From the Wii main menu, use the Wii Remote to select the "Wii" button.
Now, select "Wii Settings" to access the "Wii System Settings" menu.
Using the arrow on the right side of the screen, scroll to page two and select "Internet."
Select "Connection Settings."
Select "Connection 1: None"
(Don't see "None" in Connection 1? Click the Connection 1 button, then choose "Clear Settings.")
Click on "Wireless Connection" and then "Search for an Access Point."
Select "OK" and the Wii will display all the wireless networks it finds.
Select the wireless network that is yours.
Asked to enter a security key?
If you are prompted to "Enter the Password or Key," then the wireless
network you are trying to connect to has wireless security turned on.
You will need to type in your security key or password and select "OK."
- Select "OK," "Save Settings," and then "Yes."
- The Wii console will run a connection test with your wireless network.
- As long as you see "The connection test was successful," the "Wii Support Code" does not matter and can be ignored.
- The connection test was successful -
Then you're almost done! After your connection test, the Wii console
will check if there is a new Wii System Update available. Once you
select "Yes" and "I Accept," the Wii will begin to download any
available updates.
- The connection test was not successful - If the test was not successful, you will receive an error code.
- Error Code 51330: This means the security
code you entered into the Wii is not the same one your router is set to.
Look in your router's settings and try again.
For detailed step by step instructions with pictures use this link:
http://www.nintendo.com/consumer/systems/wii/en_na/netflix.jsp?menu=watch&submenu=rvl-ht-sys-internet-connect
Is it your router? What make/model is the wireless router?
Common defaults are : username : admin
password : admin
