Question about SanDisk Sansa e260 MP3 Player
The system is running very slow
Hi, i had my Sansa for a week and it was wonderful, but suddenly one day changing songs was taking a long time, and so geting back to songs menu, and even turn it on. Some said it was because low batt, but i left it recharging a whole day on my desktop but the behavior was the same. Anyone who can help me.
  • luis valencia
    luis valencia Apr 23, 2007
    I tried these two solutions, but the first one did not work, and the second one, it doesnt enters recovery mode, i tried many ways, but the display remains black but the wheel on.
    I read something call 'manufactures mode', but it said its a very dangerous procedure.
    What else can i do for my poor Sansa, i feel a little disapointed because i just enjoy it for a week.
    Thanks for your help.
Aise kar apni gand mein CHAADALEY bosdiki or charger ko apni maa ki gand mein daal le hen ki lodi problem solved.....I m AKON Bhaen ka loda..
Posted on Aug 23, 2009
I have A sansa e250 and i am have downloaded the converter but after a couple of months it is talking so long and then after it does finish my videos do not so up on my sansa and i have tred redownloading the software
HELP!
Posted on Mar 28, 2008
Hello, thanks for your info. But now my Sansa has totally crash, it doesnt start at all, when i press power button it turns on the blue circle but nothing futher than that. And i unable to see it as a removable device, i already try to remove the battery, but stays the same. What can i do now? It is dead? Help please!!
Posted on Apr 23, 2007
    Scholar:
  • 47 Answers
Hi. Normally the symptoms you described would be due to using an expandable memory card (a 2GB microSD, for example)and have loaded too many songs. Another possibility is that your Sansa E260 may be encountering corruptions in its internal/external memory. One solution would be to perform a "Low Level" format on the player under MSC mode, thus, eliminating any corruption on the player. To do so, please switch the player's mode to MSC. Under this mode, your player would function as a normal media storage device (like a flash drive). Just a reminder: Formatting would delete all of the files on your Sansa E260. You may want to make back-up copies of important files on your player before you proceed to the solution below. Here's how to perform a "Low Level" format: Step 1: Plug your player to your PC (Just a reminder, your player's minimum Operating System requirement is Windows XP and above). Windows XP would identify your player as a "Removable Drive". Step 2: On your desktop, please single right-click on the "My Computer" icon and select "Manage" from the pop-up menu list. This would open the "Computer Management" window. Step 3: On the left pane on the "Computer Management" window, single left-click on "Disk Management" (this is located on the middle section of the list, under "Storage"). Step 4: Look at the topmost portion of the right pane. This would give you a list of drives, one which would correspond to your Sansa E260. On the icon pertaining to your Sansa E260, please right-click on it and select "Format" on the pop-up menu list. This would display the "Format" window. Step 5: On the "Format" window, please make sure that the File System type is FAT32, and also make sure that the "Quick Format" checkbox -- found on the bottom section of that windows -- remains unchecked. Click "Start" to begin formatting the player. Step 6: Re-transfer all your music files to the player. The most preferred method is to use Windows Media Player 10 or 11 to transfer the files to your player. Another method would be to "copy and paste" or "drag and drop" the files as long as they aren't subscription music files I hope this helps resolve the "lag time" you're encountering. I just love the Sansa E260! Syd.
Posted on Apr 21, 2007
  • Sydney Reinstine
    Sydney Reinstine Apr 23, 2007
    There might still be way to revive your player. Let's try to "Soft Reset" your player and upgrade its firmware.
    To "Soft Reset" your player, make sure that your player's scroll wheel light is on.
    Press and hold the "Menu" button until the scroll wheel light turns off (this might take 20-30 seconds or more), then try to turn it back on.
    Having your player stuck with the scroll wheel light being turned on might have drained the battery, so try to charge it for at least 1-2 hours.
    If this does revive your player, then setting your player to "Recovery Mode" and upgrading its firmware might help.
    Switch your Sansa E260 to its Recovery Mode:
    1. Make sure the player is powered off
    2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface
    3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button.
    4. keep your fingers pressed on these 2 buttons until the E260 LCD screen displays "Welcome to Recovery Mode"
    5. Connect your E260 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above)
    6. Double-click on "My Computer" and you would see your Sansa E260 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6.
    Next, Apply the firmware for the E260 (your player should be connected to your PC at this time):
    Step 1:
    Use this link to download the firmware for your Sansa E260 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downl...
    Step 2:
    Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred which caused the error in the first place.
    Step 3:
    When the process is complete, unplug your E260 from your computer, and please make sure you disable the "Hold" switch
    Step 4:
    Power up your E260 and 90-99% of the time, it would boot up successfully.
    Step 5:
    Enjoy using your Sansa E260, just like I do. (I love this player)
  • Sydney Reinstine
    Sydney Reinstine Apr 25, 2007
    Try to "Soft Reset" your player, press and hold the "Menu" button until the scroll wheel light turns off.
    Then, you would need to re-charge the player before proceeding further. Charge it for at least 2-3 hours. Try to turn it on then.
    Next, try to format the player to rid of any corruption then re-transfer some songs.
