THE DISPLAY WRAPS OFF THE EDGES OF THE SCREEN AN I CANNOT ACCESS THE VERTICAL SHIFT
    President:
  • 2,110 Answers
Right click on desktop>property>setting>Advanced> try to change the screen resolution...
Posted on Dec 26, 2008
  • 10,594 Answers
Replace monitor and check display is OK now?
If yes, monitor is defective.
  • 15,935 Answers
The menu of the screen will allow you to re-size vertical and Horiz. There is no way in wondows to re-size.
  • blueextc3221
    blueextc3221 Dec 26, 2008
    even a smaller resolution will result in the same offset you are currently experiencing. Click the menu button on your monitor, and look for horizontal and vertical position. Then adjust accordingly.
  • 13,433 Answers
Please clarify the problem, try using the on screen controls to adjust the screen position, try another screen resolution. what kind of monitor you have?
My computer screen is smaller then the monitor. There is about an inch of black surrounding the screen. It was displaying fine yesterday with my current set up but i had to do the factory restore thing and...
First make sure dispplay screen resolution is set to 1024*768 .
For that go to start ->control panel->display->setings set screen resolution to 1024*768 then apply .
If it is already set to 1024*768 then press menu button of monitor and increase horizontal and vertical position also put the picture in center first then increase both H and V position then it will give good display.
Also make sure display driver installed and working fine.
Let me know if you need further assistance.
Thanks for using FixYa.
Jul 03, 2010 | Computers & Internet
Hi, I am having a problem with my TH-37PW5 TV. Close to the middle of the screen, there is quarter-inch thick black vertical line, which prevents normal viewing experience. I am quite familiar with...
If the line is straight with sharp edges and extends from top to bottom, then the connector for the display itself has probably been damaged / deteriorated. You might be able to take it to a service shop and let them work their magic. Recommend professional service on this one....
If the black line is "shadowing" with fuzzy edges, it is known as a bruise, and is result of damage to the LCD itself and is unrepairable other than LCD replacement.
Jun 13, 2010 | Televison & Video
Resolution is different from usual, but same in system prefs
you are using an extended monitor just set the display to one monitor and set the right resolution
Apr 08, 2017 | Apple Cinema HD 30" LCD Monitor
The display on my C70 will suddenly go to a series of vertical lines. Sometimes light finger pressure on the display will cure it. What is the permamant solution
I recognize the problem. It mostly occurs when the plotter is exposed to moist during some days. The contactstrip which connects the computer to the screen gets moist and does not conduct in an optimal way. The result is a non readable screen with stripes
The solution is simple: press on the edges of the screen and the contact is re-established.
Nov 19, 2009 | Raymarine C70 GPS Receiver
The display of the C70 has stopped working. Instead of a picture it only shows either vertical bands of color or just black/white vertical/horizontal lines. Occasionally the display comes back but only for...
Jul 18, 2009 | Raymarine C70 GPS Receiver
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
IBM Thinkpad 2652 has horizontal and vertical gridlines on screen
Try to remove your Memory modules and clean the contacts with a pencil eraser. Makes sure to clean both sides of the memory contacts.
Nov 21, 2008 | IBM ThinkPad A31 Notebook
White lines accross top of screen on our 27 inch Toshiba,
lcd or plasma.
are the lines solid or blurred. do they have sharp edges.
You may have a memory problem with the display which can only be repaired by factory trained technicians, or a brave soul willing to find parts on ebay.
May 02, 2008 | Toshiba MW27FP1 27 in. TV/VCR/DVD Combo
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
