Question about Electric eZip Trailz 26 Women's Comfort Bicycle
When I connect my battery light dims on battery and speed control wont work Battery is fully charged.
    Scholar:
  • 59 Answers
Try using the second battery tray to see if it is a contact issue.
Posted on Apr 17, 2010
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 117 Answers
The more you recharge a battery, the battery's lifespan is reduced. After a certain amount of charges, the battery will not be able to hold a charge for a long amount of time.
Note: Make sure it is a rechargeable battery
Posted on Dec 30, 2008
05 cobalt. replaced starter and battery. starter solenoid spins but does not engage starter. head lights dim also when trying to start.
If the lights dim when the engine is trying to start, then the battery is not fully charged.
If the battery is not fully charged there is not enough speed to make the bendix on the starter slide out under centrifugal pressure and engage the ring on the flywheel.
Put the battery on a proper battery charger overnight. Also make sure the battery terminals as clean and tight, plus the negative strap to the body and the positive lead wherever it goes to.
Incidentally, the starter solenoid is not what you think it is as it doesn't 'spin'. It is an electrical relay used to take the massive amps needed to turn the motor from the battery to the starter without burning out the wiring to the ignition switch and the ignition switch itself. You mean the 'starter spins'.
Have a read
starter solenoid Google Search
Nov 08, 2017 | Cars & Trucks
2016 ford edge wont start
no sound = check for battery connection. Turning on lights to see if they are bright or dim helps to find out if your battery is fully charged or not. If you get nothing, it might be a dead battery, or like I stated, just a poor connection. Start with the simple thing first. Battery connection..
Nov 06, 2017 | Ford Cars & Trucks
1999 plymounth voyager wont crank an wont start
well first thing to check is the battery working. turn the headlights on. do they light up bright. dim would me you need to charge it or replace it. if that's not the issue the starter will go and that makes the engine turn over when you use the key. the igniton or shifter could be another problem try starting it in neutral if you suspect the shifter cable. my guess is the battery. or the connection for the cables to the battery. but need to check and test stuff
Mar 12, 2015 | 1999 Plymouth Voyager
Car wont start after changing the battery
Well is the battery new or used and does it have a full charge ? If it is fully charged are your batteryterminals clean ?
Jul 27, 2012 | 2003 Mitsubishi Lancer
1989 flh tc step on break all lights dim real bad
Sounds like either you're drawing too much current in the brake light system or your alternator is not charging the battery fully.
On the brake light system, have you added additional lights or changed the type of bulbs in the lights. If so, you may have exceed the output of your charging system. I've seen people put so many lights on the back of their bikes that they've burned up alternator stators on a regular basis.
To check your charging system, put a battery charger on your battery and bring it to full charge. Then connect a digital multimeter to your battery, red lead to positive, black to negative, 50 volt scale. Start the engine and bring the idle speed up just a bit. After about a minute or so, the meter should read about 14.5 volts to 15.5 volts. Any higher or lower could indicate problems. If you find this, repost with that problem and I'll tell you how to check the alternator with your meter.
Nov 18, 2009 | Harley Davidson FLHTC Electra Glide...
Starter???
more than likely it is if you have a fully charged battery in the car, you can have it checked on the car or take it off and bring it to the parts store and they can check it on a machine
Aug 23, 2009 | 1995 Mazda 626
Battery is fully charged but it still wont power up no lights when plugged in to charge
Hook up only the ac adapter to the DS to see if it turns on. If it does then we know the ac adapter works. We know the battery got fully charged but the system isn't turning on with the battery that is fully charged up.
I would say your battery is defective but you won't really know until you fully charge up a known good working battery and test it out.
Jun 29, 2009 | Nintendo DS Lite Console
Will not start or come out of park. no lights and dash board dims when key is turned? battery has fully charge.
Using a voltmeter, check that voltage is identical to battery volts at the other end of cables. Check across the battery terminals, across connectors on battery, between negative post on battery and connection at starter, between positive post and end of negative cable then from postiive post and block. Wherever you find a variation, clean and re-check reading.If this does not help, there are sub system teststs you can do as well but I believe you will likely locate your problem before getting into that.
Apr 20, 2009 | 2003 Kia Spectra
Puma wont crank.
Lights dimming a good clue, that means that there is power going to the solonoid but starter moter wont turn. Check all battery connections and starter connections Make sure battery has enough power to turn starter or try jumper cablea.
Sometimes the starter gets jambed up due to poor lube on the bendix. try hitting the housing with a hammer. You can take the starter out and bench rebuild or just replace it its not a hard job,
Dec 21, 2008 | 1998 Ford Escort
Electric eZip Trailz 26 Women's  Comfort Bicycle Logo
279 people viewed this question
Top Electric Cycling Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Michial Gueffroy
Are you an Electric Cycling Expert? Answer questions, earn points and help others
