Question about GE WSXH208A Front Load Washer
Door Lock Clicks/Makes noises Washer does not agitate/spin
The door lock on washer seems to be making clicking or buzzing noises and the washer fills and starts to turn to wash then stops. When turned to the spin cycle the water drains but usually will not spin. I lifted the front thinking it was not level & it did start spinning well then leveled the washer & it started not washing or spinning again. The door lock light is on but seems to be blinking out a little.
  • 1 more comment
  • Phil Salazar Apr 19, 2007
    Thanks for leading me in the right direction. What was making the motor not able to turn the drum was that I had the washer plugged into an energy saving box that said it was for gas dryers and washing machines. My old washer worked fine with the energy saver but the newer front loading washer did not work until I plugged it directly into the wall socket, giving the motor the power it needed. Thanks again!
  • miriamharris Aug 12, 2008
    My washer is 4 months old. THe same model. It makes a buzzing sound and it wouldnt spin. I have tried everything but it just doesnt work. Please help
  • Anonymous Mar 25, 2014
    the washer will drain but wont spin. It makes a grinding noise but that is all.
I have Adora frontloaders and my washer was doing the same thing, not rinsing. I could literally squeeze the water off of the clothes. Come to find out, I needed to clean the filter that is on the inside part behind the bottom panel. Open the washer's door and there is a screw on each corner, take those off and remove the panel, there is a white tube with a gray lid on it, remove the lid (make sure you have a garbage can or something where the gunk can drop into), let it drain out and presto its done!!
Posted on Aug 26, 2008
Sounds like very worn motor brushes to me, as its trying to turn the drum but has'nt the power needed to maintain any momentum,and the blinking door light is because of the bad cotact from brushes to motor.About £20 for a set of brushes or get an engineer to fit new brushes,but get a price first.
Posted on Apr 19, 2007
THE DOOR WON'T LOCK THEREFORE THE MACHINE WONT START
Washer Door or Lid Won't Lock - Repair Parts - RepairClinic ...
www.repairclinic.com/...Washing-Machine/...---/Washer-door-or-lid-wo...
Most Frequent Causes for Washer door or lid won't lock. For the most ... Once thewasher door is closed, the washer can begin operating. If the door lock is ...
Door makes clicking noise and won't lock or start - Kenmore ...
https://www.ifixit.com/.../Door+makes+clicking+noise+and+won't+l...
iFixitOct 30, 2013 - Door or Lid Latch Assembly If the washer lid or door won't lock thelock and ... The Kenmore Elite HE3 is a washing machine by Kenmore.
Front Load GE washer won't lock / start. ' ShopYourWay
www.shopyourway.com > Manage My Life > Questions
Front Load GE washer won't lock / start. ... Based on your symptom and details it could have a faulty door lock assembly ... GE Washing Machines 3.8 cu. ft.
Washer Won't Spin or Agitate? Washer Door Latch ...
Dec 13, 2015 | Washing Machines
My roper washing machine will fill with water, but will not agitate, rinse or spin, but will drain. It makes a horrible noise during all cycles except when filling with water. What is or could be the...
No agitation or spin? try these:
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Transmission or clutch assembly not engaging due to going out or slipping.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
CHECK THE CAM DOGS INSIDE THE AGITATOR, AS THEY WILL HINDER THE AGITATION PROCESS.
Mar 17, 2015 | Roper Washing Machines
My Amana Tandem 7300 front load washer gives an f5 e3 code. It would start spin once then stop and make a click/buzz noise then beep three times then shut off. The door latch mechanism was replaced, ...
Feb 28, 2015 | Amana Washing Machines
Whirlpool washer fills sometimes and won't agitate or spin or drain what should i do
Jul 24, 2014 | Whirlpool Washing Machines
I have a Frigidaire FTF530ES1 front load washer that doesn't spin or agitate. The door lock light comes on and I don't think it is that. It fills with water, then you can hear the clicks for each cycl
Good Morning Vickie,
I understand that your Frigidaire washer, model# FTF530ES1, will not spin or agitate. I also see that the door lock light came on so you checked the door latch, due to it not unlocking right away. Now, you have removed the back panel and restarted the cycle, to find out that the motor is not coming on. There is a possibility that it could be the motor, or it could be something completely different that is causing your washer to not spin or agitate. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your washer and determine why it is not spinning. I hope this is helpful.
-Best Regards-
WP
Jun 16, 2014 | Frigidaire GLTF2940ES Front Load Washer
W600 fornt load washer does not wash or spin. It does fill and drain fine.
Jan 12, 2014 | Asko W600
How can I use jumpers to test 131763202 Frigidaire door lock switch on washer? Won't agitate or spin.
Hi slogjlog - Often when a unit does not spin or agitate, it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Mar 21, 2013 | Frigidaire GLTF1670A Front Load Washer
My roper top load washer model rtw4440vq fills with water but wont wash, spin or drain
see this causes and fix it. God bless you
Sep 30, 2012 | Roper Washing Machines
Whirlpool washer WTW5510VQO will fill, spin and drian but won't agitate, just makes a clicking noise.
If this is just clicking then the agitator bearings stuck or something is jamming it.
Jun 05, 2012 | Whirlpool Washing Machines
Washer makes very loud humming noise in spin cycle but does not spin..I removed clothes thinking it was very heavy and it did spin out but when I put clothes back it returned w/no spin and loud noise..now...
Either the control board or the motor has gone bad. Here is the diagnostic mode to run to look for the errors.
The diagnostic test is performed by using the Program Knob. To START THE TEST: • On non-digital display models, turn the Program Knob to start position, Drain/Spin. • On digital display models, turn the Program Knob to start position, Touch Up. • Press Pause/Cancel to turn off LEDs. • Within 5 seconds, press and hold the Option and Pause Cancel buttons until LEDs start sequentially chasing, then release buttons. 1. All the LEDs will sequentially light. Pressing a button below a light cluster will light all the LEDs in that cluster at one time to confirm functionality. 2. Turn the program knob (1) click clockwise from the start position. The hot water solenoid will activate and hot water should enter through the detergent compartment. 3. Turn the program knob (2) clicks from the start position. The bleach water solenoid will activate and cold water should enter through the bleach compartment. 4. Turn the program knob (3) clicks from the start position. The bleach and the wash water solenoids will activate and cold water should enter through the softener compartment. 5. Turn the program knob (4) clicks from the start position. The door lock solenoid will activate. 6. Turn the program knob (5) clicks from the start position. The door lock solenoid will deactivate and the loading door can be opened. 7. Turn the program knob (6) clicks from the start position. The washer will fill and tumble. 8. Turn the program knob (7) clicks from the start position. The washer will fill and spin (leakage test). 9. Turn the program knob (8) clicks from the start position. The drain pump and door lock solenoid will activate and the washer will operate in high spin. SAFETY WARNING: If power is removed during this test, the door can be opened. To prevent injury, DO NOT put your hands inside when the tub is rotating. 10. Turn the program knob (9) clicks from the start position. The control will signal the last error code.
Repost the error codes here.
Feb 12, 2011 | Frigidaire Affinity ATF7000E Front Load...
GE WSXH208A Front Load Washer Logo
372 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
