Question about Invicta Dragon Lupah 2096 Wrist Watch
(Loose numbers) Hi. The numbers on my watch recently started to come loose and I was wondering what would it take/cost to fix it?
  • 944 Answers
Any reasonable jeweller will have the tools and skill neede to disassemble this watch, then it should just be a matter of using the correct glue - this will depend on the material of the face and the numbers, but a jeweller would be able to figure this out. If you really want to try yourself then it wouldn't be a particularly complicated job with the right tools, but a jeweller will be able to check if anything else in the watch needs servicing too - it is unusual for the numbers to come off unless moisture has got into the watch or excess heat - both of which are likely to cause much more serious problems in the workings of the watch anyway. If you want to send the watch to Invicta for repair see this site for details; http://www.invictawatch.com/ or call; 1-866-INVICTA mail to; service@invictawatch.com An idea of cost is given on the page linked below although it doesn't specifically list your problem i would imagine it to be around the same as a cleaning, possibly a little more; http://www.invictawatch.com/support_files/service_center/ServiceCenter.htm Hope this helps :)
Posted on Apr 20, 2007
SOURCE:
Loose hand on my watch can it be repaired ?
Take it to a jeweler, most can fix them. But you need to weigh the cost of a new watch versus what you have now and any sentimental value the watch has. If it's a Longines or a Rolex, fix it. If it's a cheapie just get another. But fixing this is not a do it youself project.
Nov 05, 2014 | Watches
70's Era Automatic 2686 minute hand gets stuck
It sounds as though the minute hand is not parallel to the watch face and is getting caught on the hour markers (or 'batons') - it's probably a little loose or maybe slightly bent.
It should be a relatively easy fix but it requires skill and knowledge to do it - not difficult for a watch repairer but close to impossible for your average man in the street.
If you value this watch, take it to a professional to sort it out.
Oct 07, 2017 | Watches
Rolex 1992 replica , minute hand loose
Replica watches are all made in one Chinese town. The parts are pressed, not machined. They dont last long and cant be repaired.
Go online and buy another replica (the best ones are around $200!)
Jan 09, 2014 | Rolex Daytona 116520 Wrist Watch
Mk 5473 watch is loosing time
Okay, so I'd the watch dial says automatic or manual wind you should be able to wind the watch to get it to start working. If the second hand is sweeping buy the minute and hour or just minute hand does not go around properly there are different issues. One. It could be the pinion that is loose, (major repair) two, the watch needs an overhaul meaning cleaned and re oiled(less likely). If only minute hand is giving trouble, its loose(the 2nd hand) or the pinion is loose.
Mar 26, 2013 | Michael Kors MK5473 Ladies Logo Watch
My Rolex Explorer (black face, hacking model) is suddenly losing time and briefly stopping. Something inside rattles when I shake the watch. Can you suggest a likely diagnosis and rough price to hav
It's a very small timing gear, will roughly cost about 60.00 to fix it, has to be taken down part of the way to be put back into place, very common for them to pop loose
If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_2094e122cc46f24c
Sep 27, 2017 | Rolex Watches
I have a Swiss Legend Monte Carlo watch. All of a sudden, the watch's hour hand seems to be stuck at time 8:00 however the second hand still functions. Popping out and spinning the time-set will not...
It seems unlikely that there is any built in function that would cause the symptoms that you describe but it could be something simple like the hand being loose on its shaft.
Yor local jeweler should be able to fix that sort of thing.
Jul 19, 2010 | Cartier Santos W20056D6 Wrist Watch
Tag heuer
It sounds like something has either moved out of place in the movement or something has broken. A qualified watchmaker can repair this for you.
Hope this helps,
Ken
www.yellowstonewatch.com
Apr 05, 2010 | Tag Heuer Link Automatic Chronometer...
Noisey Explorer 2,
The noise and the vibration is coming from the winding rotor loose axle. There can be two causes for it:
1) the rotor axle, bridge and setting (fixing) spring is getting loose. This will be quite easy repair as all it takes is to tighten all screws and replace or tighten setting spring.
2) rotor axle is worn, so, consequently the bridge and the setting spring as well. In this case the rotor axle must be replaced by the new one and re-bushed into the bridge and the new setting spring must be fitted. This takes quite a lot of work and new parts as well.
Can not tell you about the costs, but Rolex repairs has never been cheap. In the U.K.about a year ago I did the repairs as described in chapter 2 and customer was charged £195.00, parts inclusive, and it was cheap by the Rolex standards.
Do not forget to rate, please.
Mar 07, 2009 | Rolex Explorer II 16570 Wrist Watch
Fossil Big Tic Brown Cuff Watch - Faulty??
Hello, not much help I'm afraid, but I was wondering where you intend to get the replacement battery for the 'tic' part? I'm trying to avoid sending it to Fossil.
I imagine your fault would be covered by warranty, and you get 2 years as well I think?
Jan 11, 2008 | Watches
Runs Fast
Usually when a watch with a mechanical movement is running fast its is because the adjustment on the hairspring is advanced to far. Since it wasn't running fast to begin with I can assume its because something was knocked loose. It is possible that a tiny drop of oil was on the hairspring and by knocking the watch two coils are stuck together by the oil. (this usually only happens if it has been over oiled by an amature watch repairer) Magnitization is possible but pretty unlikely, unless you play with Big coils of wire that are carrying a LOT of current. Either way, unless you know what you're doing and have the right tools, you are looking at taking it to a Tag repair center. Since a simple tune up can cost about $250, I'd expect to pay $400 to $500 for that one. Welcome to the wonderful world of high end watches.
Oct 29, 2007 | Tag Heuer Aquagraph CN211A wristwatch
Invicta Dragon Lupah 2096 Wrist Watch Logo
114 people viewed this question
Top Invicta Watches Experts
Arturs Kalnins
Arturs Kalnins
Norman Worley
Are you an Invicta Watch Expert? Answer questions, earn points and help others
