Question about HP Compaq Presario SR1820NX (ER919AA) PC Desktop
Compaq presario desktop is beeping
My 1yr old desktop is beeping and the keyboard and monitor will not come on. I get a signal error and it just goes black. I was downloading music to my ipod and it just quit. Any suggestions?
  • 1 more comment
  • sp103t Dec 26, 2008
    is it worth fixing, or should i just get a new computer?
    fan works, everything works. just the keyboard and monitor don't and that annoying beeping works fine.
    2 2 1
    Novelist:
    Champion:
  • 233 Answers
The first things I would suspect would be the memory and power supply. Power supplies seem to be a constant source of trouble. You would think a computer should last more than a year before having problems. Is it still under any sort of warranty? Also research the beep codes. They may be telling you exactly what is wrong.
Posted on Jan 01, 2009
    Scholar:
  • 172 Answers
Motherboard problem , most likely the processor socket blown, sadly this is a common fault with these pc's more info on activity, hdd spinning, cpu cooling fan spinning, cd/dvd drives working, but no display ?? if yes to all of these the motherboard processor socket is u/s. i just repalce the boards in the end on these.
compdoctor2005@btinternet.com
Posted on Dec 26, 2008
  • Chris Fell
    Chris Fell Dec 26, 2008
    You should not to need to buy a new pc after just one year. If you had to do this the pc shops wold be quids in all the time.
    Does the cooling fan to the cpu work? hdd running ? cd/dvd drives running ?
    beep codes please to determine problem.
Replaced power supply and viedo card stil no signal on monitor
Disable on-board video or check to see if you power supply has the wattage to run the video card..
Hope this helps
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
Apr 14, 2014 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
Monitor and keyboard not working
Maybe overheating ? Needs cleaning !
Or maybe it is graphic card... you must see with your servicer.
I can give you this :
turn off laptop, unplug adapter , remove battery, then hold the start key for about 20 sec. and release, turn back computer ion and see if this is the case...
If not :
take it to computer servicer
Mar 06, 2014 | HP Compaq Presario SR1115CL PC Desktop
When I attempt to boot the unit, no signal is sent to the monitor or keyboard, nor does the green light next to the power button turn on. The amber light does not, either. The fan will run at high power...
I had the same problem with my computer and the Compaq-HP techs told me to pull the ram out and then put it back in. They called it reseating the ram.
This fixed the problem i had. Try this and good luck.
Feb 14, 2011 | Compaq Presario S4020WM PC Desktop
My monitor has kicked into sleep mode and won't "wake up".
Unplug all the Cables from Compaq Presario 5103 CL and leave the Keyboard, mouse and monitor cable pluged in.
Now make sure the power cable of the monitor should be pluged in and the power cable of the tower should be pluged in.
Now to check if the montor is fine just unplug the video cable only which will show no input signal on the screen. If it shows this signal the monitor is fine. Plug back in the video cable.
If the monitor is going to sleep mode it might be possible that the old computer ( Compaq Presario 5103 CL ) is in stand by mode. hit any key on the keyboard and it should come back .
If it is not in the stand by mode then do one thing. Check the same monitor with the new computer. If it is working. Perfect ..!
Do one thing now ..!
Unplug all the cables from your old system and then press the power button for 30 sec and let it go. Now plug the keyboard, mouse and the monitor try again.
If it works Perfect. If not ..!
Then you need to open the tower and check on the processor FAN is it running..? If its not running you will not get the display as the fan is responsible for the display on the screen. Otherwise...!
Check the Tower possibly the Tower is not getting the power.
Try these steps and let me know If it works
May 04, 2010 | Compaq Presario 5000 PC Desktop
My compaq desktop has two long beeps a pause and two long beeps without a signal to the monitor. If I put a recovery disk in it beeps normally but still no screen.
Sounds like a video adapter problem. Try taking your video card out and then reseating it into the PCI slot. Make sure your monitor is connected correctly. Also, it might not hurt to make sure the all other periphs are seated correctly. (RAM,Network card, etc) hope this helps
Feb 03, 2010 | Compaq Presario 5000 PC Desktop
Blank screen
When you say "When I turn on the computer the monitor acts like it is getting no power", do you mean the light on monitor doesn't come on or it does and it states it has "No Signal"? If it says no signal then it is receiving power just no signal from computer. What kind of connection is it? Digital(white) or analog(blue)? Is the keyboard wireless or is it PS/2?
If the keyboard isn't wireless and you're plugging the monitor in correctly I would say it's a power supply issue. Try changing the outlet you're using and/or bypass the surge protector to plug directly into wall.
Jun 24, 2008 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
HP Compaq Presario SR1820NX (ER919AA) PC Desktop Logo
101 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
