Question about Frigidaire FER231A Electric Dryer
DRYER SQUEAKS REALLY BAD UNTIL WARMED UP
FRIGIDAIRE MODEL FDER436CHSO AND SQUEAKS REALLY BAD AT START UP AND THEN PERIODICALLY
I took apart the dryer, cleaned and greased the bearing that had no grease left at all(therefore I assumed no easy movement) and it worked.
Posted on Dec 27, 2008
Dryer has a squeak in drum area periodically.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Nov 04, 2010 | Frigidaire FEX831CS Top Load Stacked...
My dryer is making loud noise and after it gets warmed u it stops. I have replaced felt inside
heatman101
Oct 07, 2010 | Frigidaire Dryers
My Frigidaire dryer squeaks loudly.
heatman101
Sep 18, 2010 | Frigidaire FEQ332E Electric Dryer
My dryer squeels a high pitch sound until it heats up. it does ok till it starts cooling down then it squeels again. Is it the drum bearings and how hard are they to replace? It is a frigidaire Gallery...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Aug 19, 2010 | Frigidaire Dryers
Dryer squeaks when you start. warms up it goes away
It may be one of the tensioner pulley wheels either starting to fall apart or the spindle it runs on in need of a little grease. They often start off squeaking until they've warmed up a little. Then the noise goes away after 5 minutes or so.
Feb 04, 2010 | Frigidaire GLEQ2152ES Electric Dryer
The dryer has started to make a slight squeaking noise, but it is still drying
On a GE dryer the part that squeaks most is a WE3X75. Centerpost drum bearing. It is a simple repair but you must get into the machine.On a frigidaire model The plastic bearing that mounts in the rear sorta like a GE model. No other dryers that I can recall have the squeaks. The newer GE dryers are made very simular to the old reliable frigidaire models so you ought to hit it out the ball park with these 2 links.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 09, 2009 | Dryers
Dryer won't heat up. I don't have a parts manual.
more than likely the theraml fuse on the back of dryer unplug unit and use a continuity tester to check for ohms. the t-fuse is on the exhaust tube also the squeaks usally comes from the drum rollers use a little silicon grease and lube the roller shaft
May 28, 2009 | Frigidaire FSE748GF Dryer
Clothes dryer squeaks when running
Fixing Frigidaire model # FER641FSO, not stacking, but had similar problem. turnsout one of the coils came off. might try that...
Mar 01, 2009 | Frigidaire GLER331A Electric Dryer
Frigidaire FER231A Electric Dryer Logo
494 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
