Question about Brother DCP 7010 Multifunction Laser Copier
FAXING SAYS CANT SCAN TROUBLESHOOT ROUTING , DONT HAVE A BOOK
SCANNED COPIES HAVE BLACK LINE DOWN MIDDLE CANT FEED PAPERS THROUGHT TO FAX MACHINE IS JUST OVER A MONTH OLD BOSS LOST BOOK
    Champion:
  • 320 Answers
Lift the cover up and clean the scanner glass with windex might have white out on glass
Posted on Jan 16, 2009
  • 4 Answers
Usually something on scan glass..ord lamp is bad..try coping blank paper..if line shows up...check glass clean and try again..
Posted on Jan 04, 2009
Black line 1 inch wide right side ,when copies are made and faxing
When the paper is fed through Automatic Document Feeder (ADF) is is scanned before copy or fax. The scanner is fixed type and is located just below the ADF.
The lines are due to dirty scanner mirror. The printer/ scanner design is based Sheet-Fed Scanner. Open/Lift the Control Panel (scanner top )(by pulling it up from front - the area from where the paper to scan comes out). Look out for the horizontal mirror and use a soft, damp, lint-free cloth to gently clean the scanner mirror, rollers etc. and enjoy clear scanning and copying!
Inspect for any tron pieces of paper dirt etc.DONT USE PAPER, CHEMICALS OR ANY ABRASIVE CLOTH as it may damage the parts.
Also note that your machine can scan an image only 8.15 inches wide, regardless of how wide the paper is.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
May 31, 2011 | Brother 5750E Fax
Black line running down the middle of the page when faxing or copying using automatic feed tray. If I lift lid and copy no line. Receiving fax not line?
Generally this problem is due to the the glass under the lid being dirty. Some combo units have 2 scanning areas, the large one you are using to copy ans a small one it runs the faxes through. I suggest you clean any and all glass you can find on the machine and give it another go.
May 04, 2011 | Brother Office Equipment & Supplies
Faxs received are blank. Copies are printing
Can't happen. Someone is faxing papers upside down to you.
Copying and receiving faxes uses the same exact printing process.
Oct 26, 2009 | Brother FAX-8360P Plain Paper Laser
Black line down middle of page
Clean off the glass place where the paper passes when you fax. You'll probably find some foreign matter on it. Wipe it off and you should be good to go.
May 01, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Will not feed original for faxing, goes immediately into scan mode
i dont think your machine is capable of fax operation .check your manual if the fax board is standard or optional
Mar 25, 2009 | Kyocera Copystar CS-1820 Black and White...
Black line down the middle of scanned documents.
Try leaving the cover open and run a test scan, once with a fresh sheet as the item to be scanned and then a second time without anything on the table.  You may see what is blocking the light source or possibly a defect in it.
Scanning is done left-right, left-right across the width of the page and the vertical stripe indicates that the blockage is present during each scanned line.
In servicing copiers and multifunction machines, I have found a number of curious contaminents, one of the most annoying was a moth, still alive, that would randomly sit on the lamp, causing some pages to come out OK, others not.
If your copies and printouts are coming out fine, then only the scanner can be at fault.
Jan 13, 2009 | HP Photosmart 2575 All-In-One InkJet...
Need to know abt fax
HP.com has a web page that talks about the different ways you can send a fax from this product:
Faxing Overview
In general, the fax machine in the all-in-one product doesn't need a computer to work. It works just like a stand alone fax machine. You shouldn't have to scan anything in from the scanner in order to fax. Just put the sheet of paper you want to fax into the product's feeder and follow the fax instructions (see the link I posted above).
As long as the product has electric power and is connected to a phone jack, it should work out OK.
As far as legal papers, if you mean legal sized papers, it should work as long as the product supports the paper size you want to use. You can get that on the product specifications web page at HP.
Product Specifications
Once that page opens, go to the Faxing specifications and Paper specifications sections for the relevant details. Good luck.
Oct 09, 2008 | HP Officejet 5610 All-In-One InkJet...
Nox faxing and black copies
make sure there is nothing stuck in paper path or the scanner lens is not dirty.
take out toner/drum tray and reinsert it to make sure nothing is preventing drum from turning or stuck.
then try to use
Jan 13, 2008 | Brother IntelliFax-2820 Laser Fax
Brother DCP 7010 Multifunction Laser Copier Logo
124 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
