Question about SanDisk Sansa Clip MP3 Player
Wont connect everytime i connect it to computer its supposed to make this little noise and now it wont charge and say its charging but it does nothing at all. please help !!!
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jan 01, 2009
Motorola xoom wont charge
this is very common/same problem lots people having with their tablets, but i recently found solution for it.... try the following.
first connect ur charger to the table as you normally would do for charging, then connect the tablet to the computer through the USB wire (make sure charger and usb wire both must connected to the tablet) and it should start charging.... this seem awkward but will 100% work try it and see it urself
Feb 03, 2013 | Motorola Mobility XOOM Android Tablet
Ipod wont work
If it is under warranty still retrieve the serial number from the back of the iPod and call Apple to setup an appointment at your nearest Apple store to save you time. They only take appointments now that I know of.
If by resetting you mean by:
Holding down menu & play/pause?
If that doesn't work plug it into the computer, make sure you have iTunes installed and then try restoring it. And if THAT doesn't work, make sure you have the lastest iTunes, and firmware. Sometimes computers are a little iffy, if the connection noise is present and disconnected it could be the USB port. Sometimes on my phone/mp3 players it'll do that and they only liked to be plugged back into the same original port the USB driver was installed on. So if you plugged it through the front when it was working try that.
Jun 08, 2010 | Apple Audio Players & Recorders
My camera casio exz75 doesnt want to hold a charge
I had the same problem some time ago. I called Casio Live Support number and they sent me a new battery free of charge that works.
Jul 22, 2009 | Casio Exilim EXZ75 Digital Camera
My Mp3 PLayer is charged but no matter what I do, It wont turn on
your battery has run out and needs to be charged that's why it is not turning on.
connect it to a another usb port on your computer and it should be able to turn on and charge, it should work, if you still have problems, comment back.
Jul 03, 2009 | Philips GOGEAR SA6045 MP3 Player
Connects to the computer but wont turn on
i have the same problem to!! what a heap of ****!
Oct 11, 2008 | Samsung YP-K3 MP3 Player
Palm m130
If it needs to be charged, it can take up to 3 hours to do.  While it is charging you won't see any lights on the Palm.  Only the screen being turned on will indicate the charging level with the icon.
Sep 09, 2008 | Palm m130 Handheld
My laptopwant switch on? its charging but everytime I try switchinbg on it switches off straight away and the charging light flashes orange
I am giving you a step which you should try once and see if it makes any difference.
Method (Power cycle)
You need to remove the battery, adapter and any other device connected to the computer (May be any additional cards or any wires as for Ethernet or speakers or external mouse/keyboard).
Nothing should be connected at all.
Now Press and hold the power button for 25 seconds (It wont show anything). This is a step to release any static charges developed, which may surely caused the kind of issue you are facing.
Now connect the battery and the adapter and check whether it works or not.
Hope this should help
Regards
Sammy
Aug 28, 2008 | Acer Computers & Internet
I-pod nano wont switch on
I think i normally does that. I dont think you can use it while its connected.
Jan 11, 2008 | Apple iPod MP3 Player
Palm treo 650 wont power up
It may be past the point of turning on.
If this is the case, if you connect it through the USB cable to your computer for a little while, it can get a small charge.
Trickle charging
Some Palm devices have the ability to "trickle charge" from a USB port on a PC or Mac. This means that it receives a very small amount of charging from the USB port, even if it is not connected to its AC charger. If your device is capable of this function, the charging time will be significantly longer for a trickle charge (depending on the power rating of the PC USB port). However, the device may not charge at all on an unpowered USB hub (or for example off off a keyboard).
If you can then power it on afterwards, connect it to the regular power charger.
Jan 06, 2008 | Palm Treo 650 Handheld
80gb black ipod video
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod/five_rs/
If you need more assistance let me know. I'm here to help.
Nov 30, 2007 | Apple iPod MA446LL/A MP3 Player
SanDisk Sansa Clip MP3 Player Logo
26 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
