Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Iam getting nothing
I have no sound or picture no sound
No sounds
Posted on Dec 26, 2008
I have jvc tv iam not getting any sound from the tv I have picture just no sound , the model # is 36320
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Oct 23, 2014 | Televison & Video
A1 error Kyocera fs 7000. I cant figure out what a Waste Toner Conveyor is nor can I find a picture any where on the net. I would love a picture of it so I can easily identify it. Thx
sounds like it is just full waste toner.If iam not mistaken the waste toner is inside the toner/drum assembly.The only way to reset is to get a new drum assembly.as its only ment to last 350 k
MK-30 Refurbishment
("Maintenance") kit4
350,000 Includes a DK-30, a DV-30, a FK-30, a TR-
30, and a waste toner conveyer.
unless u brave enough to dismantle the drum assembly.I never done it myself but sounds like u have nothing to loose.
If u do do it outside messyyyyyyy
Nov 25, 2010 | Kyocera Mita FS 7000 Plus Laser Printer
MY IPHONE IS LOCKED HOW CAN I UNLOCK IT.WHILE IAM COPYING ITUNES TO MY PHONE IT IS LOCKED.ON SCREEN IAM GETTING ONLY THE EMERGENCY CALL KEY PAD AND NOTHING IS THERE.IAM NOT ABLE TO OPEN THE MAIN MENU
Dec 26, 2009 | Apple iPhone 3G
Iam getting duplicate picture
replace the convergence OC its a STK730-130 you need only one you can get one at www.tvrepairworld.com
Nov 20, 2009 | RCA P52940 52" Rear Projection Television
No sounds on my speakers
1. Power to the speakers (make sure they are plugged in!)
2. Make sure the speaker line is plugged into the correct port on your sound card. The connector should be green and possible the port will be green to.
3. Double click the little speaker in the bottom right of the screen (assuming you are using XP/VISTA) and make sure nothing is muted.
Post back with your results.
Jun 03, 2009 | Logitech R-10 Computer Speakers
Nothing is coming on desktop except my picture set on desktop.
You need to go into bios and check weather the Hard Disk is detecting or not by pressing DEL key, F2 or F10 this will leads you to BIOS Setup. If you are not familiar with this just load optimal defaults and save and Exit.
Then Reboot the system PC should start else send me the exact message you're getting.
Thanks & Regards
Nanda Kishore
Mar 16, 2009 | HP Computers & Internet
Hp Pavilion XT963 four beep startup and nothing
Since iam not sure about the beep noise that u get....becos there are different pattern for it.
so iam pasting this link and let me knw the pattern plz..
http://www.computerhope.com/beep.htm
or else it could be the power supply which is not placed in properly try unplug and placing it back again.
or let me knw the exact noise that u get is it a beep noise or clunking sound or very, quiet jet taking or Noisy fans.
Thank you.
Oct 01, 2008 | Computers & Internet
No video
PS3 is The amazing device by sony but it has some common problems likesound problem, video/Picture problem etc.... Good news is that these allproblems can be repaired with the help of DIY Guides, one such guideavailable at PS3 Repair Blog
Aug 23, 2008 | Sony Playstation 3 (PS3) Console
Iam getting nothing
Have you checked the fuse? If so you probably have a faulty Horizontal output or low voltage regulator causing a dead set.
Hope this helps let me know if I can assist you further on this.
Jan 23, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
22 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
