Question about KitchenAid Cooktops
Very Old Kitchenaid Cooktop
KECS 1340 cooktop with power burner, Cannot buy new power burner element. Can I replace controller/rheostat and install as regular burner?
  • 619 Answers
SOURCE: JennAir Elec Cooktop Problem
The selector knob having lose contact the elements are for full adjument , the wire connection are rust and corroded need to clean terminal of elements.
Posted on Jan 05, 2008
  • 619 Answers
SOURCE: Frigidaire Ceramic Cooktop PLEC36S9eca - Turns on but burners won't heat up
Check the power plug is their any separate plug on it / if none check the control panel some switch to power on .
  • 135 Answers
SOURCE: electric cooktop burner malfunction
The outer ring of the element is most likely broken. You'll need to replace the element.
Posted on Apr 07, 2008
  • 150 Answers
SOURCE: KitchenAid 5 burner Cooktop conversion to LP gas
you need orifices for lp and the regulator should be convertable there is a "plug" thing in the middle of it that you remove and turn over and install
Posted on Apr 23, 2008
SOURCE: dacor 46 inch 6 burner cooktop
The cost of the parts you want t o replace will usually exceed the price of a new cooktop.
Posted on Jul 07, 2008
Frigidaire ceramic stovetop burner not working
The switch controlling the burner is just a voltage controlling unit (rheostat). It needs to be replaced
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Aug 30, 2014 | Cooktops
How to dismount KitchenAid cooktop model KECT 365
Why not refer this issue directly to KitchenAid. Maybe they can explain the disparity between what the installation sheet shows and what you actually don't see.
Dec 30, 2013 | KitchenAid Cooktops
I have a Jenn Air JED 8230 cooktop with a bad heating element
They are not that hard to replace and you can easily buy the part online...
Here is a tip about how to buy appliance parts online.
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
Jun 28, 2010 | Jenn-Air JED8230 Electric Cooktop
My whirlpool gas cooktop on sparks on left front burner. Model scs3014gq1
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Apr 01, 2010 | Whirlpool SCS3014 Gas Cooktop
One of the burners on my kitchenaid cooktop will not heat up. What do you think the problem is? Is this something that can be easily repaired?
If it is not a glass top stove, with the power OFF, and cold, pull out a working element of the same diameter and install it where the non-working element was. Try it now. If it works, replace the heating element. If it does not, check for voltage at the element connector. CAREFULLY. Worst case is that the switch requires replacing.
Dec 17, 2009 | KitchenAid 32 in. KECD805 Electric Cooktop
Replace burner seals of gas cooktop
good day,
hope this link below will solve your problem.
kitchen
Sep 03, 2008 | KitchenAid 31 in. KGCS105 Gas Cooktop
GE Cooktop JP930 surface element not working
It sounds like the burner needs to be replaced. When they burn out sometimes they short out to ground. The cooktop will have to be removed from the counter and the glass top opened. You will probably be able to see where the element is burned out. Replace it and you should be fine. If it is too expensive to fix just disconnect the wires to the burner where they attach to the control . Then you can use the remaining burners. I really don't know what a replacement burner costs. An open coil is around $30.
Jul 13, 2008 | GE Profile JP930 Electric Cooktop
Jan 04, 2008 | Jenn-Air 35 in. JEC9536ADS Electric...
Cooktops Logo
Top KitchenAid Cooktops Experts
vince
freddyfox
Marvin
Marvin
Are you a KitchenAid Cooktop Expert? Answer questions, earn points and help others
