Question about Samsung Digimax A503 Digital Camera
DISH WASHER, STILL HAS A LEAK FROM THE DOOR.
DISH WASHER HAD LEAK FROM DOOR... DID GET NEW GASKET FOR THE DOOR.... NOW STILL LEAKING.... WHAT ELSE COULD IT
BE???
THE DISHWASHER PEOPLE THAT I BOUGHT THE GASKET FROM,
JUST SAY'S WE WILL HAVE TO SEND A REPAIR PERSON OUT TO LOOK AT IT.. IS THEIR ANYTHING ELSE THAT I CAN DO. WITH OUT COSTING ME A ARM AND LEG???
IT IS A MAYTAG DISHWASHER,,, AND I SPEND $50. FOR THE GASKET...WORKS FINE EXCEPT FOR THE WATER LEAKING FROM THE DOOR...
  • 10,865 Answers
Once the gasket is in place, check it for fit against the door frame. It should fit tightly with no cracks or bulges between the gasket and the frame. If necessary, tighten or loosen the retaining screws, or refit the gasket in the clips or the door channel. Then run the machine through a washing sequence and check for leaks.
If you spot a leak, and the gasket seems to be properly in place, try adjusting the door latch. The trick is to position the gasket against the frame of the door without flattening the gasket or squeezing it too flat when the door is latched properly. Adjust the latch or the gasket until it fits snugly against the door frame.
Servicing the Door Latch
The latch on a dishwasher door is opened and closed repeatedly, and this hard use can lead to mechanical problems. The latch may be loose, or it may have slipped out of position, throwing the alignment off and preventing the door from closing properly. When this happens, the latch does not engage properly, and the dishwasher will not start.
In many cases, you may be able to solve the problem by adjusting the position of the latch. Move the latch slightly by loosening the screws that hold it. Slide the latch with your fingers or pliers; the screw slots are made especially for this purpose. Close and open the door to see whether the latch is properly aligned. Tighten the screws to hold it in the correct position.
After repositioning the latch, check to see if it's working properly. Close and latch the door and turn the control knob to the ON position. If the dishwasher doesn't start, the latch is faulty. Replace it with a new latch, connecting it the same way the old one was connected. You may have to move the new latch back and forth several times before it works properly.
PLEASE mark this answer as a fixya! thanks
Posted on Mar 14, 2009
  • Joe Hogan Mar 14, 2009
    Good luck. let me know how you make out.
Dishwasher leaks from the bottom of the door
Hi, if it is leaking around/under the door, it must be the seal around the door. Check to see if the seal needs to be pushed in somewhere or is damaged..
Try running the cycle with no dishes in the washer and see if it leaks, it sounds like a gasket in the door to me and you can also check hose by removing the front panel on floor and check there....
Inspect the door gasket. As it ages, the gasket can crack or become hard, preventing it from sealing completely.
If the gasket appears solid, adjust the door latch so the door seals tightly. Loosen the screw that holds the door latch to the cabinet. Push the latch in slightly and re tighten the screw. Test the door and readjust the latch if necessary.
Replace the gasket if water continues to leak after you've tightened the latch. Most gaskets are held by compression in a groove on the door or on the dishwasher cabinet.
Jun 26, 2011 | GE Nautilus 24" Built-in Dishwasher
Dishwasher keeps leaking from door
If the gasket appears solid, adjust the door latch so the door seals tightly. Loosen the screw that holds the door latch to the cabinet. Push the latch in slightly and retighten the screw. Test the door and readjust the latch if necessary.
Jun 22, 2011 | Bosch SHU9915UC Dishwasher
Kenmore model #16761691 leaking at the bottom of the door. Where is the gasket located? Or is it another problem?
does it leak all the time or did it just start?try running it with nothing in it and see if it leaks,if the dishes were racked wrong the water can get deflected and leak out through the door,also,remove the bottom rack,look at the screws going around the bottom part under the wash arm,if any of those are loose it causes a wave in the dish washer and the water leaks from under the door.if it's leaking from one of the corners the gasket could be bad
Apr 17, 2011 | Kenmore Dishwashers
Water leaks from door during last cycle
Sometimes residue builds up between the gasket ( rubber on the back of the door ) and the unit itself. With the door open clean the inside of the washer where the door touches it when closed, clean the gasket too.
