Question about Microwave Ovens
ALL POWER LOST
CIRCUIT BREAKERS TESTED - OK
PLUGGED IN
BUILT IN 1999
Worked fine in oven mode and then lost all power. circuit breakers were reset and the plug is ok. please help!
  • adsmoore Dec 29, 2008
    Mine is a:
    GE Advantium 120 SCA1001KSS
  • William Miller
    William Miller May 11, 2010
    Please reply back with your brand and model number so we can help you.
  • Microwave Ovens Master
  • 9,098 Answers
We have the full service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
The parts I would suspect most are the internal fuse, the magnetron TCO (thermal cutout) or the oven cavity TCO.
To check or replace the latter, you'll need to remove the oven from the wall and remove the cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Jan 03, 2009
My Kenmore elite microwave model 401.88523011 has lost power. The electrical outlet still has power to it. Is there an internal fuse or circuit breaker that may be causing the power outage?
Your microwave has an internal fuse. Usually 10 to 20 amp. You can pick some up at home depot or radio shack. Make sure you get the same amps and volts as the original fuse. Will be printed on your microwave some where usually. And if its one that is part of a double oven deal make sure that you check you're circuit breakers for the kitchen. Good luck.
Dec 16, 2014 | Kenmore Microwave Ovens
Used the microwave last night. Later I noticed no light display for the clock. Come to find out microwave lost all power. Model number smh9207st
If there are no fuses or circuit breakers, the unit could be down and out. Check you power box for any tripped breakers.
Dec 09, 2014 | In Microwave Ovens
Built-in Sharp Carousel II Microwave Convection Oven died.
There are a couple of safety thermostats in the oven to shut down power if something overheats. One is on the magnetron tube (the microwave source), the other is on the cooking cavity. These sometimes go bad. There's also a power line fuse that may have failed, or become loose in its mounting clips. These can be tested with an ohmmeter; they should all measure very close to zero ohms if they're good.
Another possibility is that the control circuit board in the oven may have failed. I have worked on several Sharp ovens where the power transformer for the board has gone bad for no good reason. If the board goes bad the oven may appear to be dead as well.
Microwave servicing is best left to professionals. If you're thinking of keeping this one, take it to a service shop (or call for home service) and get an estimate. Then decide whether to repair or replace.
Hope this has helped a little. Thanks for using Fixya!
Feb 02, 2010 | Sharp R-1874 Convection/Microwave Oven
MY KENMORE 1000 WATT LITERALLY WORKED FINE ONE MINUTE THEN NOTHING THE NEXT. I HAVE NO IDEA WHAT HAPPENED.
Most likely the circuit breaker tripped or the fuse blew. A 1000 watt microwave is using 2/3 of the power available on a typical household circuit of 1500 watts. If anything else is plugged into that circuit u can have a problem. Just reset the breaker or replace the fuse and u will be up and running. if it happens alot you should consider a dedicated circuit for your microwave only.
Apr 21, 2009 | Kenmore 62622 Microwave Oven
We have a JVM1870SF02 Microwave Oven. Everything
Is it on a gfci plug? If it is reset that. If not I would recheck the circuit breaker again
Sep 23, 2017 | GE Microwave Ovens
How can I get the power to come on my Sharp microwave?
The problem may be an electrical one. Microwave ovens require a lot of power. Often, they use most of the power available to the circuit they are plugged in to. If there is not enough power in the circuit to feed the microwave and whatever else is plugged into that same circuit the fuse will blow or the circuit breaker will kick off.
Go to your electcical box, and check the breakers or the fuses. If one of the breakers has kicked, reset it by pushing it all the way off and then back on. If the fuse is blown, unscrew it and screw in a new one of the same amperage.
good luck. please rate my answer. thanks
Feb 12, 2009 | Sharp KB-6015K 1000 Watts Convection /...
ALL POWER LOST
I am not sure I can solve your problem or perhaps you have already solved your problem. My thought is "are you sure your circuit Breakers are OK"??? In order to re-set a tripped circuit breaker you have to first turn them all the way off, then re-set them to 'on'. If you did not do that they probably did not re-set.
Assuming you did that correctly then I would have to suggest you contact prototech@usa.net. He/they might know of a internal fuse or other problem the may help you. Good luck.
****.sue@hotmail.com
Dec 22, 2008 | GE Advantium 120 Convection/Microwave Oven
No power to Panasonic NN-S252 microwave oven
follow the incoming mains lead into the microwave their is a small pcb with a fuse their check this first
Nov 14, 2008 | Panasonic NN-S254BF Microwave Oven
No power from Whirlpool.
IF YOU HAVE THE MICRWAVE PLUGGED IN AND THE CIRCUIT BREAKER TRIPS IMMEDIATELY WHEN SET,
CHECK THE DOOR HOOKS THAT TRIP THE DOOR SWITCHES. BOTH SHOULD BE SPRING LOADED. THERE SHOULD BE TWO HOOKS ON THE DOOR. IF O.K., CHECK THE DOOR SWITCHES. THERE ARE AT LEAST THREE. IF ONE OF THEM IS SHORTED CLOSED,
THE MONITOR SWITCH WILL CAUSE A DEAD SHORT ACROSS THE FUSE. THE FUSE MAY BE HOLDING BETTER THAN YOUR CIRCUIT BREAKER.
Mar 21, 2008 | Whirlpool MH1150XMQ Microwave Oven
Microwave Ovens Logo
129 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
