Question about Canon i860 InkJet Photo Printer
Can't get anything to print
I haven't used this printer in probably about 18 months and it's been sitting in a closet the whole time. It used to work just fine, but now I can't get anything to print on it. I know my ink is low, but it's not telling me that that is a problem, and it doesn't even try to print (i.e. pull in the paper or make the usual pre-printing noise) it's like it's not receiving the jobs that I send and the printer queue just says there's an error and it didn't print Any suggestions?
  • Anonymous Jan 25, 2009
    My Canon printer green light is on, I hear the noise that something is happening, but the paper comes out blank it does not print what I want it to print, email or doucsuments. Help.l
  • redstarnw Feb 11, 2009
    I'm having the same problem as the person who wrote in January 2009. Nothing prints at all, and I've followed all the steps (aligning print head, deep cleaning, reseating inks). Whatever I print (file, web page) comes out blank. I've even removed the print head to clean it. Do I need a new print head? Isn't that too expensive to warrant trying to fix the problem? Should I just recycle the printer and start with a new one?
  • 837 Answers
Try uninstalling and reinstalling the printer drivers first and go through those steps .. then try printing .. It sounds like you have a "connection" problem .. Possible cable and or port (i.e. USB / parallel)
Posted on Dec 26, 2008
I bought a 55 burn STV 18 months ago and it is still sitting as a wall decoration, I cannot get anything on the TV working except no signal.
do you have an antenna connected up
are the antenna wires circuit correct
why waste 18 months of a warranty if it didn't work for all of that time
Sep 10, 2017 | Televison & Video
Epson WF 7010 sitting for several months -- wont print black -- colors ok -- print did a firmware update whne put back in service
Inkjet cartridges dry out and fail when printers sit unused for extended periods of time. The black ink cartridge is probably no longer usable. Updating firmware won't have any effect on the issue.
Dec 31, 2014 | Epson Office Equipment & Supplies
Print jobs stuck in cue
Click on Start button
Click on Run
Type SERVICES.MSC and click ok
look for Print Spooler in the list
highlight Print Spooler,
Click on STOP button then click on START
close the window and check if the print queue is gone.
Alternate method,
Click STart
Click RUN
Type Cmd ( or COMMAND ) and hit enter
In the black window type
NET STOP SPOOLER ( hit enter button )
NET START SPOOLER ( hit enter button )
Repeat the Stop and START Command 4-5 times
End the Command with NET START SPOOLER
Open Printers and faxes folder - Refresh the Window - the printer will show Status ready with 0 document
Jun 25, 2010 | HP LaserJet 8500 Color Printer
Will not print black at all
Probably needs to be cleaned the black is usually the worst for this. see if you can get to the bottom of where you put the cartridges in and use a little rubbing alcohol adn a Q-tip to get the build up off the jets it won't hurt anything as long as you don't break anything. It may take a bit to get all the gunk, it can be very messy there. hope this helps
Jun 17, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Having to clean ink cartridges before use
your cartridge is drying very fast if it is hardware ptoblem it means that cartridge parking is missing one of its part.
1. when your printer is off or it not in use their is a printer part of small rubber for covering your cartridge head in your printes cartridge parking thar rubber part is missin in your printer .
you may find it in side your printer it self.
Jun 11, 2008 | HP OfficeJet 6210 All-In-One InkJet...
No Yellow will print
If you haven't used it for a long time the ink may have dried up. You can try taking out the cartridge and letting it sit on an hot wet rag for a while to unclog the print heads. Try not to touch the copper contacts on the cartridge. If that doesn't work you may be out of yellow ink.
Apr 23, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Black ink not printing
This is what worked (so far) with my Dell1.gif AIO A940 printer1.gif that wouldn't print black ink.
It worked for awhile when I chose photo/glossy paper, but then it quit printing again (see below).
I got it to print, again, by putting SEVERAL papers in the feeder (instead of just 1) - there is a sensor that is supposed to automatically detect paper type, and it might not be working right, especially with one or only a couple of sheets.
Nov 09, 2007 | Brother DCP-340CW All-In-One InkJet...
Samsung LaserJet prints completely black pages
We had the same problem with our SCX but we replaced the Part #: SCX-4521D3 toner/drum and it worked fine after that. We replaced the starter cartridge with a 3000 print capacity cartridge.
Nov 20, 2006 | Samsung SCX 4521F All-In-One Laser Printer
HP inkjet 1100 not printing yellow
Well if you want to damage your printer use alcohol. But if you want to make it work then pull the cartridge from the printer and run hot water on a couple of paper towels leaving alot of hot water in the towels. Put some thing under them to keep them from staining your counter top and then set the cartridge down onto the hotwater towel and let the hot water melt away the dry ink and in minutes you may be printing again if this is what it is. Be sure and use a dry paper towel to wipe off the ecess wet before you reinstall the cartridge.
Nov 15, 2006 | HP LaserJet 1100 Printer
Black Printing
Possibly the printer head needs replacing. That's the actual black 'box' the inks fit in. I've generally found they last no longer than about 18 months. You can try cleaning the contacts with an alcohol pad before forking out the $50 odd dollars it costs for a new head. If you have some time on your hands you could also try reinstalling the drivers - Good luck
May 03, 2006 | Canon i 450 InkJet Printer
Canon i860 InkJet Photo Printer Logo
44 people viewed this question
old marine
old marine
