Question about Tivoli Henry Kloss Model Two FM/AM Radio
Tivoli model two - low/no sound in base unit
Tivoli model two - remote speaker works fine; base unit speaker makes sound but is very very faint;
I tried the earphone jack on the base unit and found that both channels have sound, but then also learned that the BALANCE control turns but has no effect on left and right on the headphones.
Note that the balance control does work to adjust sound from hardwired remote Tivoli speaker.
This has me stumped. How do I open this ****** up and take a look inside? Thanks!
I have exactly the same problem but found two work arounds, either one that I am completely satisfied. 1. unplug and replug the AC.
2. I have a subwoofer, when I plug the subwoofer cable half way in, the sounds of the base speak goes back to normal (but not all the way in)
Posted on Nov 22, 2009
Faint sounf from car speakers
Just a couple general ideas. If it is a used car then the head unit is possibly failing. Another possibility is resistance building up at the connections. If you can clean the connections, plugs and slipons with electronic spray, erasure, and fine sand paper if accesable.
Mar 20, 2014 | Audio Players & Recorders
Sony Bravia HDX-285 My center speaker does not put out any sound. I tried changing the input and it work fine in the other inputs. I tried a different speaker in the center speaker input jack and no sound....
Your surround capability is 5.1. Although there is a front panel function button, there appears to be no other buttons to program your unit without the remote. Find your remote or replace it. Ebay is showing replacements at what I consider a low cost. The Sony model is RM-ADU007. Failing that and considering the many remote functions required for you unit, would be a Logitech Harmony replacement. The Harmony remote also comes with a USB patch cord because the user must go online with Logitech to program the remote for your unit. It would be best to the Harmony website prior to buying to make sure it covers your model.
Nov 30, 2017 | Sony Audio Players & Recorders
My Tivoli Model One makes a loud screech/buzz noise
I had the same problem and was able to repair it quite easily. Only thing needed is some basic soldering skills.
Problem description:
  • Suddenly a quite loud and disturbing (scratch/screech/buzz) noise appears.
  • Sometimes the noise is gone but it reappears sooner or later.
  • Changing volume or radio band / input (am, fm, aux) does not affect the noise (even on volume turned down all the way).
  • The signal coming out of the Headphones / Rec Out plug is not affected.
Cause:
  • Cold solder joints
Solution:
  • Unplug from mains
  • Remove back panel (the two black screws next to the plugs in the center). The back panel sticks quite firmly, so it might help to remove the front panel first (the 4 screws in the corners) and carefully press out the back panel from the inside. (The other two (silver) screws are used to attach the transformer to the back panel) and need not to be loosened.)
  • On the circuit board at the back panel locate the plug that goes to the speaker (is says "J2"). Check the solder joints. In my case, looking closely, I could see that they're not good anymore.
  • Renew the joints by heating them up and applying some fresh soldering tin. I also renewd the joint from the wire bridge next to the plug. Just check the other solder joints on the board.
In my case afterwards the problem was gone and the device is working properly again.
Apr 03, 2010 | Tivoli Kloss Model One AM/FM Radio
Tivoli Radio,
Does your radio have a sleep button or option? If so, check to make sure that you did not set it on accident or with out knowing. Or if it has batteries, check them to make sure they aren't dead or mixed with old or new.
Oct 21, 2008 | Tivoli Cherry Top-Firing Stereo Speaker -...
Tivoli Stereo Speaker
Any speaker has the potential to be used as a computer speaker. The problem you will run into is what will be used to power the speaker. Typical computer sound connections do not put out a strong enough signal to power a full sized speaker on their own. If you hooked the computer to an amplifier and then to a speaker it would work fine. If you do this, I recommend using the line out connection on the computer instead of the headphone connection.
Jul 20, 2008 | Tivoli Cherry Top-Firing Stereo Speaker -...
Bose cinemate acoustimass module
try taking ones apart that have the rumbling and see if theres anything loose inside
Jan 21, 2008 | Bose Cinemate Digital Home Theater System...
Very low sound from all channels
Without a model # it's hard to say what you have or what the problem might be, but since you said "in the day" I'll assume it's old enough to have a tape monitor function... Make sure Tape Monitor 2 is not on. Also make sure you are on the correct A/B setting.
Sep 12, 2007 | Audio Players & Recorders
Tivoli Henry Kloss Model Two FM/AM Radio Logo
811 people viewed this question
Top Tivoli Audio Players & Recorders Experts
Frank Russell
Frank Russell
Are you a Tivoli Audio Player and Recorder Expert? Answer questions, earn points and help others