When dishwashers aren't run frequently the gaskets can dryout and shrink, this creates a gap in the gasket and allows it to leak. New gaskets are available from your dishwasher manufacturer.
Dec 30, 2010 | Estate 24 in. TUD6700KQ / TUD6700KT /...
Leak at the bottom right hand corner of the dishwasher, I cleaned the gaskets, checked the door latch, checked the levelness, & the door hinge. Ran it thru the cycle & still leaks. How do you...
The gasket should pull rigth out. For the old gasket you can pull out with pliers. Once the first part is removed the rest is easier. Replace with similar one. Insert new gasket fully in groove. Remember that the first time the gasket will leak because it needs to expand. Also if you haven't used washer in a while it will leak becasue the gasket contracted.
Also with the power off check for water leaks at the inlet and outlet hoses and where it connects with the washer. Take a flashlight and dry finger and trace the water back to its source as muchs as possible.
Aug 17, 2010 | Frigidaire GLTF2940ES Front Load Washer
Kitchenaid dish washer kuds24sewh4 door leaks but does not seam to be gasket ! water drips from inside of door bottom? possibly rinse aid leaking in door?
remove the inner door panel and ck for leakage . there should be water tracks . / there is a bottom seal. that may be failing / ch to see if its in proper possion .. its on the tank under the door / open the door all the way and look from inside to see. ( with a light .. mm
Dec 12, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
I have water leaking from bottom of dishwasher motor area..the dishwasher started making a whinning sound and then washer cycle would'nt work. it happened after i discovered a broken glass in washer.
Hi
Thanks for using FixYa. If you have nuisance water leaks around the base of your dishwasher, you may be using a detergent that is causing too much suds. Cut back on the amount of detergent you use, and see if that makes a difference.
Water that spills through the door vent is usually caused by improperly loading dishes. Leaks from the door itself may be caused by a faulty door gasket or door tightness adjustment. You should check the main tub seal, the door latch, the door gasket, the water-inlet valve, and the fill and drain hoses.
Also make sure the dishwasher is sitting level (you can adjust the front feet up or down, and many units have some type of levelers at the rear).
Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repairperson.
An older dishwasher may corrode at the bottom, but this is fairly uncommon. If this is the case with your dishwasher, it's time for a new one.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Dec 08, 2009 | Amana 24 in. ADB2200AW Built-In Dishwasher
My Maytag washer leaks at the door. It doesn't
f you have nuisance water leaks around the base of your dishwasher, you may be using a detergent that is sudsing too much. Cut back on the amount of detergent you use, and see if that makes a difference.
Rate the solution..
Jul 10, 2009 | Maytag 24 in. MDB5600A Jetclean II...
When starting dish washer water comes out at bottom of door about in the middle
You don't list the manufacturer or model number, not its approximate age but there are generally two things that need to be repaired or adjusted when you have a leak.
1.) The door gasket
2.) The door latch ... but if after you close the door and it latches, if it appears to lock tight, replace the gasket.
Good Luck! Please post back here what you find and decide to do, OK?
Apr 17, 2009 | Dishwashers
Ldf8812st lg dishwasher leaking from front door
Thank you for the update. The retrofit kit will probably not only fix your leak but also dry your dishes much better.
I hope the info I provided was useful. Can you take a moment to rate my level of helpfulness?
Mar 31, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Samsung Digimax A503 Digital Camera Logo
243 people viewed this question
Top Samsung Cameras Experts
Computer Links
Jerry Z
Are you a Samsung Camera Expert? Answer questions, earn points and help others
