Question about SanDisk Sansa e250 MP3 Player
Help me one day i left my e250 on and it just went dead i thought that i could just charged it but it keeps saying battery too low system shut down please help.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 82 Answers
Use an xbox 360 if you have one or a desktop pc those will provide enough current, also you could take out the battery for an hour then re-inserting it.
Posted on Jul 28, 2007
Hello : Try to charge it from other PC, some USB PC ports have not enought USB current to charge the battery fully.
Posted on Apr 18, 2007
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
My battery went dead and after i charged the battery the air conditioning does not cool
What happens is, you have a battery and an alternator. The alternator charges the battery when the engine is running. It can only put out so many amps at 12 volts. A/C compressor runs off the engine, but the clutch for it is electric, and the blower fan is electric. When these are running, unless the car engine is running at above idle RPM's, your alternator may not be actually putting out enough amps to run the A/C AND charge the battery. So it is possible for the battery to go dead, especially if you start the car more than a couple times with out letting the battery charge. It happened to a friend of mine. He delivered newspapers, and it was a hot summer day. His A/C was on, plus, his car had 2 electric fans for the radiator. He was only idling along delivering his papers, and at one point he shut his car off. When he went to re-start, it was dead. He called me and I gave him a jump start, and told him to go for a ride down the expressway, to charge his battery. You see the A/C took say 30 amps, then each cooling fan for his radiator took say 20 amps a piece, then add in the stereo, and the power it takes to fire the spark plugs, and there wasn't enough left to charge the battery. Most cars these days only have 100 amp alternators. Older cars have less
Jun 05, 2014 | 2001 Lincoln Continental
New battery keeps going dead no low voltage light
Have the vehicle taken to one of many places that will test the Alternator output etc--narrow it down first without replacing that.
Voltage may drop enough to prevent starting without triggering the low voltage issue.
Jun 14, 2012 | 1997 Ford Escort
LG enV touch keeps shutting off when charging
I would replace the battery and see if that helps with this problem
Mar 30, 2017 | LG enV VX9900 Cellular Phone
Battery Low Message - Won't recharge
did u try connecting it to your computer like i do mine
Jan 24, 2009 | SanDisk Sansa e250 MP3 Player
Sansa crashed have white screen
I have a e250 also and it white screened. I could'nt shut it off. I just left it on overnight and 1/2 of the next day until the battery went dead. Then pluged it in. It Worked!!!!
Jan 19, 2009 | SanDisk Sansa e250 MP3 Player
COMPLELETY BROKEN
noticed the oil needed to be changed. It started back up and ran fine for a day then broke down again had to call a tow truck to get home. I changed the oil today with the recommended oil and now its completely dead. New oil new battery new spark plugs, new coolant and a full tank of gas and its worse than when i got it 2 months ago. Don't know what to do anymore. Help me out friends. Thanks. ,Completely dead? Do the lights come on with the key? If not, Then you either have a blown fuse or bad battery connection. A loose connection will cause problems like you describe. New battery or not, I would remove the cables, reinstall to make sure. Is the battery charged? Maybe you have a bad charging system or fuse. A 2006 shouldn't have needed a new battery unless you (or someone lese) left the lights on and totally drained it. My last battery lasted 7 years. Check the electrolyte level in the battery if it isn't a sealed one. Add distilled water if it is low.,,,
Nov 10, 2008 | 2007 HM CRE F490X I
Battery appears charged, but computer will only run when plugged in
does your battery have one of those charge indicator panels on bottom?
also, it's possible that the connection from battery to the internals is shot..if that's the case, then you're looking at a major motherboard swap
May 15, 2008 | Lenovo 3000 V100 Notebook
Sansa e250
alright just take the battery out and put it back in and turn on ur mp3 player.
it takes a little power to take the battery cover off though so dont fell stupid if ur using all ur energy.
Mar 14, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250 2Gb - No Charge - My PC no recognize my mp3
if you plug it in to the computer mabe the drive cant charge it in some computers some drives dont charge the mp3s it happened to me but try to connect it to different arias and if that doesnt work buy the wall charger hope it helps.
Jul 03, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
