Question about Sony RDR-GX7 DVD Recorder
Discs I always used -R discs & recorded tv programs fine. I just bought Sony DVD +RW discs so I could write over the programs I record & the recorder won't use them. It says - cannot use this disc. The manual says I can use them. What can be the problem? Also, I couldn't play a new DVD of Talledega Nights I borrowed recently. I can play other movies I buy or rent. Lynnette
  • Lynnette Lee May 05, 2007
    I did try a DVD drive cleaner. It's not a wet type though. Does that make a difference?
    Sergeant:
    Champion:
  • 326 Answers
Hello, please try to clean the laser unit (OPU). You can use special (wet) cleaning disc obtainable at the market or ask the pro to do it for you. If you need more info please advice.
Posted on May 02, 2007
Sony RDRGXD455 have tried both DVD-RW and DVD+RW discs from Phillips and they do not work. I have tried VR and Video modes. Do you think Verbatim DVD-RW discs would work?
It depends on what you are trying to record on them. These machines have copy protection built in. So if they detect that they won't let you record on the disc.
Mar 26, 2017 | Sony Televison & Video
I have a sony rdr-gxd455 dvd recorder that is supposed to play DVD-RW and DVD+RW discs. Everytime I load one of these discs, I get a Disc Error, even for one that was not used before.
If you get a disc error, it could be dirt on the lens. So you should try cleaning it. Generally this effect all discs, but your player might be sensitive so only does it on new discs. You could have a bought a bunch of fake discs too, looking genuine, but useless!
Lastly a fault on the player.
Sep 19, 2016 | Sony RDR-GXD455 DVD Recorder
Model DMR-ES30VEB. I have had this recorder for a few years now but since I got a new Sony TV at christmas I am having problems recording. When I record a programme the DVD says it does not recognise the...
DVD-RW discs are ideal for temporary video recording and data backup, but they are not recommended for successful finalising, as there is no guarantee that the disc will work in another device.
Have you tried using DVD-R discs? these CAN be recorded in video mode AND finalised for compatible playback in other players. I assume the DMR-ES30V is a DVD/VCR combo unit - if so, the DVD recorder will not recognise RW discs; only DVD-RAM and DVD-R.
DVD-R discs are recommended for video recording and finalising in this model. (later model Panasonic DVD recorders allow RW disc recording).
Mar 26, 2011 | Panasonic DMR-ES30VEBS
Recorder works great but cannot play DVDs recorded from television on my computer. These recordings were made of several films over six hours on DVD-RW discs. I have Windows 7 and have tried all types...
Recordings made on DVD-RW discs cannot be played in other players, including many PC DVD-ROM drives; incompatible format. If you had recorded your TV/video material onto a DVD-R in the recorder, for example, then finalised the disc, it would work in your PC and any DVD player.
But since you used a re-writable video/data DVD, it won't work outside of the recorder - that's why you can't play it (or if it was written on your PC, your recorder won't read it - incompatible disc).
If you don't wish to finalise the RW disc (I don't recommend it - plus I wouldn't blame you for not wanting to do that), you could copy it from one recorder to another, unless your PC has a capture card - which allows the outputs of your DVD recorder to connect to the PC inputs. Using relevant DVD software (for example, ULead DVD factory), you may be able to 're-author' the contents of your recording, and create a DVD-R copy which WILL work in all players that way - use DVD-R (or DVD+R if your PC and other players allow that format) for 'permanent' video recording - use re-writable discs for backups, test recordings, temporary stuff, and PC data files. There are many inexpensive software programs available. Have a look sometime at your leisure. See what they are like.
Even if you could copy the DVD contents in a Windows program, regardless of the software used, there is no guarantee that the copy you make will work outside of the player and/or original recorder, because it would require a lot of time and effort to achieve, and unless you know what you're doing with the program, you could waste a lot of time (and blank discs) in the process - it only adds to the frustration.
I am glad to hear your recorder has no major faults at present - that's great. No expensive workshop repair cost headaches; just frustration with discs (especially if they become drink coasters).
DVD-RW is ideal for test video recordings and PC data, but is limited when it comes to compatible playback/usage outside of the device it was written/recorded on.
DVD+RW discs on the other hand, when titled/ top menu created, can be played on a PC or player without finalising. You can even direct copy a DVD+RW straight to a DVD-R - it works in most cases.
The upshot of this is you haven't lost anything, and with the exception of perhaps a few dollars for a pack of either DVD+RW, DVD+R, or DVD-R discs (any brand), it didn't cost a fortune. You can also retain any DVD-RW discs you have previously used.
The simplest and cheapest options are often the best ones.
