I have a Quantum DLT4000 and I need it to back up tapes on the
SGI we have at work. The problem is that it is unknown to the
system.
I went into /var/sysgen/master.d/scsi and found that it was not
there. How do I add? In Solaris I just dump with the density and
blocking factors and it is fine. But I can't get this DLT to do
anything on the SGI.
Help......
(Wandering through the halls of Irix 5.3 without a flashlight..)
George
Rating: 0%, 0 votes
=> => I have a Quantum DLT4000 and I need it to back up tapes on the
=> => SGI we have at work. The problem is that it is unknown to the
=> => system.
=> => I went into /var/sysgen/master.d/scsi and found that it was not
=> => there. How do I add? In Solaris I just dump with the density and
=> => blocking factors and it is fine. But I can't get this DLT to do
=> => anything on the SGI.
=> => Help......
=> I just finished doing this and wrote up a quick procedure.
=> Load http://gis-www.larc.nasa.gov/~jason/dlt_on_irix5.3.html and
=> follow the steps. This procedure isn't officially supported by
=> anyone, so following it is at your own risk.
There was a small error on that page, so if you used it,
you'll want to go back and fix your kernel. The only difference is
the MTCAN_LEOD setting has been changed to MTCAN_SPEOD. I've sent a
note to Quantum that their documentation is wrong, but who knows when
and if it will get fixed.
Thanks to Tom Mander for pointing out the error.
Jason C. Austin
Email: j.c.aus @larc.nasa.gov
WWW: http://gis-www.larc.nasa.gov/~jason
Was this solution helpful? Show your Appreciation by rating it:
Rating: 0%, 0 votes
fix DLT4000 problems or any DLT problems? I cannot find it on
ftp.sgi.com or ftpgate.sgi.com... where else can i try?
Steve
Steve Loughran, SGI Admin / Video Engineer
Internal Mail: root@camsg001, stevel@camsg001, root@camam001
External Mail: ste @millennium.co.uk, zor @cix.compulink.co.uk
Web Home Page : http://camsg001/~camsjl/camsjl.html (Internal)
Equipment : SGI Indy, Amiga A2000 `030@40MHz, Yamaha YZF750R :)
Rating: 0%, 0 votes
=> system.
=> Help......
Jason C. Austin
Rating: 0%, 0 votes
George Lancaster <geo @sd.cts.com> wrote:
Add the following lines just after the "SGI" "DLT2000" entry to
the above file:
/* DEC THZxx DLT drive */
{ DECDLT, TPDLT, 7, 7, "Quantum", "DLT4000", 0, 0,
{0, 0, 0, 0}, MTCAN_BSF|MTCAN_BSR|MTCAN_APPEND|MTCAN_LEOD |
MTCAN_CHKRDY|MTCAN_VAR| MTCAN_SETSZ|MTCAN_SILI|MTCAN_SEEK|
MTCAN_SYNC|MTCAN_CHTYPEANY,
20, 8*60, 20*60, 5*60, 4096, 64*1024 },
Only the last entry should not have a comma after the close brace "}".
Then run "autoconfig -v", make sure that the kernel rebuild
works without errors and reboot. It should work much better afterwards.
Some of the SGI patches replace the scsi file with a new one, so
if you install patches, verify that the DLT4000 entry is still
there before rebuilding the kernel.
Mike Beirne
Michael G. Beirne, bei @fnal.fnal.gov (708)840-8525
Rating: 0%, 0 votes
| system.
So, could you tell me why the comments in that file weren't enough
to tell you what to do? I tried to make it really obvious...
I did add a few more comments to the 6.2 version, but since I don't
know what's not clear to people, it's hard to guess what else to
add.
Dave Olson, Silicon Graphics Guru and busybody at large
http://reality.sgi.com/olson o @sgi.com
Post a New problem for Quantum DLT 4000 DLT Tape Drive
Email this problem
Can you Help with these Tape Drives problems?
error reported: No more data os...
