If your Grundig tumble dryer is taking a long time to dry clothes and not getting as hot as it used to, there are a few things you can check:
Clean the lint filter: A clogged lint filter can prevent proper airflow and cause the dryer to take longer to dry clothes. Make sure to clean the filter before every load.
Check the vent hose: Make sure the vent hose is not kinked or clogged. A blocked vent hose can also cause the dryer to take longer to dry clothes.
Check the heating element: A faulty heating element can cause the dryer to not get as hot as it should. You can test the element with a multimeter to see if it is working properly.
Check the thermostat: A faulty thermostat can also prevent the dryer from getting hot enough. You can test the thermostat with a multimeter to see if it is working properly.
If you have checked all of the above and the issue persists, it may be best to contact a professional appliance repair technician for further diagnosis and repair.
One basic reason is your washer could NOT be spinning most of the water out, therefore your clothes are wetter than they should be, thus taking longer to dry:-)
If this is a vented dryer then check all the filters in the machine also check the vent hose is not blocked on the machine in the hose itself and where the pipe goes out of the wall.If it is a condenser dryer the filters need checking and the condenser box in the base of the machine.If none of this is successful then it could be a fault with the heater or the programmer.
Check to see that the lint filter and exhaust duct are clear all the way to the outlet. If the moist hot air is not being exhausted the clothes will not dry. If the vent path is clear and you are using auto-dry the sensor may be at fault.
Make sure that the filter and filter compartment are clear/clean, and then locate where the pipe exits the wall. They usually clog right at the vent exit, especially when they have the mesh covering and not a louver.
It is possible that the pipe itself is clogged as well.
This not only prevents proper drying, but is a fire hazzard and can cause problems with the dryer.
It "should" be a problem that the apartment maintenance crew will take care of free of charge.
You definitely have an air flow issue. Let's do some tests to see if we can pinpoint the cause. Step 1: Remove any clothes and the lint filter.Inspect blower housing inlet below the filter to see if there are any restrictions or obstructions. If OK, proceed to >Step 2: Replace lint filter only and remove the vent to the outside from the rear of the dryer. Put an old nylon stocking over the vent coming out of the dryer, and do a load of clothes. If dryer works fine, your vent to the outside is at fault and needs to be corrected. If not certain, proceed to>Step3: Remove the nylon stocking. With the dryer set on air fluff, do an air flow test comparison with and without the filter in place. I use a Kleenex and gently stretch it across/over the dryer vent tube, Have someone turn the dryer on and see if it is strong enough to rip the Kleenex. If no filter in and Kleenex rips and with filter in doesn't, then your filter is at fault This may not be definitive enough to evaluate for certain, and only needs to be done after the nylon test fails. After performing these tests, let me know if my advice helped resolve this issue by rating my answer.
If you need more assistance, suspend your rating, and post me back and I will be happy to assist.
