Wireless mouse goes in and out
My wireless mouse seems to go off all the time. I know it is on the control panel under the mouse setting. Both batteries are new and they are not old batteries. I look under the trouble shooting, and I can't not fine where to go. Could you help me? I have a HP 60-125 NR Notebook PC.
I got the computer not too long ago. Model of this mouse is DX-PWLMSE.
  • 709 Answers
Clean the contacts where the battery connects. My wireless mouse was doing the same thing even with new batteries. I had to use a toothpick with a piece of Pencil eraser on its tip to clean the contacts in my mouse.
Posted on Dec 26, 2008
I have an older HP desktop and just added a new HP wirewless optical mobile mouse with usb. They seemed to work fine initially but then I needed to move the computer so everything was shut down and moved...
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you can update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps
Jan 13, 2011 | HP Wireless Optical Mouse
My wireless mouse is not working
Hello sbregar here, your problem is not very hard try ALL usb connections, if that doesnt work go to HARDWARE under control panel and click new hardware, you go through a wizard and it should work thanks. :D
Feb 14, 2010 | Microsoft Wireless Notebook Optical Mouse...
Mouse left button double clicks all by itself about every other time it is pressed. Very annoying. May be an internal contact problem, but don't know how to open it up to check.
Recommend you check your mouse settings on your computer (i.e. mouse properties buried in control panel settings as found on Windows XP); make sure double-click speed is not set at an over-sensitive setting.
Might also check there is nothing sticky under the mouse key, causing it to get stuck (e.g. splashed soda pop or something that got under there).
Feb 10, 2010 | Logitech Wireless Mouse & Keyboard
MOUSE IS HARD TO CONTROL VERY SHAKEY WIRELESS MOUSE THERE SEEMS TO NO DUST IN IT
Wireless mice are known to have trouble with certain wooden and metal surfaces that they can be used on, if not using a mouse-pad try one.
Secondly, if that doesn't work. Be sure that your mouse isn't set to be very fast in your mouse preferences under mouses in your control panel
Hope this help!
- Jason Cornelius
If it helps, be sure to throw me some thumbs up!
Dec 14, 2009 | HP Wireless Optical Mouse
MS Wireless IntelliMouse 2.0 pointer direction reversed (up/down)
Go into the control panel and click on the mouse icon and see if you can change to settings back to normal.
If not then check under your start menu and see if the intellimouse software is installed there and go into it to change the settings from there.
Feb 14, 2009 | Microsoft Wireless IntelliMouse Explorer
HYBRID CONECTED TO AN HDTV AS A MONITOR
Change the power options in the control panel so it doesn't go on standby when your in the middle of something
Jan 17, 2009 | Dell Studio Hybrid Desktop Computer
Microsoft Wireless Laser Mouse 6000 (Model 1052):
Normal 0 Go to Control Panel and click on the Mouse icon. Then the mouse properties will appear showing the mouse buttons. Put the pointer on the left button and then go to the drop down and make sure the buttoon is set properly.
Hope this helps. Bud
Jan 02, 2009 | Microsoft Wireless Laser Mouse 6000 v2.0
Wireless mouse
Normal 0 Go to Control Panel and click on the Mouse icon. Then the mouse properties will appear showing the mouse buttons. Check to make sure they are set properly.
Jan 01, 2009 | Toshiba Wireless Mouse PA3205U-1ETC
Wireless mouse intermittent
try going into your control panel, go mouse/ settings change your mouse settings and get some air for computers clean everything on the mouse
May 18, 2017 | HP Wireless Optical Mouse
Computers & Internet Logo
107 people viewed this question
David Payne
David Payne
