Question about Kenwood DNX8120 DVD Navigation Receiver Car Video Player
Send picture & sound to the rear screen
I have an Kenwwod DNX8120. There are so many steps, its hard to find the info I need in the user's manual. How do I send the DVD sound and picture to the video screen in the back seat area?
If you go to audio...you'll find "zone" press it and it will give you zone 1 and zone 2. in zone 2 you want to pick dvd as a source and that should be it
Posted on Jan 12, 2009
32L1300U
In what way is the screen broken? cracked, distorted picture, no picture but has sound?
If it is cracked. Replacement of screen is expensive. Cheaper to buy a new TV.
If Distorted. Parts linked to the screen can be the culprit. Most common part to fail is the T-con board. Main board may not be sending signal to the T-con board.
If its no picture but has sound. Back lighting has failed which could be several things that can cause that.
without any other details besides "broken" it will be hard for someone to help with diagnosing your problem. We need symptoms like. has sound but no picture. Picture has horizontal or vertical lines. part or half of the screen is black, black borders don't count. Hope the info here has, in some way, helped bring you closer to what to do with your TV.
Mar 26, 2014 | Toshiba 32L1300U 32" LED TV 1280x720, 120...
Change lamp on TV model WD52525 reset does not work
follow this steps and fix it. God bless you
Rear-Projection TVs have a lamp, which picks up the picture and projects it on the TV screen. A burned-out or connected lamps are two of the most common problems for Rear-Projection TVs. First, you will want to confirm the bulb is still good. If the bulb is bad then then replace it immediately. Second consult your user manual and verify the lamp and lamp cover are installed properly. Most Rear-Projection TVs have warning light which notify you when there are lamp problems. Again consult the user's manual to see what each light means.
Jul 31, 2013 | Televison & Video
Left rear window came off track and is stuck in the down position. The motor still cranks however the window is off track. Is this an easy fix? How do you take the door panels off to gain access to the...
Hi Dana,
I'm glad we got your taurus fixed. Thanks for the "Kudos".
If you can hear the window motor on your BMW running and making a bunch of popping and cracking sounds and your window is not moving, it is because you have a broken window regulator. The part you need looks like the picture below. The door panel as well as the sound insuator and rear glass must be removed to replace it. This sounds much harder than it really is. Actually, BMW has one of the easiest window regulators in the world to change. The hard part is getting the sound insulator off of the door without destroying anything. You will need a couple of single-edge razor blades to pull this one off.
If you think you will need step-by-step instructions with diagrams, just visit my profile and click on one of my "Pro Services" and sign up for email support and I will be happy to send you the factory service information for your rear door.(Haynes eat-your-heart-out, good info!)
Oct 03, 2011 | 2007 BMW 335i Coupe
I need the user manual with pictures to connect all the cables
You can get soft copy of user manual from below mentioned link:
moz-screenshot-3.pnghttp://www.transferbigfiles.com/e5486bf3-0637-42fb-a074-99fc4b960b65?rid=FvgAtyB2d1ORiKhjXpkzlQ%3d%3d
May 28, 2010 | IBM NetVista PC Desktop
Kenwood DNX8120: Hard Buttons Stopped Working
so does anyone know short of sending the unit by to kenwood?
Dec 30, 2009 | Kenwood DNX8120 DVD Navigation Receiver...
Screen color/picture quality
You can access the menu by hitting two buttons on the TV itself at the same time. You then adjust by hitting the up/down buttons.
The double pictures u mention sounds like a convergence problem.
If adjusting the convergence via the menu does not work
you would need to order 2 parts and be able to solder. A rather inexpensive repair if you can do it yourself.
For step by step info on how to repair click below
Good Luck,
Paula
http://techghetto.com/tv-repair/
Jan 14, 2009 | Philips 60PP9202 60" Rear Projection...
Sending pictures.
k listen go in to mms outbox and delete all your sent items and your g icon will be removed and if u want a user manual why not try ebay hop eit helps
Aug 22, 2007 | Samsung SGH-D600 Cellular Phone
Kenwood DNX8120 DVD Navigation Receiver Car Video Player Logo
150 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
