Question about Sony Ericsson Z500a
Message on screen
When I get a message waiting notification, I get the message, too many messages, erase from any folder. When I check my messages, it comes up as "corrupt". What should I do?
    President:
  • 1,017 Answers
Delete, Delete, Delete.
Posted on Jan 03, 2008
SOURCE:
Forgot unlock code voicemail kyocera jax
Go to this link...
http://www.virginmobileusa.com/resources/phones/prepaid/manual/kyocera-aw-jax.pdf
DOWNLOAD THE MANUAL FOR FUTURE REFERENCE!! LOL
Scroll down to page #39 to where it says Use Voicemail and follow the instructions!! As per the service tech I spoke to on the phone to find this link, following these instructions will automatically erase your old voicemail unlock code as well as any as yet unheard messages.
Just in case anyone still has difficulty in finding the instructions.....
Set Up your VoicemailBefore your phone can receive voicemail messages, you must set up a 4-10 digit passcode and record a personal voicemail greeting.When you have set up your voicemail, all unanswered calls to your phone are automatically transferred to voicemail, even if your phone is in use or turned off.1. Press and hold the 1 key.2. Follow the system prompts to create a password and record a greeting.
Check your Voicemail
When you receive a voicemail message, a
notification with a voicemail message icon
appears at the top of your screen.
• At the voicemail notification, select Call to call
your voicemail number and follow the system
prompts to retrieve the message.
Select Ignore to clear the notification without
checking messages. The notification icon
remains on top of the screen until you listen to
the message
• When only the voicemail message icon
appears on top of the screen, select
Voicemailand follow the system prompts
Best of luck!!
Susan
Jan 27, 2012 | Kyocera Jax Cell Phone
Hi ! Every time I try to send a text message, it appears Memory full! Close some applications and try again.I did erase my pics as well as those file saved in my memory card, but it still hopeless. It's 3...
Go your message setting. There is option where you'll save your message and choose save to memory card.
Delete all message in inbox and outbox folder, delete all cache in your browser and close all active applications. Try to send text message.
If the notification "Memory full" still appear you must uninstall a one or more application (not just close it but uninstall it) to make some space in your phone memory. Choose application that you don't use the most.
If the problem persist, format your phone back to factory setting.
Hope this help and if helpful RATE please.
Feb 09, 2011 | Nokia 3230
How do i change the text message notification sound?
1) under my files make a folder named notifications. 2) put the ringtone you want to have as the notification ringtone in the folder, 3) go to message then press the menu key 4) go to settings and select the notification ringtone
Dec 30, 2010 | Samsung Captivate Cell Phone
The recorder dosent errs why
Hello you can erase the recorded messages one by one or all massages in folder at time
Note once a recording has been erased, you cannot retrieve it.
Erasing messages one by one
1 Press ERASE while playing back the massage you want to erase or press ERASE for more than 1 second during stop mode.
A beep will sound and the message number and "ERASE" will flash while the first and last 5 seconds of message is played back 10 times
2 Press ERASE while the message is being played back.
The message is erase and the remaining messages will be renumbered. (For example, if you erase Message 3. When erasing is completed, the unit will stop at beginning of the following message.)
Erasing all messages in a folder
1 Press FOLDER to select the folder you want to erase.
2 While pressing STOP, press ERASE for more than 1 second.
"ALL ERASE" will flash for 10 seconds
While the display is flashing, press ERASE.
Nov 16, 2010 | Sony ICD-B7 Digital Voice Recorder
My phone always appearing the mail icon i the upper left corner of the screen beside the signal bar. i dont have any messages and i have enough memory. i erased all my message but it keep appearing and...
I suspect there is a message in your Messages folder, which gets system messages. You may have it hidden. This folder is a different folder than your account folder. Un-hide it, remove the message, and then hide it again.
You were saying something about removing service books. Don't do that.
Jul 11, 2010 | Sony Ericsson Satio Cell Phone
Envelope Notification showing one message
If you call your service provider, they should be able to clear it, provided all messages have been read and you don't have any voicemail waiting to be heard. They can send a "0" count through their switch (processor) to your device which will in turn clear your message waiting indicator.
Aug 21, 2009 | Cingular Wireless AT&T RIM BLACKBERRY BES...
Message(s) Received
From the Main Menu, go to:
Tools
Control Panel
Device
Sounds & alerts
Message alerts
On the display, place a check on the tick box before the "Display notification" tab.
This will enable the message notification whenever you receive messages on your phone. I hope this helps. =)
Jul 01, 2009 | Sony Ericsson W960i Cellular Phone
Nokia 6220c notification message blinking all the time
Hello Strokerpin,
Please go to "messages", select "options" then go to "sim messages" then delete all messages from the sim. There you go the envolope notification has now stopped blinking and is no longer there.
Mar 19, 2009 | Nokia 6220 classic Smartphone
Message waiting light
Go into the voicemail, press 5 for message waiting notification options, press 1 for message waiting light status.
Aug 08, 2008 | Panasonic KX-T7633 Corded Phone
Deleting the recent text message folder
go to your menu screen and go over to the mailbox. notice the bottom right corner of your screen says erase.......click the top right button and it'll take you to another screen to pick what which folder you want to erase. pick which one you want cleared out and you're done.
if there is a particular message that you don't erased, go to it and lock it. that way when you do the mass erase, the locked message will remain there.
Oct 01, 2007 | LG VX5200 Cellular Phone
Sony Ericsson Z500a Logo
48 people viewed this question
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Marvin
Marvin
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
