Question about Acer Aspire 5100 Notebook
New not yet set up keeps turning off
Hi acer aspire one, have tried to set up time date etc , turned off, when turned back on goes to aspire one page and cannot go anywhere from there and will stay on for short period then turn itself off
Keeps restarting about every 10 minutes.
Could be a possible Virus/Spyware related issue or startup items are causing this issue or could be issue with graphics/video driver etc.....
Unplug all external peripherals/devices if any.
When you say you restored it do you mean System Restore to an earlier time or ?
Feb 22, 2014 | Acer Aspire 5742Z-4200 Notebook
Bl51 motherboard
All laptops have a CMOS, or "Complementary Metal Oxide Semiconductor," battery.
The main purpose for the CMOS battery is to keep the system time, date and BIOS settings even if the computer is turned off or the main battery dies.
Individual Acer Aspire laptop models differ somewhat, but the general steps are the same when replacing a dead CMOS battery.Preparation
Read through the owner's manual for your particular Acer Aspire laptop to determine what kind of CMOS battery you need.
Purchase the battery through Acer or a local or online computer parts dealer.
Turn the laptop off and unplug it.
Also unplug any external hard drives, cameras or other external devices.
Turn the laptop over (bottom facing up), then touch something metal to remove static charge.
Removal
Remove the Phillips screws that secure the motherboard cover (refer to your owner's manual if necessary), then release the cover from the clips on the bottom of the plastic casing.
Lay the cover aside, then locate the CMOS battery cable on the right side of the motherboard. Unplug the cable, then remove the battery.
Installation
Plug the new CMOS battery cable into the motherboard.
Slide the battery partially under the laptop casing to hold it in place, then align the cover with the slots on the bottom of the laptop housing.
Replace the screws, then turn the laptop back over.
Settings
Plug the laptop in and turn it on.
Enter your BIOS (usually by pressing "F1," "F2," F10" or the "Delete" key) before the operating system loads.
Follow the BIOS prompts or refer to your Acer Aspire owner's manual to reset your time, date and desired system settings.
BIOS Reset
Any time the CMOS battery is unplugged for more than a few seconds, your BIOS will be reset to the default manufacturer settings.
If you make any changes to the BIOS that cause problems with your Acer Aspire, unplug the CMOS battery for 3-5 seconds to correct the problem.
http://support.acer.com/us/en/default.aspx
Acer aspire laptop battery replacement
http://www.youtube.com/watch?v=mQTZ1AUR0uw
Jul 24, 2013 | Acer Aspire 5100 Notebook
I set date & time on my acer aspire, but it will not stay set it just stays on the date & time ive set. help! fred.
Welcome to FixYa!
-try doing these steps.
1) Enter the CMOS setup
-to enter the CMOS or BIOS setup, shutdown the computer completely -then once you press the power button to turn it on, keep on tapping on F2. (for some computer its F1, del, F10)
2)In the main or system setup screen you should be able to see the date and time. Using your arrow keys, navigate to the date and change the date. Once highlighted on the month, day, or year, press your arrow keys or your page up / page down keys to change the date.
These steps may vary for your BIOS; additional help, information, and simulations can be found on the BIOS help page.
3)after you have configured the time and date, save your settings and exit.
4)if it still would'nt hold the time you have setup, it could be a possible virus issue, or the CMOS battery on your computer could be degraded.
Hope this steps would help!
Have a great day!
May 25, 2011 | Computers & Internet
The system clock will not stay set, when I turn off laptop the clock stops and calendar stops . I reset it every time I turn it back on so I receive all up to date updates . Windows updates are set to ...
You need to set the correct date and time in your system BIOS. To access that you need to press the correct key when the computer is first booted (usually DEL or F10/F2/F11).
Most computers will have a message stating press xx Key to enter setup or etc.
If this problem persists even after setting the correct time in your BIOS, your laptop needs a new CMOS battery. I recommend having a professional do this.
May 09, 2011 | Acer Aspire 6920-6422 Notebook
I have an acer aspire 5315 and the screen goes black I have tried to go into set up and I have taken out bateries etc but it's still not working . Any help is greatly appreciated thanks
Hello mariawint589,
The following instructions are from the Acer Aspire 5315 user's guide (page 35):
The computer's power management system automatically blanks the screen to save power. Press any key to turn the display back on, three hings might be the cause:
*The brightness level might be too low. Press <Fn>+<right-arrow key> (Increase) to adjust the brightness level.
*The display device might be set to an external monitor. Press the display toggle hotkey <Fn>+<F5> to toggle the display back to the computer
*If the sleep indicator is lit, the computer is in sleep mode. Press and release the power button to resume.
If this solution is helpful please click a thumbs-up rating.
Have a great day,
martyshaw152
Nov 12, 2010 | Acer Aspire 5315 Notebook
Acer Aspire One - blue screen only when try to boot
You may have to remove and reset the HDD and Memory on the unit.
Next, you will recv. the F-2 to continue or F-12 to enter setup.
Enter setup and change date and time.
Save and try.
You may have a damaged HD or boot partition and reloading the operating system will be necessary.
Reseating the HD will assure that you have a good connection and the same with the memory.
Also, if the unit has been dropped, you may have a damaged HD and may need to change it.
Sep 26, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire One - Time settings
click the icon then remove check from lock taskbar
then click to adjust time and date then set your timezone
then in internet time check automatically syncronize then
time.windows.com then update and then apply
then click icon again and check beside lock taskbar
if this does not hold your time then redo remember to unlock taskbar first this time in internet time click server and change to time.nist.gov
then update and apply
if problem persists change back internet time to time.windows.com let me know if problem fixed please don't forget to rate me
thanx
Feb 09, 2009 | Acer Aspire One PC Notebook
Acer aspire 1 netbook won,t boot up.
Hi
When you first turn the machine on hit F2, that will take you into the bios menu, i don't know what version your machine is using, but the information is usually on the first page, you should find it easy enough because it will be next to the CD/DVD drive.
Feb 01, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire laptop
Hi
OS means operating System and HDD stands for Hard Disk Drive.
When u turn ur system on is it already black or it shows the bootscreen like ACER logo etc. and then goes black.
If thats the case then ur OS has crashed. Try installing new one.
And if its black right from the start then i think it is a hardware failure.
In any case let me know.
Jun 28, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5100 Notebook Logo
50 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