    For better results, perform the firmware re-flash procedure outlined aboved
SOURCE:
Apple tech said to contact arris, modam not working/slow speed 2.0 mbps! help
hi Jim.
Check your modem speed
  1. Open up a web browser such as Internet Explorer, Firefox, Chrome, Safari, etc.).
  2. Type http://192.168.0.1* in the address bar, and hit Enter.
  3. Select Modem Status and locate the rate (downstream/download or upstream/upload). If you don't see Modem Status, troubleshoot as if your speed test is less than 100%.
  4. Compare your results to the Internet speed which you subscribe. If the modem speed test shows your speed is slower than the speed to which you subscribe, you can explore these articles for further troubleshooting:
  5. Note: Your speed can be affected by changes in network traffic and usage, which will usually vary across days and the time of day. To get the most accurate reading, run the speed test more than once, including different times of the day and different days of the week.
  6. or go to this link.
Why Is My Internet Suddenly So Slow
or this one.
modem not working slow speed 2 0 mbps Google Search
Nov 27, 2017 | Apple Computers & Internet
I can't drag and drop music from my library to the sansa clip. I have downloaded songs using Rhapsody and I can see where my device is but it wont allow me to drag my songs to it... I have purchased the...
Account Status
You need to connect to Rhapsody once every 30 days to continue playing your subscription tracks. When you reconnect, the 30 day license is renewed. The indicator will change from full circle to a quarter cycle as the days pass, and you will be warned when your tracks are about to expire.
Rate This Song
1. In playback mode, press the Submenu button.
2. Select Rate This Song.
3. Press |<< or >>| to change the rating (Negative to 5 Stars)
4. Select Negative to ban this track from playing again.
Purchase
2. Select Purchase This Song.
3. When you connect the player to Rhapsody To Go, the track will be added to your Purchase Bin. You can decide if you would like to purchase it at your leisure.
Add To Library
2. Select Add Track to Library
3. A confirmation message, "Song has been added to your Library". Your song will now be a part of your device Library.
Artist Info
To display the artist information, press the center button 2 times when the song is playing back.
Account Info
1. From the Main Menu, select Settings.
2. Select Account Info.
Feb 26, 2010 | SanDisk Sansa Clip MP3 Player
My playlists from sansa m250 disappeared but when i connected ..
When transfering the songs from computer to player. First, sync device before transfering. Only do this the very first time. If you try to sync with songs already on the player, they will be erased.
To test the device. Open your comuters music file folder, keep folder open, than go to start menu, go to my computer and open the folder (D: or F: folder) It will have your player listed there.
Now with both folders open, take a song from the music folder, drag it to the sansa folder and drop it in there. It should be added to player.
May 05, 2009 | SanDisk Sansa m250 MP3 Player
Try to listen to songs on my Mp3 player (sansa c240) it no wrk
You have to connect the mp3 player to the computer and refresh your device through Bearshare - their songs have fixed licenses, which require you to refresh every 30 days or less.
-Tha Mp3 Doctor
Nov 17, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Player shuts itself off
There could be a damage or corrupted file in the sansa clip. I suggest to reformat the player. To reformat the player. First turn off the player. Then slide the power switch down it will be showing red, now press and hold the center or the middle button on the player while connecting the player to the computer. It will be detected as a drive on your computer, now right click on it and choose FORMAT, make sure the file system is FAT32 then click start to continue formatting the player. This will erase or remove all the songs on your player but this will fix the problem that you are having
Aug 22, 2008 | SanDisk Sansa Clip MP3 Player
Downlode sandisk model m230
My Sansa e250 never pass to the next song since 3 days. I must change each song by menu.
May 29, 2008 | SanDisk Sansa m230 MP3 Player
Sansa disk e 260
I had the same problem with mine freezing. It happened when I kept pressing the back track button (on left side) to go back to an earlier song. It then froze in the middle of a song, couldn't hear the song, the time of the song was frozen, etc., and the unit stayed lit, despite pressing all the buttons. I tried holding down power but nothing happened. I read another person's post that you need to hold it down 15-30 seconds. I did this and it worked, you just have to hold it down until it shuts down, which was about 15 seconds as suggested, could be longer for others.
For me, next time I wont keep clicking the tracks repeatedly, I'll simply go out of the song and back to the song I want through the menu.
Thank you for the good posts. Glad I didn't have to mess with the battery like others....
May 14, 2008 | SanDisk Sansa e260 MP3 Player
Sansa c250 freezes while refreshing database
I got my c250 to turn off while frozen by holding the "menu" and "select" buttons down at the same time for a few seconds.
Jan 21, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa shaker files write-protected
SHAKER ONLY TAKES MP3 FORMAT!!!!!
Use this site to change your format to the correct one for the sansa shaker. This is the only way to load songs from your cds MWA will not work at all. Must convert all files to MWA use site below
http://www.wma-mp3.org/
Dec 10, 2007 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
"unknown" songs taking up memory in my sansa e200
Renew music svc sub, convert to Mp3, or update/remove DRM licensing
Nov 25, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
413 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
