Question about Microsoft Windows XP Professional
Error in application download due to regsvr.exe is missing
Not able to save application s because of regsvr.exe file is missing in system32 and in windows file so please help me to solve the error.
  • Anonymous Dec 28, 2008
    how to solve
  • Anonymous Jan 27, 2009
     regsvr.exe is missing problem
I have regsvr.ex missing problem
Posted on Jul 21, 2009
Window is asking about Regsvr.exe file at the start up.
Posted on Feb 27, 2009
Solve this problem
    New Friend:
Windows cannot find 'camfrogs.vbs'.make sure you typed the name correctly,and then try again.
Posted on Jan 08, 2014
I have a problem in my computer that "windows cannot find regsvr.exe"
Posted on Aug 16, 2010
  • 392 Answers
Your windows damaged, update it or FDISK it and install it again. of course some utility softwares are available, for example Symbian products, install some of them and try to solve the problem by these softwares
Posted on Dec 28, 2008
4 Suggested Answers
  • 3 Answers
SOURCE: " windows cannot find 'regsvr.exe'.
Regsvr.exe file is a virus. In order to remove the startup error message you need to change a registry value using registry editor. the solution in detailed steps with screen shots is given in the site below:
It is a simple one and it worked for me, hope it works for u also.
Posted on Mar 06, 2009
SOURCE: cannot find regsvr.exe
it showing the same problem as i installed the Regsvr.exe file in System32. it showing file missing on or corrected...... can u get from this .
Posted on Mar 15, 2009
  • 14 Answers
SOURCE: Trojans wont go away. Hijackthis SCAN help
I've had VERY good luck by using this Kapersky Antivirus rescue. Here is a link to that, courtesy Brothersoft:
Scroll down, it is a 102MB download.
Download this to a known clean machine and burn a CD. Once burned, put it in the infected machine and boot. It is a linux based OS Live CD, so it won't be infecting this disc. Live CD's are great, they take a little while to boot though.
Make sure you have an active internet connection as the program will update itself before scanning. If if says it won't mount the internal drive, choose Force Mount. In Settings, choose scan all files, set level to highest threat level.
This CD saved my **** and is now a permanent part of my CD collection!!!!!!!
After this finds the problems, download and install and run both Malwarebytes (full scan) and also Superantispyware (full scan). After those, download Avira-Free AV software.
By this time, you should have killed the beasties dead in their tracks!
Best Regards,
Posted on May 11, 2009
Disconnectivity within 1 minute I install a fresh
A lot of Windows Update Issues are linked to this Intel Storage Technology Driver being out of date. Hope this helps!
Aug 16, 2013 | Computers & Internet
this is your directx problem. the directx plugin which is required to play tekken 5 is missing or not installed in your pc. to fix this problem, you have to install latest directx or update current directx version to latest version. updating directx may take nearly 150 to 200MB.
Apr 11, 2013 | Computers & Internet
HAL.DLL is missing or corrupted, xp doesn't boot
if it was running for more than 30 hours, it wasn't doing much. You can try copying hal.dll off of a known, good-working XP pc, and replace it with the one on your broken PC. It's better if you extract it from i386 folder but grabbing it from another pc should work fine.
Aug 09, 2012 | Microsoft Windows XP Professional
I think i have a worm on my pc. my folders are duplicating with a .exe. pls help
TRY RUNNING SUPERANTISPYWARE i have used this program it works very well for removal of all varients and other little pesky varmint on your pc.
Jan 26, 2010 | ASUS Eee 4G Notebook
Regsvr.exe not found please help me
This is your problem i think: Windows cannot find 'regsvr.exe'.Make sure you typed the name correctly,and then try again.To search for file,click the start button,and then click search.
Most likely you had a virus that installed a Regsvr.exe reference into your Windows registry. If it shows as "missing" at start-up it's because your anti-virus software removed the program but not the reference. You need a registry cleaner tool like CCleaner. It's a free tool that can be used to clean both your registry and delete junk files from your hard drive.
