Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
What is the Yellow blinking light when turned on.
When we turn the tv on a yellow light blinks and the tv does not come on.
  • 47 Answers
It could be the ballast
Posted on Jan 05, 2009
Blinking yellow light on Mitsubishi wd 57731
Based on the service manual:
Blinking yellow= Lamp cover is open.
It could be something else!
www.aaatvservice.com
Aug 09, 2014 | Mitsubishi WD-57731 57" Projection HDTV
What does the yellow blinking light mean on Mitsubishi WD65837
Here is a whole list for you :
Mitsubishi Blinking Codes :
Constant Green - TV is Powered On
Constant Red - Lamp Failure
Constant Yellow - DMD temp is very high
Blinking Yellow - Lamp cover is open
1 Red Blink, 6 Yellow Blinks - Color Wheel Failure
3 Red Blinks, 4 Yellow Blinks - Lamp Failure
3 Red Blinks, 6 Yellow Blinks - Exhaust Fan Not Working
3 Red Blinks, 7 Yellow Blinks - DMD Fan is not rotating
5 Red Blinks, 7 Yellow Blinks - Ballast Problem
6 Red Blinks, 6 Yellow Blinks - Lamp Missing, Bad Cable between lamp and ballast
And the Lamp cover must be here somewhere in your TV :
For more you can refer to the below link :
Mitsubishi DLP TV Blinking Code Errors Explained Overview of Each...
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
Yellow light keeps blinkingand the tv wont turn on
If the status light is blinking yellow it means the filter cover is open ( On the left side of televison)
If the lamp light is blinking yellow it means the lamp cover door is open. ( Behind front lower panel) If both covers appear intact the switches may be defective or not engaging properly.
Dec 11, 2009 | Mitsubishi WD-52525 52" Rear Projection...
When turning on the TV the green light on the front does not come on. You hear a click and then about ten seconds later you hear another click but the tv never comes on.
What light do you get, green blinking, red blinking, yellow steady light or yellow blinking light. The led lights will tell what is wrong with your tv.
Jun 12, 2009 | Mitsubishi WD-52327 52" Rear Projection...
No picture yellow standby light blinking
how old is the tv is it possible your lamp is burned out this is what a dlp screen would do.
Apr 14, 2009 | LG RU-52SZ51D 52" Rear Projection...
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
405 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
