Question about All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater
Fan turns on starts blowing and a lot of smoke.
I have a 150,000.00 BTU all pro heater. I have changed the fuel replaced all the fuel line's and every time I turn it on it start's to smoke and then pop's the overload it is about three years old. In reading all sort's of problem's I noted to clean the igniter did that still does not work properly. Please Help.
Thnak You, Jim in California.
When you start it the smoke starts wright away it is not getting the right air flow takethe top part off and started see what it does if it stays running try to ajst. the fens ok .
Posted on Dec 30, 2008
Reddy Heater kerosene 110,000 btu . plup it in, fan runs, blows smoke out the front, leaks kerosene also from front, i have cleaned photo cell, replaced plug, cleaned filter and checked lines for cracks,...
Just because there is fuel & spark does not necessarily mean there will be combustion. The fuel must be delivered at the correct pressure, the correct volume, and must be delivered as a fog- not a mist.
My suggestions:
  1. set the pump pressure
  2. be sure the fuel filter is clean
  3. be sure no air leaks or vacuum leaks
  4. Desa recommended annual replacement of the nozzle. They wear out. When was the last time yours was changed?
More troubleshooting tips
Oct 20, 2011 | Reddy Heater-30-55,000 BTU Variable
I have a knipco portable space heater 150,000 BTU. It runs a couple minutes and shuts off and blows smoke.
Check the air line and the fuel line. Look for cracks in the lines. Also check where the air line connects to the fan motor and fuel nozzle and the where the fuel line connects to the filter and the fuel nozzle. You need it to fit tight. If it is stretched out trim some from the ends and put them back on. This will help them fit tighter. Also check the fuel filter. If this doesn't help let me know and if it does don't forget to rate the answer.
nitensheaterservice@earthlink.net
Jan 10, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
Have 30,000 btu Dayton heater m#3e3665 when reaches temp. fan
Hi blow heater out with air line flame sensor could be dirty check out pressure switch jump this out see if it lights
Feb 09, 2010 | Dayton (3E379) Heater
Pro 110, runs 10 min., blows white smoke ,shuts off
the first thing you need to do is go back to useing K1 kerosene, diesel fuel not only burns dirty but also has a tendency to gel up in cold weather which could be makeing it hard for the heater to draw the proper amount of fuel. To reset the pressure you will need a gage, it should run at about 6-7 psi. you can order a pressure gage from mr. heater online, they are by far the cheapest I have found as they are the actual manufacturer or call 1-800-251-0001
Feb 05, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Dayton Salamander Heater - Blowing Unburnt Fuel/Smoke Randomly
I have seen this before, you need to replace the nozzle.
Feb 01, 2009 | Dayton (3E386) Heater
Won't ignite and fill the entire tube with flame, cold air, smoke
The deisel fuel hogged it up. Clean everything out and replace the wick. Deisel fuel is filthy to burn and it needs a lot of airflow.
Jan 16, 2009 | Reddy Heater-40,000 BTU Kerosene w/T'stat
THE HEATER STARTS THEB BLOWS ALOT OF SMOKE
There are any number possibilities for intermittent running.
1. Bad ground connection at the Ignition Device (transformer, spark box)
2. restricted fuel filter causing fuel starvation
3. crack in the plastic end cover
4. crack in the airline
5. crack in the fuel line
6. crack in the nozzle adapter
7. water in the fuel
8. Others I’m sure I left out
You must be the one to troubleshoot & find the cause.
Follow these troubleshooting tips
Dec 21, 2008 | Reddy Heating & Cooling
Fumes
One of two things, a high heat limit control or the flame sensor, also check your air line that runs to the heater nozzle could be cracked, not enoughair to fuel mix will make it burn dirty.
Dec 14, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Blows cloud of smoke
thin your fuel mix with about a gallon of kerosene to 5 gallon of heating oil.could also be a semi clogged fuel line filter.
Nov 21, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Ready hater 110,000 btu
replace the nozzle and check the fuel filter - if this is a kerosene heater. under the access plate is a round filter - remove it completely or change it.
Dec 18, 2007 | Reddy Heater-30-55,000 BTU Variable
All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater Logo
370 people viewed this question
Top All-Pro Heating & Cooling Experts
Paul Carew
Craig Butler
Craig Butler
john h
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