I found a few things you can do: 1.
2. Just Google CCleaner - download and run it.
3. I found a site. just follow thes steps:
4. I found (maybe) the got the error at startup say that regsvr.exe not found.
Plz find the process how to remove this error
Goto-> RUN-> Regedit->HKEY_LOCAL_MEACHINE->SOFTWARE->MICROSOFT->WINDOWS NT->CURRENT VERSION->WINLOGON->in the reght side panel u can see the key SHELL -> in that key u if u see the two names (Explorer.EXE Regsver.exe) plz delete only the regsver.exe(plz do not remove the explorer.exe) Just Press OK
if you find it difficult, i found a site with the same steps but with screenshots: I found the soultion for the same.
I hope it works for you. And please rate
Jul 08, 2009 | Microsoft Computers & Internet
When I open computer a message displayed cannot find regsvr.exe
Hi there.
You have a virus on the PC!!
What the regsvr.exe virus does?
• This worm creates folders and a registry entry to enable its automatic execution at every system startup.
• This worm also creates a scheduled task to enable its automatic execution at a specified date and/or time.
• It also creates Autorun.inf file for its auto execution.
Solution to fix the problem:
1. If the task manager and registry editor is disabled then we need to enable them first. Read this post.
2. Delete the Autorun.inf file created by the virus. First go to cmd (start menu, run or search, type “attrib X:Autorun.inf –s –r –h” without quotes where X is your drive name which is having the problem. Now the file is visible and ready to delete. After deleting the file, close the explorer and open it again
3. Now type msconfig in the Run dialog and click on startup tab.
4. Look for regsvr and uncheck any options, click OK.
5. Now traverse to control panel -> scheduled tasks, and delete the At1 task that might be listed there.
6. Type regedit in the Run dialog to open the registry editor.
7. Click on Edit -> Find and search for regsvr.exe
8. Just delete all the occurrences of regsvr.exe virus (do not confuse it with regsvr32.exe which is not a virus).
9. Navigate to entry HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindows NTCurrentVersionWinlogon and modify the entry Shell = “Explorer.exe regsvr.exe” to delete the regsvr.exe from it.
shell_regsvr.jpg10. Now to actually delete the virus from the system go to system32 folder and delete the regsvr.exe virus file from there (you will need to uncheck the option of “Hide Protected System Files and Folders” in Folder Options to view the virus file).
Reboot the system for changes to take place.
If this is too much for you to understand please post back for an alternative.
Good luck
May 27, 2009 | Microsoft Windows XP Professional
I am of the mind to do a complete reinstall of the operating system including flash the BIOS even if it is the same version. I worked many hours tracking down and thinking you found every part of the problem on to hit an .EXE and it all starts over again....I just clean out everything and start fresh.
If you tell us what make and model of computer along with the operating system it is we can direct you to the drivers for the reinstall. Some off those programs - for example AOL seem to be virus magnets. (if it is a dell it is really simple if you just put in your service code- it give you your particular driver of your computer.)
That is what I would do...Or you can keep hunting.
please leave rating,,,thank you
May 11, 2009 | Microsoft Windows XP Media Center Edition...
type in run "msconfig:
then go to starup then disable all.thenrestart the system.thats all dear .
Jan 05, 2009 | Microsoft Windows XP Professional
Common Language Runtime and Windows cannot find 'regsvr.exe'
This is malware! Never click on an executable file that you do not know as you activate a worm or virus by doing so. A quick google search of the file name is prudent if you do not know what that file is. Now you should download the Windows Malicious Software Removal Tool from Microsoft here: Let me know if you need further help. Steve
Dec 19, 2008 | Microsoft Windows XP Professional
Cannot find regsvr.exe
Download and run this:'s a virus you have. It will get worse if you don't clean it or restore your computer.
Oct 24, 2008 | Microsoft Windows XP Professional
Microsoft Windows XP Professional Logo
517 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
