkJet...
Canon mp 600, errorcode 5c00
Hi there it is ink error.
You can try to reset the cartages this may do it Please call back let us know if it worked for you, PLEASE.
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click “Power” button. Green led should be on
  3. While holding the Power button, release the Resume Button.
  4. Without releasing the Power Button, click “Resume” button for two times and release Both Buttons.
  5. Click “Resume” for four times then soon click “Power” button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
  7. Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Oct 04, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Error
Try
Error Code 6502 appears generally after chaging a cartridge.
Solution:
  3. Plug in the printer and press and hold power button
All Best: Pineworks
Dec 23, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon mp600 error 5110
i have the same problem anyone know what 5110 means???
Jul 06, 2008 | Canon Office Equipment & Supplies
My canon MP600 PRINTER
There's a couple things you can try:
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.
Double check that your ink tanks are seated right too
If you STILL have the error code, try these two types of resets:
To clear the memory:
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
To do a stop/reset:
To clear error messages displayed on the LCD or if the printer is not functioning as expected, it may be necessary to simultaneously press Stop/Reset and ON/OFF buttons.
  1. With the printer powered on, PRESS AND HOLD DOWN the <Stop/Reset> button then press the ON/OFF button.
  2. Once the printer is powered off, hold down <Stop/Reset> and then press <ON/OFF>.
If none of the above clears it up, you may have to have the machine serviced.. check to see if you are still under warranty.
Good Luck!
Maggie B
Feb 23, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon Pixma MP600r - error code 5110
Dec 23, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
136 people viewed this question
old marine
old marine
