Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
My 81 shovel sounds and feels like it is fouling the plugs.
Once i get rolling after reving the bike to get going out of first, it runs like a champ on the highway it hauls *** til i have to stop and try to take off again.it pops and stutters til i get going. any ides ? it has a crane single fire ignition.
  • Mel Jacobson
    Mel Jacobson May 11, 2010
    Have U checked the plugs ? Are they fouling ?
    Scholar:
  • 29 Answers
The first thing I would look at is the accelerator pump in the carb. The original carburetor on your bike was a Kehin. The pump consists of a small cam, rod and diaphragm. Most likely the diaphragm has ruptured. Take the air cleaner off and at the bottom right of the carb there is a round boss the size of a quarter with a cast tube on top. Remove the 3 screws under the boss and a spring and the diapragm will fall out. Even if you don't see a hole, if the diaphragm is wet with fuel on the top, replace it. Hell, replace it anyway, it is not expensive. It is also possible the outlet plumbing is clogged. Spray some gumout through the discharge port (you will have to look at it from underneath to do this if the carb is still mounted) and it should exit at the little brass jet right in front of you. Make sure the tiny o-ring and the lip on the diaphragm are seated in their grooves when you reassemble it.
Posted on Dec 27, 2008
Front cylinder fouls
try cleaning the carbs, changing plugs, and cleaning the fuel tank. If that doesn't work, it might be the piston rings are getting worn out or you cylinder sleeves need a honing.
Jan 15, 2014 | 1994 kawasaki VN 750 Vulcan
Why does my dirt bike keep fouling plugs
Hi, Joey assuming it's a 2 stroke the usual suspects are:
1. The first thing to do if your spark plug has been fouled is to check the air filter. If it's really dirty, that makes it difficult for air to get through to the engine, causing a rich condition. Either clean it thoroughly with some Air Filter Cleaner or buy a new filter. Before you put it back in the air-box, treat with a fine mist of some air filter oil or spray. "WARNING" adding too much oil can also clog up the filter, resulting in another fouled plug.
2. While the gas/oil ratio doesn't equate to what the jetting is, you can still foul plugs, or worse, if the mixture is wrong. Depending on your bike, it's best to look at your owner's manual for the correct ratio. For most 2-stroke motocross bikes, a ratio is 32:1 or 40:1, the gas being 32 or 40, and oil being 1. For those that don't it, it means that for every 128 ounces (one gallon) of gas, you add 4 ounces of 2-stroke oil for a 32:1 ration, or just over 3 ounces for a 40:1 ratio.
If you have too much oil in the mixture (such as 12:1), then you will probably end up fouling the plug because it is more difficult to burn that much oil. Don't try to cut corners with the oil though, because it's very important for your dirt bike's engine. 2-stokes need the oil for lubrication on the cylinder walls, so if you don't have enough (or any for that matter) then the cylinder walls will run dry, causing it to overheat and seize the engine very quickly. So it's very important that you put in the right mixture pre-mix to your 2-stroke gas tank.
Also, 2-strokes have reeds that air and fuel go through into the cylinder, so if they are cracked or broken the bike will not run right. This could cause the plug to foul, so before you go out and buy anything expensive, make sure the reeds are in good condition.
3. While this usually isn't the main problem, it could be that your spark plug isn't burning hot enough. Having a hotter spark will ignite the fuel stronger, leaving less residual gas/oil in the cylinder that could cause the plug to foul. This "ISN'T" the best choice, but I'd say it's safe to go one plug hotter than stock. Keep an eye on the plug color you're looking for a light tan color anything whiter and you could burn a hole in your piston. Spark plug manufacturers aren't always the same, so make sure you find out how they rate them.
4. Almost every motocross bike comes rich from the factory (especially Honda 2-Strokes when they were being made). It's usually a pretty simple fix, but many riders are too lazy and would rather continue buying plugs instead of spending a few bucks on jets.
5. Piston rings badly worn or broken.
6. Faulty ignition coil low output.
For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Fouling plugs in my yz 125
Spark Plugs Keep Fouling
why does 2 stroke foul plug
fouling plug with 4 stroke what wrong ATVConnection com ATV Enthusiast...
How do you stop plug fouling
Jun 06, 2017 | Motorcycles
77 shovel head plugs carbon fouled
Hi Anonymous, and the usual suspects are:
1. Plugs in bad condition or partially fouled.
2. Spark plug cables in bad condition or leaking.
3. Spark plug gap to close or to wide.
4. Faulty ignition coil, module and or sensor.
5. Battery nearly discarged.
6. Damaged wire or loose connections at battery terminals especially the ground cable at BOTH ends, ignition coil, or plug between ignition sensor and module.
7. Intermittent short circuit due to damaged wire insulation.
8. If your bike has a CKP sensor you must leave both plugs in
head and check for spark with a 3rd plug. Good luck.
Jan 30, 2013 | Harley Davidson FXR Super Glide...
2000 XLH sportster bike starts up and idles right but once you put it in gear and try to ride cuts out and dies
Sounds like you're letting it idle too long with the enricher on. The enricher circuit is VERY rich and it will foul your plugs. When you start the bike, run the enricher only long enough to where you can get the bike to stay running with the throttle grip or throttle lock. Turn that enricher off as quickly as possible. Your plugs are probably fouled.
Good Luck
Steve
Aug 28, 2010 | Harley Davidson XL Sportster 883...
What spark plug should i run in my 2003 YZ 125?
Run a B9ES if you don't have a problem with fouling. If you do have a problem fouling, run a B8ES. Both of these plugs are available at auto parts stores for a few bucks each.
The stock plug was a BR9** - the R indicates a resistor plug which is not needed.
Scott
Jun 18, 2010 | 2003 Yamaha YZ 125
Running rough. At 70-75 km/hr it seems to
sounds like a spark plug is fouling out,or a clogged fuel filter.
Apr 07, 2010 | 1997 Dodge Intrepid
1995 suzuki sepia 50cc 2stroke doesnt run
Two strokes are bad with fuel/oil mixure. If this is premix theres a problem,if injected you may not be getting oil injected. Topends will heat up fast without oil. Fouled plugs and the wrong gap will also cause these problems. Check carb boot for cracks as air leaks will also starvel fuel out. Spray WD40 into carb throat with out tank hooked up, if it fires up, clean carb and reset float. Make sure the spark gap is correct. Check to be sure you have not slipped a keyway on flywheel which would throw timing off and it will only start by accident once every so often.
Feb 25, 2010 | 1995 Suzuki VX 800
2003 Yamaha 125 yz plug fouls pretty quickly. running 32/1 fuel oil ratio, and using NKG plug 2411/B8ES. Do we need to run a hotter plug?
NGK BR9EG is the stock plug for your bike. You are one heat range hotter already. I suggest you go to a BR8EG to keep you in the racing plug style but one range hotter than stock. I question what 2 stroke engine oil you are using. Stick with Yamalube 2 stroke oil and you should be okay. If you are using standard motor oil like you have in the gearbox then the fouling is definitely the oil.
Oct 27, 2009 | 2003 Yamaha YZ 125
Plugs Fowling 79 shovel
Install a Dyna, or equivalent, electronic ignition.
Jun 07, 2009 | Harley Davidson Harley-Davidson Motorcycle...
1991 CR 500 (reving to high on idle high serges)
take some wd 40 & spray around the carb boot while running to see if the idle drops for a few seconds. sounds like you have an intake side air leak causing a lean condition making the motor rev high.
Feb 16, 2009 | 2001 Honda CR 500 R
Lands Phones Logo
70 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
