Question about Sony Playstation 3 (PS3) Console
Playstation 3 Does not display on TV using HDMI or regular video
.senerio: My son hook it up using HDMI Cable to my bedroom sony flat screen tv to watch a blue ray movie and play some games. which worked fine. We then move the consol back to the living room TV using the regular cable so that everyone could watch the Movie. playstation did not display. We tried to to perform the video by holding down for 5 sec. to no avail. We did however get display to respond a couple of times. " with plug in you controler using the USB cable. We did that and it gave us a list of choices we selected option one and nothing happened. same situtation no display again. tried to reset the consol several times and then after playing with the on/off it the message apeared again. we then selected from the list "reset to factory settings"Nothing again and will not work on either HDMI or standard video cables.Please help.Thanks
  • 3 Answers
This happened to me a few years back so I apologize if it's not 100% accurate. If you can get it to work on another TV, go ahead and connect it to that, and go in to the settings to select the video input. If it's connected through an HDMI cable, then it will probably be set to HDMI. Change the input here to whatever cable you used in the living room. You will have to power it off at this stage, but when you connect to the other TV it should work.
Posted on May 01, 2017
2 Suggested Answers
SOURCE: Playstation 3 Does not display on TV using HDMI or regular video
I posted to your problem with a similar one. I was able to get my PS3 to work by:
1.) Powering down both the PS3 and ViewSonic LCD
2.) Unplugging the power cables to both PS3 and LCD
3.) Waiting at least 10 or more seconds
4.) Plugging in the power cables to both PS3 and LCD
5.) Turning on the ViewSonic LCD
6.) Turning on the PS3 and holding down the power button until the beep
After this sequence I heard the bootup audio and the menu appeared on the screen- which detected the HDMI connection to my LCD.
Very odd.. I've had my PS3 in the same place for months and just today this happened.
I wanted to post my success. Best of luck!
Seth
Posted on Jan 12, 2009
I have the system hooked up and it comes on but not o the tv screen do i need the hd cable to make it work it is a flat screen tv please let me know what to do i have playstation 2 already hooked up and...
Are you using the AV connector cable? If so look on your tv for an av channel. Best thing to do though is Try using a HDMI cable. Most tv's recognise when a HDMI cable is plugged in and the tv switches automatically to the HD channel.
Hope this helps.
LJ.
Apr 17, 2011 | Sony Playstation 3 (PS3) Console
PS3 used to work on TV in bedroom and on TV in lounge, now it won't work on TV in bedroom
I believe your Lounge TV is an HDTV and your Bedroom TV isn't, This is what you have to do:
1. Connect it to
your Lounge TV with an HDMI cable and a red/white/yellow cable.
2. Turn it on and go to the display settings and switch it to the composite cable setting.
3. Change your TV channel where you would see the red/white/yellow cable and accept it that way.
4. You should be all set. Take it to the regular TV and connect it with the red/white/yellow cable.
cheers :)
Jan 14, 2011 | Sony Playstation 3 (PS3) Console
I cant find any place to hook up a dvd player to it, Is it possible? Also What is the jack used for that is hanging above screen on left hand side. I have no manual as my son gave me tv for my bedroom when...
Look for a jack labeled HDMI, Component Video, or S-video on both the TV and the DVD player. You will need a cable that matches the jacks that you have available. HDMI is the easiest. Buy your HDMI cable on line - the retail stores mark them up drastically. Try firefold . com
Jan 13, 2011 | Televison & Video
How do you switch from hdmi ,to the regular non hd...
you need to hold your finger on power button til it makes beep sound twice , Thanks
May 19, 2010 | Sony Playstation 3 (PS3) Console
Ps3 not wworking on regular TV after hdmi cable was used.
sounds like you have the ps3 set up in HD video display settings?
If this is the case hook it up to the regular tv and when you turn the power on continue to hold down the power button til it beeps this restores the video to default settings sometimes it takes a 2nd power down and power up holding it down to work.
If this doesnt solve please give more details
May 02, 2010 | Sony Playstation 3 (PS3) Console
Origiannly had my son's PS# hooked up to our HD TV
You must reset your PS3 in order to accept the new TV configuration.
  • If the video output settings on the PLAYSTATION®3 do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system.
  • Then, with only the PLAYSTATION®3 and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution.
  • From: http://playstation.custhelp.com/cgi-bin/playstation.cfg/php/enduser/std_adp.php?p_faqid=967&p_sid=1frk_Cuj
    Hope this helps please remember to rate my response, thanks!
    OpenSource13
    Apr 06, 2009 | Sony Playstation 3 (PS3) Console
    Cannot get my HDMI cable linked from my ps3 2 my hd tv
    Try video settings on the playstation 3. Adjust it to reflect hdmi.
    Feb 22, 2009 | Sony Playstation 3 (PS3) Console
    Playstation 3 Does not display on TV using HDMI or regular video cable. senerio: My son hook it up using HDMI Cable to my bedroom sony flat screen tv to watch a blue ray movie and play some games. which...
    Seth
    Dec 26, 2008 | Sony Playstation 3 (PS3) Console
    Sony Playstation 3 (PS3) Console Logo
    148 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
