Question about Apple Studio 17" Flat Panel LCD Monitor
Apple 17" LCD Studio Monitor color darker after boot up
At startup the screen comes on with good color but after fully booted the image turns darker and more contrasty with most gradations in tone gone. This has occurred for a long time but I discovered a work-around in OS 10.4 Tiger by opening a .jpg file in Preview, clicking Slideshow and closing and color would be good until shutdown.  Now under OS 10.5 Leopard the workaround fails.  Any ideas?
  • 624 Answers
SOURCE: Apple Studio Display Flashing Power Button
Hi Lusciousleri, Some Apple LCD panels can report problems then encounter. I'm betting if you watch you'll see a pattern of a short flash, followed by another short flash followed by a long and then repeating. That indicates a backlight error, which typically means a trip to the authorized Apple repair shop. Let us know if you have any other questions and please don't forget to rate the posting.
Posted on Jan 30, 2007
For the brave of heart, You can disassemble the monitor. After you get in to the inside of it, you'll see a circuit panel with 6 ballast coils on it. On my Cinema display, what happened was that the solder joints on some of those coils had cracked, causing intermittent connection. After hitting all the connections with a soldering iron to heal the cold solder joints and re-assembling it, it is working perfectly fine now.
Posted on Jan 06, 2008
SOURCE: blank screen (Apple Cinema HD 23"LCD)
damn gay i got t is 23 apple screen for 14month and it has a black screen now :( .. what can i do to fix this .?
Posted on Aug 27, 2008
Had a similar problem with similar symptoms. Try unplugging the firewire and usb. Might help for a while. It did for me. In the end I risked the price of a new power supply. That fixed it and my 23" has been working fine since. Have to order the power supply directly by contacting Apple's service people. I found no other way to get one.
Posted on Sep 14, 2008
SOURCE: cannot boot Leopard or Tiger
Can you pleasr post more information on when how this was started I had this problem once with bootcamp but now it was resolved. Can you still get in somewhere?
Posted on Jan 04, 2009
Using a HP L1506 Monitor on a HP Pavilions a 867c computer and has worked, but now receiving "VGA input: no input signal" with window on monitor, followed by "Monitor going to Sleep" and it does. Worked...
First of all, boot your system without the monitor connected to it and when you feel that it's booted upto logon screen (or if you haven't assign password it'll directly logon to the desktop, power on the speaker to make sure you can know it's done) connect the monitor. If this isn't successful, please turn off the system and remove the cmos battery, leave it outside for few minutes and again reinstall it. Boot again normally. Still having the same problem? then let's try another method. Did you see the bios loading (black screen with white text during startup) when you power on the system? If so, press F8 several times while it is booting and select "Safe Mode" and restore your system to previous state. Do let me know if this isn't possible. Good luck Thanks for using FixYa.
Jun 10, 2010 | HP Pavilion F1703 17" LCD Monitor
Dear Sir, I am facing problem with my Samsung LCD monitor, when I switched on my Computer it shows the bootup screen, after booting the LCD screen goes blank, when i turned off the monitor and again turned...
yes turn on the computer and keep pressing F2 contineulsy immediatly after display observed then menu will be come then highlight on last good known configuation and press enter problem will be solved
Mar 05, 2010 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Damaged 24 iMac screen - want to use ext monitor via "mirroring" in screen preferences, but cannot access system preferernce due to damaged screen...any suggestions
There is an elegant way to solve this, but it requires another compatible model Mac.
Boot the damaged Mac into FireWire Transfer mode by holding down the "T" key immediately after hearing the startup chime. Attach a FireWire cable between the two Macs. Start up the other Mac by holding down the "option" key after hearing the startup chime. Choose the startup drive from the broken Mac. Now your good Mac is booted off the drive of the broken Mac, and any configuration changes you make will be made on the hard drive of the broken Mac.
Attach the external monitor temporarily to the good Mac. Open System Preferences and set the monitors up in mirrored mode. Shut down the good Mac. Then hold the power button in on the broken Mac until the power turns off, and remove the FireWire cable.
Now move the external monitor to the broken Mac and boot it. It should come up in mirrored mode.
Jan 20, 2010 | Apple Computers & Internet
Need Repair Manual for Apple Cinema Display M8149
here is a manual for the 17 in. apple studio http://www.devicemanuals.com/guide/Display%20and%20Video/Apple/Apple-Apple-Studio-Display-(17-inch-CRT)-User%27s-TVRBek9BPT.html
Jun 30, 2009 | Apple Studio 17" Flat Panel LCD Monitor
When i turn on my monitor it shows my desktop then shuts off after 10 seconds...never stays on
elainenemeth, Hi, Tell me more! How old is this LCD monitor? Is it out of warranty? Did the "SHUT-DOWN-IMMEDIATE" problem occur without warning? Did the BenQ display a "perfect" image the day before? Did you actually count----1001, 1002----1010 and then it shut down, after pushing the monitor on button. Did you do the "flashlight" test? With monitor connected to a "known-good", fully booted pc with Win Desktop displayed, TURN ON the monitor! Did it display the desktop for 1-2-10 seconds ? What did you see or not see when you pointed the flashlight at different angles about 1-2" inches from the now dark (black) screen? Get back to me with your results. I will offer the best advice possible to you as a consumer/user of LCD/FPD monitor. I'm louie12fix on fixya or lmistyrel @ aol.com Bye for now.
Apr 17, 2009 | BenQ FP71G 17" LCD Monitor
Dell E171FPb 17" TFT LCD Flat Panel Monitor Problem
The LCD and or the LCD inverted has failed. it is an unfortunate fact of life that nowdays it is cheaper to replace that monitor that to aquire parts for repair
Here is one on Ebay:
http://cgi.ebay.com/Dell-E171FPb-LCD-17-Flat-Panel-Color-Monitor_W0QQitemZ290290215133QQcmdZViewItem
You can buy a new 19 for about the same price
http://www.newegg.com/Product/Product.aspx?Item=N82E16824254009
Jan 21, 2009 | Dell E171FPb 17" TFT LCD Flat Panel...
Apple monitor
I THINK YOUR DISPLAY COLOR PROBLEM.
DEGAUSS YOUR DISPLAY, CHANGE YOUR DISPLAY COLOR RESET IT TO DEFAULT SETTINGS.
Mar 24, 2008 | Apple Studio Display 17" LCD Monitor
Connecting Apple Studio Display 17 ( LCD ) to Apple G4 Cube
Check the connector coming from the monitor and see if any pins are crushed or touching. It may be shorting power going to it.
Mar 02, 2008 | Apple Studio Display 17" LCD Monitor
Apple Studio 17" Flat Panel LCD Monitor Logo
41 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
