Question about Samsung SGH-a737 Cellular Phone
Water damage on samsung sgh-a737
It got wet and dried for a short amount of time before we had put the battery back in. it only displays a constant DOWNLOAD across the screen how can i reset or restore it for use?
  • 3 more comments
  • Anonymous Dec 27, 2008
    same here the download screen went away but now the keyboard isnt responding, or is resonding incorrectly (I.E. whenever i press 7 it comes up 8)
  • Anonymous Jan 03, 2009
    same problem
  • ashay44 Mar 18, 2009
    even i have same problem....constant download on the screen when i connect the battery. The cellphone didnt got too wet, it was just touched by wet hands...I tried to heat it up by warm air blower...but that aint working....what should i do now..
  • Anonymous Mar 23, 2009
    put my phone through the wash took it out let it dry for bout ten minutes wile i researched if it was completely gone found out bout download and put the battery back in and that's what i get the blue box with red line and white DOWNLOAD in the middle
  • Anonymous Mar 29, 2009
    i have the same problem i rolled in wet grass with my jeans and they barely got wet
  • 3 Answers
I had the same problem, when download came up i charged my phone. then i took out the battery and put back in and turned on. it worked but some buttons did not. so i pressed hard till it could recieve it and it did and now its fixed!
Posted on Mar 29, 2009
The best thing to do to get the water out is set your phone in a baggie or container full of dried rice. it doesnt matter what kind of rice either
Posted on Jan 18, 2009
  • 4 Answers
In worst case scenario, and you can still view your contacts, copy the non-responsive number from an old contact and dial from there.
Posted on Jan 28, 2009
Screen wont come on my galaxy s4
If your phone gets wet. Turn it off immediately and remove the battery. Let it dry out naturally for quite a long period. this can be aided by leaving the back of the case off and the battery out.
If an attempt is made to power the player on before it is dry, the probability is that it will short out inside and never work again.
There is a phone on the market that will work under water but I can't remember the make.
May 21, 2014 | Samsung Galaxy Player 4 8GB Android Tablet...
The screen on the inside of my gpsmap 76 got wet. how can i find out if the unit is still powering up so that i can download my waypoint to my p.c.
If it's still wet, don't do ANYTHING until it drys out.
May take a few days until it does. Putting in a warm, dry environment will help. Like on your dashboard on a warm day.
After you know it's dry, plug in and see what happens. Worst case it doesn't work because of a short or corrosion. Best case it works.
If there was a way to get the battery out that would be best. Then wait for it to dry out.
If it doesn't work you may have to send back to Garmin for repair. Or replace it. Good luck.
Jan 19, 2010 | Garmin GPSMAP 76 GPS Receiver
Wet Phone with Download screen
it may sound funny but put the phone, battery and nething else that got in a bag of dry rice. it will soak up any water left in the phone. that may fix your problem.
Sep 13, 2009 | Samsung Propel A767 Cell Phone
I got it wet, I immediately removed the battery and let it dry thoroughly. It turned back on but displays a screen I've never seen with the Verizon logo and a quaint message that says " LGVX8500 Downloader...
well i guess its late, but every time one of my phones got wet i would take the battery off and dry it with a hair blower. ( the ones that women use to dry their hair). trust me , it works. just dont put it too close or it would burn it.
Mar 26, 2009 | LG CHOCOLATE VX8500 Cellular Phone
Water damage
I had the same problem, so i kept taking the battery in and out and turning it on when the slider is down and after about 15 times it turned on but now the numbers dont work right like 4 is 1, 5 is 2 so post wat happens to yours
Dec 25, 2008 | Samsung SGH-a737 Cellular Phone
Got Wet = Blank Screen
I helped a friend with a similar problem using the solution below, so I am sure it will work unless your phone has shorted out:
  • Remove the battery from the phone immediately -- preferably right after it had gotten wet.
  • Spray the phone liberally through the keypad and inside the battery compartment with a good brand of electronic cleaner such as "CRC QD Electronic Cleaner Quick Drying Formula". It is important for the cleaner to get into the phone to wash out any water and mineral residues as they can cause a short when you put the batteries back into the phone.
  • Allow it to drain and dry, or better, blow dry it with hairdryer set on cold, or turn upside down on your dashboard for a few hours. Do NOT put the batteries back in the phone while it is drying.
  • When your phone is completely dry, put battery back in and turn it on. If it does not come on, put it on the charger. You should see the indicator come on showing "Charging".
  • After a few minutes to a half an hour, try turning your phone on. It should work if nothing has shorted.
Nov 22, 2008 | Nokia N95 Cellular Phone
Well i droped my phone in the water and now after drying it off it works but it says "Car Kit" on the main page of my phone.
Believe it or not the phone is still possibly wet inside and its a very small amount of moisture shorting across something which is causing this spurious reading on the screen. There are a few ways to dry it out thoroughly, but I have always found the best method is to leave the phone on top of a radiator on a low heat setting for a couple of days and that usually does the trick. Please do not try to dry it out quickly by leaving it on a hot radiator or damage will surely happen to the phone. Good luck.
Sep 27, 2008 | Lands Phones
I have an Telus LG 210 phone and got it wet, and when i turn it on all i get is the LG letters and the symbol beside it and the phone never starts up. It just keeps shutting off and turning back on at...
Normally the extent of the problem will depend on the amount of water seepage. I don't know the details of this particular phone but in general it is the moisture trapped under the keypad that can cause the problem. If you can open the keypad and run a hair dryer on low heat across for a few minutes that might help. It is also possilble the battery is discharged because of the drain of current due to water causing internal short circuits. Take out the battery, dry off the phone with hair dryer and put the battery in. Connect the charger and hope for the best. By the way I am not a phone technician.
Jul 27, 2008 | Lands Phones
It turns on but a blank white screen only shows
i had the same issue when my phone got slightly wet. try taking everything apart (sim card, battery, back). let them dry out for a little bit then after like a day or two put the phone back together. turn it on it will be a white screen for a little bit but give it like 2 or 3 mins and if should come back. I did this for my phone cuz i really needed the pictures off it and it worked! hopefully if will work for you too. GOOD LUCK!
Jul 16, 2008 | Nokia 6133 Cellular Phone
LG DLG 2524W gas dryer
call svc tech under warrenty, also sensor rellies on clothes touching two shiny strips to sense the dryness of the clothes ussaly in front or rear of drier drum or rather back or front wall inside wet clothes short the bars and stalls timer when they are dry does not short bars so sensor knows dryness by resistance of short tilt drier front or back where ever bars are to make shure clothes main tain contact lots of time this cures the promblem
Nov 18, 2007 | LG DLE2532W Electric Dryer
Samsung SGH-a737 Cellular Phone Logo
770 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
