Question about Maytag PYE2300AY Electric Dryer
Drum will not turn
I just replaced my heater element in my maytag dryer. I took out the drum to clean, put it back together and now cannot get the drum to turn. The belt is on the pully assembly and the motor.......... Now what ??
  • 179 Answers
Check the belt to make sure that you have it on right
Posted on Dec 26, 2008
My Maytag Ensignia electric dryer quite heating. I cleaned front and back lint traps. I'm trying to find where the heating element is at. I was told to remove the drum through the front to get to the...
I worked on one not long ago and made some photos.
You pop the top using a putty knife and remove the front.
The element is mounted in the rear and is held in place by 2 screws. The thermal fuse and high limit are also mounted on it.themobilian_2824.jpg
I worked on swapping out a motor and took some photos:
Maytag Ensignia motor replacement
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 16, 2011 | Maytag Dryers
All the clothes in my dryer dry at a normal time, but the smell burnt! After a dry cycle, the inside of the dryer smells like something is melting, but everything seems to be working correctly. We have had...
Remove the vent duct at the back and clean out all of the lint. Next, find the air inlet to the heater elements and make sure there is no lint accumulated there. Inspect the back of the drum (inside) for any plastic debris (something left in a pocket?) that might have melted and stuck on there. Last resort: remove the dryer cabinet and drum, and inspect the heater and its wiring. If the insulation on the wires appears burned or is broken off, cut off the damaged part of the wiring and replace its terminals, then polish the heater terminals before reattaching the wires (a tarnished connection will cause the wire to overheat). Clean out the heater if necessary, but be careful not to stress the heater element. Used heater wire is brittle and cracks or breaks easily.
Jul 04, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
Screen on back of drum is rusty
http://www2.partstore.com/Brand-Landing-Pages/Maytag/Maytag-G1.dot?s=Google&CID=g8Account18Maytag8GeneralTerms8VersionGwithGLS&gclid=CN26uJ6E7Z4CFR8RagodTXZyuA
Go to this site .They have replacement parts .
But it is easy to get it to a appliance repair person as it needs some professional knowledge on how to take it apart and put it together .
Merry Christmas to you .
Dec 23, 2009 | Maytag Dryers
My Maytag Performa dryer is blowing out cold air. How can I fix it myself?
remove frt cvr,then top then remove drum belt and drum, check for open heater element, defective thermal fuse,hi-limit switch, open neutral to element if it uses the neutral connection
Oct 18, 2009 | Maytag 7.0 Cu. Ft. Electric Dryer
Need help with installing belt in Maytag Electric dryer
if not able to remove rear panel,you will need to start,like most models,take top cover off and hinge back to wall then remove frt cover including door as a whole assy. lift up drum put new belt on drum ( and position in same area as old belt,it will have marks on drum from where original belt was on drum) then put rest of belt over mtr pulley and then idler pulley, turn drum by hand to align belts and put it back together in reverse order
Jul 28, 2009 | Maytag PYE2300AY Electric Dryer
MOD T700 ASKO DRYER REPLACED DRUM ROLLERS PUT BACK TOGETHER WILL NOT TURN ON
When I took the back off my Asko to clean it out I had to lay it on its face to get the drum to line up again with the back - in the doing this a wire pulled off its setting. Did not figure this out until I took the top off the dryer and found the loose wire. I have no idea if this is your problem but it was very frustrating. There is also a black reset button on the back of the dryer that you might try.
Jun 15, 2009 | Asko T701 Electric Dryer
Dryer drum does not turn - only by hand?
Try this link, the first one the maytag one has the actual instructions, all dryers a pretty similar you just have to route the belt according to the diagram!! Good luck,, ps a good rating would be nice! thanks
http://fixitnow.com/wp/2004/08/19/appliance-repair-revelation-how-does-that-dryer-belt-go-back-on/
May 10, 2009 | Dryers
MAYTAG DRYER DE-306 REPLACING HEATER ELEMENT
the elament is in center of drum take off back of drum
Feb 18, 2009 | Zanussi TD4212W Electric Dryer
Maytag dryer: pye2300ayw
yes, it will. you should be able to take off the panel on the bottom of the front of the dryer. way in the back is the heating element. do not put your hands in there with the power on, but start the dryer and look in there and you will see if the heating element comes on. it will be like looking inside your toaster.
Oct 27, 2008 | Maytag PYE2300AY Electric Dryer
Help!!!
Further dissassembly is required. You'll want to do this anyway to inspect the heating elements. Some of what I say my not apply to your model (because you did not list a model number). 1. Disconnect power to dryer. 2. open door and remove screws going up into the dryer top. (two or four) Usually these are phillips screws, but you may find tri-wing phillips or T-15 torx. 3. swing top back, allowing access to remove the two screws holding the front panel to the side panels. (near the top) 5/16 hex or twin drive (phillips / #2 robertson square drive) 4. tilt front panel forward, lift off and swing to the side. You don't have to remove the door switch wires if you don't want to. 5. Pull drum forward a few inches. (it's a tight fit to get it past the dryer sides) 6. release dryer drive belt. 7. Finish removing the drum.
8. inspect coil heating elements. If one or both have a break in them, you can replace just the coils, you don't have to get the entire big metal part that holds them. 8. Clean and reassemble. (check the teflon rear drum sleeve bearing and the front drum support slides. now's the easiest time to replace them if needed.) 9. put the drum back in, then the belt back on by reaching your thin arms way back to the belt tensioning pulley. The grooved side of the belt touches the drum and goes down directly to the motor drive pulley on the left, then around the tensioning pulley. 10. Put front back on dryer. 11. turn drum by hand several revolutions to make sure the belt is not twisted or comes off. 11. Finish reassemble, connect power and test. You're done !
Aug 31, 2008 | GE Dryers
Maytag PYE2300AY Electric Dryer Logo
55 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
