Question about Goodman GMS90703BXA Heater
HEATER NEVER SHUTS OFF
I REPLACED THE THERMOSTAT, BUT MY HEAR NEVER SHUTS OF I HAVE AN OLD A36-20 MODEL.
ALSO IT ONLY BLOWS OUT LUKE WARM AIR.
  • 1,420 Answers
Check your thermostat wires. They may have a short in them.
Posted on Jan 02, 2009
My furnace come on and blows luke warm air but will not blows hot
You need to check the flame sensor. There is a wire that tells the unit when the burner is on. The burner may be coming on and then gets warm and shuts off, then the fan comes on. It could also be the upper limit temp thermostat that is tripping but since you did not post the make and model, it is hard to say
Dec 17, 2017 | Cars & Trucks
Heater temp on high only bows luke warm air after driving. A/C works just fine.Plenty of cold air from it
heater blows cold air idle chrysler 300 Questions & Answers ...
www.fixya.com > Forum > Tags
Find solutions to your heater blows cold air idle chrysler 300 question. ... blow warmair for a few mins then back to luke warm. i replaced thermostat ... HEAT BLOWSCOLD AIR WHEN IDLING ONLY GETS HOT WHEN START DRIVING ... About 15 minutes after driving the diver side vents start blowing straight cold air but the ...
Heater only works when pressing the gas? - DoItYourself.com ...
www.doityourself.com/...repairs.../459521-heater-only-works-when-pres...
Nov 3, 2011 - When I press the gas, the air from the vents is nice and hot. .... So am Idriving a car with a ton of problems, or could the power steering ... Just anotherquestion, when warmed up does the engine temperature ... When the heater is on and I'm not pressing the gas pedal, luke warm air blows from the vents.
Heater blows cool air when stopped and warm air while ...
https://www.reddit.com/.../heater_blows_cool_air_when_stopped_...
RedditFeb 12, 2014 - Heater blows cool air when stopped and warm air while driving 2008 Kia Spectra (self. ... just fine but appears to blow cool air when I was stopped at a stoplight. ... My temp gauge would also be pegged high when at idle / low RPM. ...thermostat only blocks coolant going to the radiator, and the heater core, ...Missing: 300m ‎luke
Why is My Car AC Blowing Hot Air? - BlueDevil Products
gobdp.com/blog/car-ac-blowing-hot-air/
Jan 27, 2016 | 2000 Chrysler 300M
Heater not working ?
There could be more than 1 thing wrong, I assume the fan works because the A/C blows cold, as for the heater is it blowing luke warm or nothing at all. If the thermostat was removed and left out you would have luke warm air because the water that circulates through the heater is not getting hot if this is the case replace the thermostat with the correct one, another issue would be the heating element under your dash has no power to it or the element has deterioated.
Dec 19, 2015 | 2005 Chrysler PT Cruiser
My heater blows only luke warm air. I have replaced the thermostat and flushed the systme
If both heater hoses are getting hot, it could be a blend door problem.
Dec 01, 2015 | 1998 Jeep Wrangler
Heater blows luke warm air, both front pannel and rear.
do you hear a clicking sound under your dash if so the blend door accuator is bad and not switching all the way over for the heat or cold
Jan 03, 2012 | 2000 Ford Expedition
"78 Chevy Scottsdale 4x4 400 small block. I
You may have a heater valve that is on one of your heater core hoses may be bad.
Dec 13, 2010 | 1978 Chevrolet C1500
Car heater blows cold/luke warm air. Gauge only gets quarter warm.
is it where gage always has been? If lower, you need a thermostat. If same, you may have air tapped in heater system. fill degas bottle/reservoir and run engine with cap loose on degas bottle until air is purged.
Jan 13, 2010 | Ford Focus Cars & Trucks
The heater only blows luke warm air. Just replaced the water pump and thermostat. Hot water on one heater hose, cool on the other. Both front and rear.
Hello...
One of 3 things could cause this, that I know. The thermostat has been installed backwards. The water pump broke soon after install. Due to it being a rebuilt one. And a small clog in the heater core. All of these things are easy to fix.
Good Luck...
Dec 13, 2009 | 2000 Ford Expedition
Heater blows cold air ,at idle and blower motor off,if you wait a couple of min and turn on blower it will blow warm air for a few mins then back to luke warm. i replaced thermostat did not help
the heater control valve is not opening all the way.
look under the hood on one on the heater hoses .
you should find a vaccum controled heater hose valve.
make sure your not low on coolant also.
also make sure none of the heater hoses are pinched off.
Nov 25, 2009 | 2000 Chrysler Sebring
Goodman GMS90703BXA Heater Logo
133 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
