Question about Sony PlayStation Portable (PSP) Console
Loud Clicking noise and won't read UMD
K my PSP hasn't been working, when i put in a UMD all it does is just make these loud clicking noises, i even tried changing the UMD. I'm not sure if I its hardware or something technical wrong with it. Please help me.
  • 1 more comment
  • i_am_eric_12 Dec 26, 2008
    no its not the problem i tried using different UMD's and it still makes the same loud noise... but thanks for the help anyway
  • zaigo Dec 26, 2008
    same happens with me and especially annoying as it is just few days after christmas so i cant play any of my new games :( i tried moving the laser and it seemed to work for like 5 seconds then it moves back to the same spot
  • i_am_eric_12 Dec 27, 2008
    K i moved the laser thing to the right which made the clicking noise stop, but it still doesnt read them.
  • 709 Answers
I think the it is possible your UMD case is cracked and the clear part is pressing down on the disc inside. Check and pull the clear part of the case from the media disc.
Posted on Dec 26, 2008
  • Greg Stokes
    Greg Stokes Dec 26, 2008
    Reach inside the UMD door and manually move the laser to the right a couple of clicks. This may get it back on track
  • Greg Stokes
    Greg Stokes Dec 27, 2008
    Well, It looks like you need a new UMD drive. I have had to replace many of these, they do go bad. It is important to use Sony if you are under warranty. You can call them at 1800 354-7669. Otherwise, my shop, can replace these for very reasonable price with quick turn around. The PSP requires near complete disassembly when replacing the UMD drive.
Cannot start loud fast clicking noise
Clicking noise would indicate starter solenoid faulty! This would also be the case if battery low but since you have a new battery you can look at the starter solenoid!
Aug 22, 2015 | Cars & Trucks
My son psp beep when you put a game in and the umd does not come up can you help please
f you are experiencing issues when using a Universal Media Disc (UMD™) on the PSP system, try these troubleshooting options:
  • Issues with PlayStation®Store content Click here for help with content purchased from the PlayStation Store.
  • Restore Default Settings Restore Default settings will default the PSP system to its original settings. A setting change may be the reason the PSP system is having difficulties. Click here to learn how to restore default settings on the PSPgo / PSP system.
  • Confirm UMD is properly inserted
    Make sure the UMD is properly inserted with the label facing the back of the PSP system. Try removing the UMD and reinserting it.
    Please note, it is normal for the PSP system to make noises while it is reading from a UMD.
    For PSP-1001, slide the latch to open the UMD door. For the PSP-2001 and PSP-3001, simply lift the door open.
  • Try playing the UMD on a different PSP system If possible, try playing the UMD on a different PSP system. If the disc still does not function properly, it might need to be replaced. If the disc does function properly, the PSP system may need service, see PSP Service for details.
  • Try playing a different UMD on the PSP system If possible, try playing a different UMD on the PSP system. If another UMD plays, the original UMD may be the problem. If none of the UMD's play, the problem may be isolated to the PSP system.
  • Check for moisture Do not let the PSP system or any PSP® accessories come in contact with liquid. Also check for moisture condensation in the PSP system. If moisture condensation occurs, remove the disc from the PSP and do not use the PSP until the condensation has evaporated, which can take an hour or two. In general, if any part of the PSP gets wet, discontinue use until it is completely dry.
  • Check the regional code Check the regional code on the UMD™ Video. The only regional codes that the North American PSP® is tested to work properly with are "ALL" and "1.
Tried these steps and still need help?
If you have tried the troubleshooting information above, but continue to experience problems, please contact our Consumer Services department to have your PSP system serviced.
Jun 28, 2011 | Sony PlayStation Portable (PSP) Console
Psp makes beeping noises and wont play any umds
mate make sure the case of your umd is correctyly placed and put your finger on the umd (where it spins) its like a little circle color silver move it with your finger and make sure it spins..
Mar 28, 2010 | Sony PlayStation Portable (PSP) Console
My psp cool graphic games like Valhala Knights wont work but the low graphic games works!help
its because all cool games with great graphics are almost released this year so they a restriction (hands down for sony)this year after a disscussion sony came up with a idea to shock the whole portable gaming world that the new games(cool graphic games)would want a firmware update (no less than 5.00)to run so they made all the games patched them to run only if the gamer has a firmware more than 5.50 so what you should do is simple just upgrade to 6.00 or if you are using custom firmware then upgrade to 5.50 gen d2 (after these process be sure to reboot and go to recovery mode and do recovery) 5.50 gen d2 is a big concept when you click some firmware which is lower than 5.50 it will say you have a upper firmware which is 9.90 (which means it has the power of fw 9.90 even though 9.90 is not released) and if this doesnot work take your umd out and refresh psp and put it back in if your using custom firmware press select and change driver m33 driver if it does not work then change it into sony n9660 (although you need a umd for that to work and the umd should be inside the psp when playing the game
Dec 06, 2009 | Sony PlayStation Portable (PSP) Console
My washer is making a loud, clicking noise
One of them underwire garments could be stuck in the pump and eating a hole into it.You should take the cover off and take a look at it in motion without the case.
Sep 24, 2009 | Kenmore 24032\24036 Top Load Washer
When i put the umd into the drive it starts loading and then makes a clicking noise
Its nothing you should really worry about as long as the game works all the umd is doing is reading at a higher disk speed (i.e faster loading times) also happens with ps3 at certain times
Jul 06, 2009 | Sony Video Game Consoles & Games
Cannot load umd games
If you have custom firmware, make sure your "execute boot.bin" and "plain modules" are both disabled under your advanced configuration settings of the recovery menu. Also, make sure your ISO/CSO games are saved in the ISO Folder of your memory stick and that your UMD MODE is set to NO UMD REQUIRED. Your PBP Games should be saved in your PSP/GAME Folder.
Jul 06, 2009 | Sony PlayStation Portable (PSP) Console
Psp slim dosent read umds dono whats wrong makes a little noise
Is this happening with every UMD? If so the laser has gone bad. Google tutorials on how to replace it or have it replaced.
May 31, 2009 | Sony PlayStation Portable (PSP) Console
PSP Slim making click sounds when UMD is in
it could be a problem with the inside mechanisms of the UMD dock. Better make sure that the insides are clean and free of dirt or small particles.
Feb 08, 2009 | Sony PlayStation Portable (PSP) Slim...
Sony PlayStation Portable (PSP) Console Logo
236 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
