Question about IBM ThinkPad T43 Notebook
Key No 2 has come off ibm Series 43 thinkpad keyboard
The above key popped off the keyboard of my daughters computer this morning.
We have tried to put the key back in place, but find the bits fidgety and some of information is a little bit vague and not very helpful.
Can you suggest an easy way to re-assemble the bits and re-attach to the keyboard.
    Problem Solver:
  • 6 Answers
It would be very difficult to describe, as it's a bit fussy.
What you should do is carefully pull off the tilde (top left below the F1) key with your fingernail. Look at how the gray and white parts fit in. If you simply get them in this shape and press straight down, it will click into place.
If you haven't disturbed this configuration, simply pressing the key straight down will click it into place.
Posted on Dec 26, 2008
I have a Mac computer and the key board Num Lock won't turn off. I tried Fn=Shift+NumLock or Fn=NumLock but still won't unlock, Help
Hi Kip,
On the right side of the number keypad on a Mac Laptop, there is a 'Clear' button above the number 7. Press Shift + Clear to turn Num Lock on. Press that again to turn it off. If the keyboard doesn't have a number pad, press F6.
Apr 11, 2014 | IBM Thinkpad 560 Series Laptop 20h4241...
Lenovo p580 numlock off
What options have you tried ??
Number Lock on IBM Laptop Computers b> Laptop computers have the advantage being portable and self-contained, but among their drawbacks is a keyboard without a separate number keypad. While for most applications number keypads are unnecessary, they can be useful for data entry. Laptops sometimes provide a number keypad by giving certain keys double duty, allowing them to enter numbers rather than letters when a "Number Lock" setting is turned on. Number Lock, however, can get turned on accidentally, or enabled by an operating system by default, which can really mess up your typing. If typing "M" ends up displaying a "0" on your screen, Number Lock is probably the problem.
Try to locate the function key. On a T-series ThinkPad, it's in the lower left hand corner. It should be labeled "Fn," and the lettering may be blue, green or red instead of white. If your laptop lacks a "Fn" key, use the "Shift" key for Step 3 below instead. Locate the key labeled with "NmLk". On a T-series ThinkPad it shares a key with "ScrLk" which sits on the very top row between the "PrtSc" and "Pause" keys. On other IBM laptops, the "NmLk" key might share a key with "Delete." While holding down the "Fn" key or the "Shift" key, depending on your model, press the "NmLk" key. This should turn off Number Lock and restore your keyboard to its usual state. Number Lock on an IBM laptop is a "toggle" setting. You can turn Number Lock on by following the same steps.
also Examine your keyboard to ensure your "Number Lock" key is not activated. This activation is indicated by the key being lit up. If the key is activated, press it to deactivate the lock. The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor. In the registry, open the below folders.
Control Panel\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon.
Jan 30, 2013 | Computers & Internet
Unlock the security chip for a ibm t 60 thinkpad
IBM-branded Thinkpad T60 laptops from Lenovo are mobile computing devices that feature a keyboard lock for data security. When the lock is enabled, pressing the keys on the keyboard does not result in input to the computer. The lock hampers attempts by an unauthorized user from gaining access to your computer and your files. Lock your Thinkpad using the Function key. The Function key used in conjunction with other keys on the keyboard expand the laptop's number of available features.
Locate the "Fn" key in the lower left corner of your Thinkpad keyboard. Locate the "F2" key in the upper left area of the keyboard. Press and hold the "Fn" key, then press the "F2" key to toggle the "Lock" feature. Release both keys. Hope this helps.
Jan 14, 2013 | IBM Computers & Internet
When I write text on the laptop keyboard, only numbers show but no letters. what to do?
Try reset your laptop. Remove the battery and allow 1 hour before re-inserting the battery. Then get back to me what happen.
Nov 04, 2010 | IBM Thinkpad 560 Series Laptop 20h4241...
How do I turn on the wireless on an IBM ThinkPad 2628 A20m Thanks in advance
To turn on the wireless on IBM Think Pad 2628 A20m you can try the below options
IBM General - Some models have the wireless slide button on the side of the laptop.
IBM DV series - use the antenna-like button found on the upper section of your keyboard.
IBM R40 - Use the Fn+F5 key-combo.
IBM Thinkpad (General) - Most have software switch or button on Left hand side.
IBM Thinkpad (model not further identified) wireless switch on Front edge of case.
IBM T43/X32 - Fn+F5 -Click "Turn On"
IBM ZD series use the antenna-like button just below the “Lock” key.
Let me know fi this will help
Dec 04, 2009 | IBM ThinkPad A21m 2628 Notebook
Letter Y popped out and I lost a white plastic piece to pop it right back. Can i buy it?
take a look on ebay, if not look for a faulty keyboard around $10 and use the key of that
Nov 19, 2009 | IBM Thinkpad 560 Series Laptop 20h4241...
Ibm thinkpad keyboard. i type letters, numbers show up. fix?
With my IBM Thinkpad, I had to hold Shift+ScrLk to turn off Number Lock.
Mar 27, 2009 | IBM Thinkpad 560 Series Laptop 20h4241...
Entering BIOS settings, Easy-Access, after POP, with external KB
The Power On Password problem is near impossible to crack. It is designed to prevent unauthorized access to the Thinkpad and removing the BIOS battery will not remove the password because the password is stored on an EEPROM chip.
There are no backdoor passwords available, the only option is to ask the person who set the password.
There is a way to hack into the Thinkpad to see and remove the password but it requires electronic skills, a program and a working computer.
For details on how to do this go to :-
Feb 03, 2009 | IBM ThinkPad 600X Notebook
IBM ThinkPad T43 Notebook Logo
135 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
