Question about Whirlpool LER4634J Electric Dryer
Whirlpool electric dryer ran all night and won't heat
Will the dryer heat if the timer is inoperative?
  • 979 Answers
Yes it will heat. The two are normally not dependent on the other. The element could be bad. Check the breaker first, then the connections in the back, then the element. The timer could be bad itself allowing it to run all night. This could be a blessing in disguise as the clothes would have been damanged possibly from all the excess heat.
Posted on Jan 14, 2009
2005 Whirlpool Gas Dryer. It won't heat. The coils won't glow. Had the fuses, ignitor, and coils checked and are ok. Could it be the timer? How do I check it?o
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101-
Jul 22, 2011 | Whirlpool LGQ9858P Gas Dryer
Dryer ran for over a hour. No heat . timer never moved
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 27, 2010 | Whirlpool LGV4634JQ Gas Dryer
Dryer ran all night now no heat
Remove back of dryer and take out the elament shield and replace element don't over strech it start at one side and work it around thank you for useing fixya rate me
Jul 13, 2009 | Estate TGDX640JQ Gas Dryer
DRYER WILL NOT HEAT UP AND DRY CLOTHES ALSO TIMER IS STUCK
No heat & timer stuck would be an indication that the motor in the timer is not functioning or there is something wrong or jambed on the internal mechanism of the timer. There are no fuses inside the dryer, if you do not understand the basics of electricity and how to test things, then I would not suggest you attempt this yourself. No heat can be a number of problems(1)faulty element (2)open limit switch (3)bad breaker or circuit in the main electrical panel (4)inoperative timer (BUT) if there isn't 240VAC @ the dryer then the timer may not be getting any power at all, chances are, if you can't move the timer it is more than likely no good. If the dryer is still under warranty, enquire at the place you purchessed it from.
Justin
Apr 02, 2009 | Whirlpool LER5636P Electric Dryer
As long as the timer is on your heating element will be on.Sounds like you've have lost both.
Feb 11, 2009 | Whirlpool LEQ9858P Electric Dryer
Will dryer work if timer is inoperative
Check the breaker first, then check the connections in the back of the dryer, then check the element itself. It may be burned in two. The timer may be coincidentally bad as well.
Dec 26, 2008 | Whirlpool LER4634J Electric Dryer
Whirlpool drier has no heat and won't shut off . . .
it was most likely caused by the timer not turning off and burning out the heating element or a temperature switch or tripping one side of the circuit breaker in the house. it really needs to be checked out by a professional. unless it is old then you might want to replace it.
  • best case scenario:
  • the breaker has tripped (turn it off then back on to find out)
  • the TIMER MOTOR is the only problem <$30
If the timer itself is bad then it will cost a lot more.
Jun 30, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool dryer model wed5300sq0
My dryer heats but it takes more then 3 x to get the clothes completely dried. Why does it take triple the time to dry my clothes now.
Jun 15, 2008 | Whirlpool LER5636P Electric Dryer
NO HEAT
CK IF YOU HAVE 220V COMMING IN OR THE HEATING ELEMENT IS GOOD. OR CK THE THM FUSE.IS NO GOOD. BUT IF DRYER RAN OVER NIGHT AND DIDNOT TRUN OFF YOU HAVE TIMER PROBLUM. THE DRYER SHULD TRUN OFF EVEN YOU HAVE HEAT IN THE DRYER OR NOT.
May 03, 2008 | Roper REX4634KQ Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
123 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
