Question about Sony Playstation 3 (PS3) Console
HDMI for PS3 Doesnt work
I;ve tried the fixes including turning the set off and then on, checking the settings on my PS3 but I cant get a signal
  • Osiris2067 Dec 26, 2008
    Having the same trouble also. Worked fine last night now all I get is a blank screen and no main menu or anything.
    Alex
    Problem Solver:
  • 7 Answers
Do you get picture on tube tv if so hook up to tube tv go to settings and set for hdmi then turn off and take to hd tv hook up with hdmi cable and should work you need to set hdmi in settings as it will be set for s-video at 480p I do believe
Posted on Mar 28, 2010
Ps3 turns on but no signal on tv
Hi There,
Is the TV set for the correct input?
I assume you are using HDMI?
If all settings and input selections are correct then I will have to say that either the HDMI cable is faulty, or the HDMI port on either the TV or PS3 could be faulty.
Check if PS3 can work on another TV with the HDMI cable.
Check if another Device can work on that TV with the HDMI cable.
Try another HDMI cable.
From this, you should be able to determine where the issue is sitting.
Hope this helps!
Jan 13, 2016 | Sony Playstation 3 (PS3) Console
I own a Sony kdf-55e2000 , when I try to hook up a ps3 through the hdmi imputs i get a message reading "unsupported signal please check device output" i can here the sound but no picture.Is there any
try only having the hdmi cable hooked up to ps3 and tv, turn off ps3 and hold power button for 5 or 10 seconds and you should hear 3 beeps, this should reset the ps3 and detect the settings, if this doesnt work you mmay have to manually change audio and video settings in the ps3 settings menu to hdmi output and auto detect which settings work.
Jan 05, 2013 | Sony Grand WEGA KDF55E2000 55" Projection...
Technosonic hdmi help my xbox 360 works with the hdmi but my ps3 doesn't
have you made sure the hdmi out on the ps3 is turned on (its in the settings can't remember exactly where and i've just sold my ps3 so until i get 'round to putting another together i cant check for you) start with the menu on the extreme left then it's somthing named settings or similar have a look through it won't take long to find
Oct 02, 2012 | Video Game Consoles & Games
Connecting Ps3 with philips tv (full hd) when i got hd cable in, and click to switch so the ps3 uses hd to show things and i than switch over to the channel i plugin the hdmi cabel it gives blac kscreen
If it's the first time using your PS3, use the composite cables that came with it. Turn on the PS3 go to video settings and switch the input to HDMI. After you've switched to HDMI, turn the PS3 off and connect your HDMI cable, go back to video settings and change the resolution to 1080p. If this isn't the first time you've used HDMI for your PS3, make sure your T.V. is on the correct input. If the T.V. is on the correct input, try switching the HDMI cable to a different input. If that doesn't work try using a different HDMI cable, testing different HDMI connections if you're still getting the black screen. If none of those work then it's probably a problem with the PS3, but just to make sure try plugging something else with HDMI to see if that works. If another HDMI device works, then it's your PS3, if it doesn't then it could be a problem with your HDMI connections on the T.V.
May 04, 2011 | Philips 52 In. LCD HDTV
I plugged in my PS3 using an HDMI cable and i get no feedback
If you just bought the PS3 use your composite cables that came with the system. Turn the PS3 on and go to the video settings, set up video input to HDMI. After you've done that plug your HDMI back into your PS3 and try turning it on. If that works go back to video settings and change the resolution to 1080p. If that doesn't work make sure your T.V. is on the same input that the HDMI cable is plugged in. If it is and still doesn't work try switching to a different HDMI port. If switching to a different HDMI port doesn't work try a new HDMI cable. If the new HDMI cable doesn't work then there is a problem with the port on the PS3 which would require a repair.
May 03, 2011 | Toshiba 50HP66 50 in. Plasma Television
I recently went online to play and now i get 'no signal' on my tv from the ps3.
ok have you set up the ps3 on the same as the tv wants to go to
ex. hdmi tv + hdmi ps3 = hdmi cable
or if you have it through scart check it on there
and if that doesnt work then press and hold the on/off button for 5 seconds or untill it beeps when turning on your ps3 and it should work with the cable you have connected to the tv enjoy
Jan 11, 2011 | Sony Playstation 3 (PS3) Console
I have an 52 inch lg5000 tv . it supposed to be full hd. i ve tried to connect my play station 3 via hdmi cable but the only thing i get is the no signal sigh on the screen i ve tried everything . is my tv...
plug the ps in with power cable only no hdmi. When turning on Hold down the power button until you hear a second set of beeps you have now reset the video settings. Turn the console off and plug in your hdmi and switch back on it should now work.
Jun 10, 2010 | Sony Playstation 3 (PS3) Console
Hdmi doesnt show picture
a few things to check. 1) does the TV tune to the appropriate HDMI port? If not then it isn't detecting a signal from the PS3. In that case you may not have HDMI output turned on. If you can reconnect the A/V cables then go to the system menu to display and set the output correctly. Start with 720p and work your way up to make sure you don't set it to a resolution that your TV can't handle. If you don' have the A/V cables then boot into safe mode and reset to default. This will reset the PS3 to out of the box settings (no data lost).
May 04, 2010 | Sony Playstation 3 (PS3) Console
PS3 doesnt work w/ hdmi
Have you tried reseting your option settings for video output? It could be set up for standard definition. There for not sending a 1080 signal through the HDMI, instead sending a different signal for SCART. There is a master way to do this as well. Think holding the off switch and turning of the master power button at the same time does it (do a search).
Jun 26, 2009 | Sylvania LC195SL9 19 in. LCD TV
PS3 HDMI Audio Problem
The settings on your PS3 may be to high for your TV. try turning off your PS3 and turning it back on, when you turn it on hold the power button untill it beeps aprox 10 sec. this will reset the your PS3 back to original (minimum settings)
Aug 14, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
76 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
