Question about Mpuls3 Ampigo3 MP3 Player
Refresh database i have a problem with my mp3 player ever since i disconnect it from the computer two days ago, it still indicates refresh data base on the screen and is not going off. can some body help me.
0 characters
1 Points
Freezes at refresh database screen
Update the software else do a format. Make sure ur system is free from virus and other malwares.
Appreciate a good rating from you..
Jul 31, 2009 | SanDisk Sansa Clip MP3 Player
Sandisk sansa clip mp3 player
i need to know how to refresh data base
Nov 20, 2008 | SanDisk Sansa Clip MP3 Player
Sansa e200 shows refresh database fail
try putting it in MSC mode and formating it and then putting back on MTP mode. Hope that works
Aug 24, 2008 | SanDisk Sansa e250 MP3 Player
Refresh database error
Used the Firmware Updater to get the latest firmware and this updated my Sansa E260 player which was in Recovery mode. The player then completed the refresh database process. No data was lost. The player is now functiining correctly.]
Jul 27, 2008 | SanDisk Sansa e260 MP3 Player
Refresh database?Need Serious HELP!
Have you removed the battery, wait then reinstall it to try to reset it? Been the Sansa website and their FAQ or tech support?
Mar 04, 2008 | SanDisk Sansa e250 MP3 Player
MP3 not being recognized by computer
My opinion.
No one here seems to understand the question...unless it's just me.
Not being recognized by computer means you should not be able to disconnect the device safely. Am I right?
I cannot seem to disconnect the device safely, which means that the refresh database option will not display and do so!
Nov 06, 2007 | SanDisk Sansa e260 MP3 Player
Very weird...
'Refresh Database' doesn't mean everything is erased. It only means it's writing the progress that you made, onto the computer. It stays on 'Refresh Database' for about maybe 5-10 minutes. It refreshes its database every time you disconnect your MP3 player from the computer. What it does when you disconnect it from the computer is it saves any unsaved changes made to it and overwrites the memory or data.
Oct 28, 2007 | SanDisk Sansa E280 MP3 Player
Refreshing data base
It refreshes the database to build the menu for you to navigate.
Your device may have corrupt data in it and therefore takes longer than normal to build the library.
You can format the device to remove everything, and then re-transfer them to see if that helps.
To format in My Computer>Device Name (e250)>right Click and select format.
Best of Luck.
Oct 12, 2007 | SanDisk Sansa e250 MP3 Player
First switch your USB control to MSC. Then turn off your mp3 player and activate the hold icon. Then turn it on while holding the record button with hold icon still being activated. then it will go to recovery mode. Now plug your sandisk into the computer and wait until it says RECOVERY COMPLETE...PLEASE DISCONNECT or when it just says for you to disconnect. This worked on my sandisk, and it hopefully work for you.
Jan 13, 2007 | SanDisk Sansa e250 MP3 Player
Mpuls3 Ampigo3 MP3 Player Logo
21 people viewed this question
Top Mpuls3 MP3 & Digital Media Players Experts
Are you a Mpuls3 MP3 and Digital Media Player Expert? Answer questions, earn points and help others
