Question about Samsung HLP5085W 50" Rear Projection HDTV-Ready Television
No Sound When tv is turned on...there is no sound. There is however sound that comes thru the speakers (the sound it makes when turned on/off) but no sound. I have went to remote to see if a button was pushed inadvertantly, but nothing. I have also went into the adio menu and nothing there either. Also, there is no sound when I put in a DVD either??? Please help...motorboy
    Genius:
  • 1,074 Answers
Take your tv to a tech for repair the tv has a problem in the audio circuit or related circuits.good luck.
Posted on Apr 19, 2007
SOURCE:
How do you get audio to play through a receiver? We have the TV running to input on receiver and no sound?!?!
You have to go thru the menus on the TV and tell it you want TV speakers off, and output to surround at fixed volume. Then plug audio out wires (RCA jacks or optical digital wire) from audio outs on TV to AUX or Video or something like that into the receiver.
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_195f36f311cb10df
Jan 21, 2015 | Insignia IS-LCDTV32 32 in. Television
I cant get sound from my tv thru my ht-r380 reciever
This is most likely a connection or switch problem:
  • Make sure you are plugged into the appropriate sound out jacks on the TV
  • Make sure you are plugged in to the appropriate sound in jacks on the receiver
  • Make sure the source for the receiver is set correctly
  • ensure volume is set appropriately
  • ensure correct speakers are selected.
If you are playing a DVD, the input to the receiver should come from the DVD player
Jan 10, 2015 | Onkyo Audio Players & Recorders
I'm trying to connect a Samsung HD LCD tv to a Denon AVR1508 receiver using HDMI cable so that the TV sound comes thru the receiver/speakers. which jack do I use (on both the tv and the receiver,
connect the hdmi to the tv (hdmi input 1) and to the receiver (hdmi output) you must make sure that the receiver input settings are assigned correctly. Then hook up all of your devices to the receiver. remember that the 1508 dosent do hdmi upconversion, so if you have any devices that are NOT hdmi, you need to run rca cables from the output of you receiver to the input of your tv. If you have any digital inputs coming out of your devices, i would recommend using them. your 1508 has two inputs that are assignable.
If all of your devices are hooked up to your receiver, and its hooked up to your tv properly, just turn down the sound on your tv, and turn up the volume on your denon!
Dec 04, 2011 | Denon AVR-1508 Receiver
Connect Bose System to Panansonic TV
in the tv setup menu there should be an item that will allow you to change the volume from variable to fixed on the output of the tv
Dec 07, 2009 | Panasonic Audio Players & Recorders
Hooking up a sound bar to a 42'' flat screen panasonic can't get any sound from sound bar.
Go into the "menu" of the Panasonic TV toggle down to Audio and speakers and turn them "off" this turns on the monitor output from the preamp section. If you still have an issue, post a comment and I'll walk you thru troubleshooting. Hope this helps
Jun 24, 2009 | Audio Players & Recorders
TV sound only thru front and sub woofer speakers only
this might be happening because the audio format for surround is not supported by the channel or affiliate of the channel that you are viewing does this happen on all tv channels or is it on just a few? if all sound while playing a dvd is proper and in working order than there must be an issue with the sound and or format of sound from the tv source. maybe more information would help me decipher this
anyways hope it helps
Ryan
Feb 14, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
No sound from TV thru sony bravia hdx576wf; DVD & CD audio ok.
Could be a sync calibration issue. Try to divert the TV sound to another input source on the Hometheatre system if possible, if it is a go then maybe the TV audio needs to be recalibrated. Make sure TV audio setup menu option has not changed also.
Feb 08, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
Can TV Sound Come thru Sound System Speakers
if you have a digital rec the red and white output goes into the surround sound input, if you have basic cable, then you need to use the red and white output on your vcr to go into the surround sound input. just make sure to note which input you are using on the surround sound and switch it to that.
Nov 17, 2007 | Koss KS4192 System
No sound
you may have a blown fuse. check that first. Very if it still has a power.
Sep 12, 2007 | KLH SE-6000 System
Samsung HLP5085W 50" Rear Projection HDTV-Ready Television Logo
83 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
