Question about D-Link Xtreme N DIR-655 Wireless Router
Router networks I was wondering if it is possible to have two seperate securities running at the same time? One being WEP and one being WPA.
I very much doubt it, every router config i've seen has only listed the one currently in use.
Posted on Dec 26, 2008
What is wpa passphrase
If you use wireless WiFi, instead of direct ethernet cable connection to the Roku, WPA passphrase and WEP key are security codes used to keep unauthorized people from using your wireless signal to access the internet and possibly eavesdrop on your internet activity.
Apr 21, 2014 | Roku XD Streaming Player 1080P Wireless-N...
WAP/WEP password not working
These are the two options for your Router. Don't forget to save your settings
WPA is an upgrade to the WEP (Wired Equivalent Privacy) standard for securing your wireless network. If you would like to secure your wireless network using WPA, you will need the following:
  • WPA enabled on your Dell TrueMobile 2300 Wireless Broadband Router
  • WPA support for your wireless clients. If you are using a Dell TrueMobile wireless client, you can check for the availability of WPA enabled software update for your wireless client at http://support.dell.com.
  1. Log into the Web configuration of your router at http://my.router (or the default address http://192.168.2.1)
  2. Click on Basic Settings.
  3. Click on Wireless Security.
  4. Click on the Enable Wireless Security checkbox.
  5. Select either WEP or WPA in the Network Authentication list.
To setup WPA
  1. Enter your pre-shared key. This key must match the key that is used by each wireless client computer associated to your router.
  2. Choose a key format. This can be hexadecimal digits (0-9, A-F) or ASCII characters (any key on the keyboard).
  3. WPA Group Rekey Interval specifies how often the key rotates or changes.
  4. WPA Encryption allows you to select 1 of 2 possible encryption methods (TKIP and AES) - choose one that your wireless clients supports.
  5. Click NEXT, then Save and Restart to apply the changes.
  6. Setup the WPA on your wireless clients. Refer to the documentation that accompanied your wireless clients, or your wireless clients on-line help system for information on how to setup WPA.
May 14, 2012 | Dell TrueMobile 2300 Wireless Broadband...
The access point's security settings are not supported by the Nintendo DS
WEP and WPA are types of security that are used to protect home wireless networks. WEP is the only security setting that works with the Nintendo DS and Nintendo DS Lite. WPA and WEP are both compatible with the Nintendo DSi. If you are not sure how to find your router's WEP or WPA Key or if you have problems entering it into your Nintendo DS, try the following tips:
so if your wifi is WPA. you wont be able to use wireless
but if your wifi is WEP you can.
WEP is not recommended because it is not secure. Easy to hack
Mar 20, 2011 | Computers & Internet
What's the difference between WEP and WPA? What should I pick?
WEP is a weak securtiy protocol that is outdated and can be easily broken
WPA is a newer security protocol that is much harder to break with AES encryption
WPA is always recommended mode for operation over WEP.
Use WPA2 which is latest version if it is supported by device.
Mar 12, 2011 | Belkin N1 Wireless-N Wireless Router
How do I block other users from using my Modem
you need to lock the wifi use your house or cell phone number as a WEP key
Mar 02, 2011 | Arris SURFboard SBG900 Wireless Router...
Using wireless router and wirelss dongle/adaptor on same pc
Sorry to say, but no you can't do WPA/PSK and WEP at the same time from a single wireless router or access point.
The simplest way to accomplish what you want is to buy a simple Wireless Access Point, configure it to use WEP, and run it when your son wants to use his NDS. Leave your existing router on WPA for your computer(s).
Ok, that's really the second-simplest way. The simplest way is to set it to WEP and reconfigure your computer(s) to use WEP instead of WPA, and leave it that way. That drops your security though, so you may not like that solution as much.
Nov 01, 2009 | Belkin Computers & Internet
How do I put an encryption on my linksys router?
Securing your wireless network is a simple process, which generally does not require a lot of time. This can be done by:
  • Enabling WEP or WPA on the Router
  • Enabling Wireless MAC filter on the Router
  • Disabling SSID Broadcast on the Router
NOTE: The wireless security modes available may vary depending on the model of the router and wireless adapter you are using.
Enabling WEP on the Router
Wired Equivalent Protocol (WEP) is a type of wirelesssecurity which does not change. It provides comparable confidentialityto a traditional wired network. There are two types of WEP you canchoose from:
a. WEP 64-bit: This type of WEP consists of 10-hexadecimal codes. To enable WEP 64-bit, click here.
b. WEP 128-bit:This type of WEP consists of 26-hexadecimal codes hence it is moresecured compared to WEP 64-bit. To enable WEP 128-bit, click here.
Enabling WPA on the Router
Wi-Fi Protected Access (WPA) is a type of wireless securitywhich is dynamic in nature. Meaning, it changes depending on the timerenewal you will specify. Hence, WPA is more secured compared to WEP.
  • Temporal Key Integrity Protocol (WPA-TKIP) – utilizes a stronger encryption method and incorporates Message Integrity Code (MIC) to provide protection against hackers.
  • Advanced Encryption System (WPA-AES) – utilizes a symmetric 128-bit block data encryption
To enable WPA, click here.
Enabling Wireless MAC Filter on the Router
Wireless access can be filtered using the MAC address of thewireless devices transmitting within your network’s radius. You caneither permit or prevent specific wireless computers access to yourwireless network.
To permit wireless computers to connect to your wireless network, click here.
To prevent wireless computers to connect to your wireless network, click here.
Disabling the SSID broadcast is one way of securing your wirelessnetwork. This procedure will prevent other users from detecting yourSSID, or your wireless network name, when they attempt to viewavailable wireless networks in your area. For instructions, click here.
Jul 11, 2009 | Linksys Wireless-G WRT54G Router
Panasonic cf-50 problems to connect wireless wpa personal
If the wireless card is an old model it possibly won't support WAP encryption. The wireless router most likely supports both WEP and WAP encryption.
WEP is not as secure as WAP so use the highest bit encryption that is available to you.
May 07, 2009 | Panasonic Toughbook 50 Notebook
Belkin Wireless G desktop card & BTHome Hub
hi..
it has been seen that due to some reason the wep key doesnot work...
u can try changing the key type to WPA instead of WEP...
go to the router page and change the security type to WPA instead of WEP..
1 more thing in vista you can use the windows utility only...how come is it possible that you are using the card utility as well..i suggest you to disable the card utility and just use the windows default utility..
vedhick.....let me know if u need steps to change the security type to WPA..
Jan 26, 2009 | Belkin 802.11g Wireless Desktop Network...
D-Link Xtreme N  DIR-655 Wireless Router Logo
157 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