Mar 24, 2011 | Panasonic DMR-ES10 DVD Recorder
I have dubbed vcr tape to a Sony DVD-RW disc and tried playing it back through a toshiba player and it keeps coming up Bad Disk. My PC won't even recognise it. When started dubbing the screen displayed 1hr...
Did you say you used a DVD-RW disc to transfer a videotape onto? The reason your PC won't recognise that disc is because the data format on it is a different language to what PCs understand - plus an unfinalised DVD-RW won't play in other DVD players - it is usually an incompatible format.
(DVD+RW discs with titles/top menus created in video mode CAN be played on a PC DVD drive or a normal DVD player as can finalised DVD-R discs (DVD-R discs MUST be recorded and finalised in the same recorder for compatible playback). DVD-RW discs can only be viewed on the unit they were written/recorded on.
The other reason for the 'remaining space' on the disc you describe showing less than 120 minutes is due to a title recently being recorded or erased - unless you format it - the 120 minute / 4.7GB DVD-RW will not show full available space. Erasing titles on re-writable DVDs does not increase space. The same rule applies to unfinalised +R / -R discs (you cannot re-format these to get the space back once recorded - they are 'once only' writables)
I recommend you invest in some DVD-R discs and re-copy your VHS tape to that - then if you are satisfied with the result, title etc., finalise the DVD-R - it will play on any DVD player or PC with DVD support (or it should). These discs are relatively inexpensive to buy just about anywhere.
Final note: do NOT finalise the DVD-RW you recorded (I hope you haven't already done this) - simply format/erase it - re-use it for something else or keep it until you need it.
You can use any brand of DVD, just take note of the format before recording/playing.
Mar 21, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Disc say cant record,what disc do i buy
This model (PY90DG) DVD recorder supports the following disc recording formats: DVD+RW/DVD-RW/DVD+R/DVD-R for everyday video. These should record fine. The RW discs are for repeated recording/erasure while the R discs are once-only recording types - the R discs must be finalised in this deck to make them playable on other DVD players. DVD-RAM discs are NOT supported by this unit. This recorder will play MP3 files on a CD-R or CD-RW (not DVD-ROM) just fine as well, but will not record them.
Best discs to buy for this type of recorder are DVD-R (recommended brand - Verbatim or TDK if you can get them, but not Memorex). These are OK.
Feb 22, 2011 | Funai PY90DG DVD Recorder
I was wondering if you could help us with our DVD recorder. Its a Toshiba DVD Recorder Model: D-R18DTKB and up until recently has been in good working order. A while back I bought some Sony+RW...
Hi Tony
Although I am a member of this site I came across your post while searching Google for answers to the same issues as you are having.
From what you say and what I have tried I can only put fault with the DVD recorder itself and probably the LASER.
This thing just seems to hate reading recorded media of almost any format including those which it's stickered front panel boasts about. It also doesn't leave you with many other options as there is no USB port either.
I dont use the unit to record or the Freeview facility and never have as we have Sky+ and no TV ariel.
I bought it for the varied formats of video it says it can play but out of 6 different formats that I recorded onto DVD with my PC (and I am an advanced user and work in I.T) it only played back one and badly which was a mpeg-1.
I put the same 6 disks into my sons (apparantly DVD only) player bought from ASDA for £15 and it played 4 of them perfectly as good as the originals!
Logically this would suggest this model is a Lemon. I just hope your not a £130 light lemon as I am!
Oct 27, 2010 | Televison & Video
Lg dvd rw recording problems
Hi
You might like to know that this recorder works well with DVD+R, DVD-R and DVD-RW but is known to not work well with DVD+RW. This is likely to be the main cause of your problem if you experience these problems and find it happens mostly with DVD+RW.
If the problem occurs across all formats a DVD cleaning disk should help the problem.
Hope this helps. Please do rate my answer. Thanks.
Jul 26, 2009 | LG Televison & Video
Disc initialization Toshiba D-R250SB recorder
can i suggest you record vhs tapes on maxell dvd-r or tdk dvd-r (if you wish to keep them) used the dvd-rw to record those sporting events / movies or specials that you might not be around for....(because any one can accidently erase an dvd-rw).......now that formatting dvd-rw issue. i found that dynex http://www.dynexproducts.com/c-11-storage-media.aspx dvdv-rw works best with toshiba . i record all the ultimate fights erase (format) after i look at and on to next good luck
May 28, 2009 | Toshiba DRW2 DVD Recorder
Cannot initialize DVD discs. Same one I always used Sony rw. Seemed to work fine for ages now doesn't want to initialize any of them.
are you using + or - discs and are they the same type of disc which your programme was originally recorded, as a minus pre recording will not be able to be written to a plus disc so make sure both formats are same
Apr 13, 2008 | Televison & Video
Sony RDR-GX7 DVD Recorder Logo
279 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
