Question about Samsung HLP5685W 56" Rear Projection HDTV-Ready Television
TV keeps cutting off and won't show a picture. There is a symbol I don't understand...
My TV has a Triangle (with an ! in the middle of it) with a lightbulb below it to the bottom left in the "circle" above the tv contronls. When I try to turn it on, it comes on and I can hear sound, but there is no picture. I wasn't home when it went out, but my nanny told me that it just cut off. Any help would be greatly appreciated. Thanks, Eric
  • tony_lanni Jan 26, 2009
    that it just cut off. Any help would be greatly appreciated. And i have changed the lamp.
    thanks
    tony
  • Anonymous May 21, 2009
    I replaced the bulb and it worked for a month. Now the tv constantly turns on and off. It makes a weird noise like it is a motor powering up and down. Any help would be appreciated
Your light bulb is dead and needs to be replaced. You can access the bulb in the rear panel by removing a few screws. The bulbs go bad every 3 years or so. Good luck!
Posted on Jun 21, 2008
    Genius:
  • 1,074 Answers
Have a tech check your tv the problem is in the power supply or related circuit.good luck.
Posted on Apr 19, 2007
SOURCE:
Dryer won t dry clothes
If it's new and not working correctly, I would suggest getting your warranty service to fix it. Otherwise, you may void factory warranty
Sep 23, 2017 | Hotpoint Washing Machines
What does the picture of a camera on the screen mean?
The symbols showed in the Camera screen may related to the selected settings or some error symptom. Please let me know the model # of the Camera and the symbol/picture youf're referring so that I can provide the exact information about the picture.
Thanks for understanding.
Dec 28, 2011 | Fuji Cameras
I receive texts but cant send them keep getting a triangle symbol with a ! symbol in the middle want does it mean
Turn your phone off and back on. Also, are you using the built in text messenger or are you using google voice?
May 03, 2011 | Cell Phones
How do you turn on the volume? Thank You.
1. Press the Fn key and while holding it down, press the F8 key momentarily to toggle muting of the speaker. An icon of the speaker appears at the bottom middle of the screen showing muting on or off.
2. After making sure the muting is off (no slash symbol on the speaker icon), press and hold Fn again.
3. With Fn pressed, press the key with the upward triangle and speaker symbol to increase volume which is shown at the bottom middle of the screen by the green lettering & vertical bars Volume ''''''''''''
4. With Fn pressed, press the key with the downward triangle and speaker symbol to decrease volume which is shown at the bottom middle of the screen by the green lettering & vertical bars Volume '''
Apr 28, 2011 | Acer Aspire One Netbook 8.9" Notebook
Samsung HLP5085W DLP - lamp replaced about 7 months ago. I powered up TV and got strange colors with flickering picture. Turned unit off and triangle symbol appears with lamp showing - needs replacement....
Strange colors and flickering picture symptom shows problem with color wheel and/or dmd board.
Lamp is only light source in dlp tv and it has nothing with colors or picture flicker.
TV goes to protection mode because of some internal problem as mentioned above.
If you wish to repair tv by yourself then you should have service manual copy in hand and that can be downloaded from HERE for small fee.
Hope these info will help you.
Thanks.
Jul 04, 2010 | Samsung HLP5085W 50" Rear Projection...
Warning symbol (triangle with an (!) in the middle
tmps " tire pressure monitor system" you have a low tire or tires fill with air if the light stays on take it to your tire shop they can assist you
Sep 22, 2009 | 2006 Chevrolet Equinox
Warning symbol on mini cooper
If it is yellow and looks like a tire it is the flat tire light, and you should check his tire pressure. if it is a yellow triangle with an arrow going around the triangle with a exclamation point in the middle this is your DSC or ASC and if it is on all the time these features are inactive and you should hit the DSC/ASC toggle switch to the right of the drivers window switch. If this symbol just flashes briefly this means the DSC/ASC is presently activating. thest are the tow that I can think of, I hope this helps.
Dec 04, 2008 | 2005 Mini Cooper
Red triangle in middle of screen
Good Day, lawrentzsca;
Sounds like bad convergence IC’s, chips. Hit recommends using STK392-150’s and replacing the bias resistors.
Good Luck, Big Irish, but hope the TV is fixed by now.
Mar 14, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Open Questions:
Samsung HLP5685W 56" Rear Projection HDTV-Ready Television Logo
586 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
