Question about Acer TravelMate 2423WXCi Laptop
Connect to tv
Did you ever get a good answer about connecting youe laptop to tv. I have the same model with just vga out. Your help is greatly appreciated
Connect laptop to tv
To connect a laptop with a Sanyo TV, the TV must have VGA cable connection. VGA cable picture
If the TV is not equipped with a VGA cable, it can not be be a laptop and a TV connection.
Jan 07, 2012 | Toshiba Satellite A665-S6086 16-Inch...
I have a inspiron1300,and i wondered if it is possibe to connect it to my philips hdready tv.am sure which cable to use
You never mentioned what model Philips TV you have, however I've researched several and most seem to have a VGA video port in the back of them. If you have one of these (15 pin D connector) on the back of your TV you should be able to purchase a corresponding VGA cable (you'll want female pins on one side of the cable and male pins on the other side) and plug one side into the VGA port on your laptop and the other cable into the TV. Then use your TV remote to select that input. Should work fine!
See item 8 in the attached user guide link to see what I'm talking about. http://download.p4c.philips.com/files/4/42pfl3403_98/42pfl3403_98_qsg_eng.pdf
I hope this response helps you out.
I wish you the very best of luck! If I can help you further, please let me know.
I strive for '4 Thumbs Up'! If I've assisted you, I'd greatly appreciate you taking the time to provide me with a favorable rating. Thanks so much!
Jun 23, 2011 | Computers & Internet
What do I need and how do I connect my Toshiba L305 model PSLB8 050302f to my hdtv to view online tv?
I dont believe that laptop has an HDMI port on it. If you have an LCD TV then your TV may have a VGA or DVI input on it. You can connect your laptop to the TV by using a VGA to VGA or VGA to DVI cable. If you your TV doesn't have one of these input ports, then you're not going to get your laptop connected to your TV.
Mar 03, 2011 | Toshiba Satellite Pro L300 Notebook
HeLLO i tried to conect my lap model d250 to a sony tv bravia, the lap recognize the tv but tv didnt get any signal, what kan i do? best regards from norway
Hello! Well, there are a few questions I need to ask so I can help answer your question correctly-
how are you connecting your computer to your TV? Is it a VGA, DVI, or a HDMI cable? How many "input" channels can your TV support? Have you updated the video drivers on your laptop? Answering these questions will greatly increase the ability of a technician to help solve your problem, and I hope to hear back from you soon!
Feb 05, 2011 | Acer Aspire One Netbook
I have just bought an acer aspire 7720g laptop and i want to connect it to my 50" lg plasma tv, can you help
If your TV has a VGA input, you can use a regular VGA cable from the computer's external VGA connector.
If the set doesn't have a VGA input, you can get an adapter cable (here's one) to go from the computer to the TV's component video input.
You might have to enable the computer's external monitor from the keyboard. One of the function keys usually does this, see your computer manual.
Feb 19, 2010 | Acer Aspire 4720 Notebook
How can I connect the Asus K50IN laptop to a TV?
if your tv is a newer hdtv it might have a 15 pin female vga connector in the back. I just use a vga cable from my notebook to my tv. make sure the vga cable is female on both ends. works great!
Oct 10, 2009 | ASUS Computers & Internet
Connecting latop to tv?
use s-video cable  a little round plug most newer tvs have s-video imput that is standard resulution
May 22, 2009 | Dell Inspiron 2200 Notebook
How do i hook up a tv monitor to my campaq computer
usually laptops have vga conector for external display, you may need a cable, vga cable.
vga cable varies depends on the connection that you have on the tv, if your tv supports vga connectors thats great, some tv doesnt have that option, thats where adapters go in to adapt what ever ports or connections you have on your tv.
some of the cable adapters that you might need.
vga to hdmi.
vga to rca.
vga to dvi.
hope that helps.
Oct 17, 2008 | HP Compaq Presario V2000 Notebook
CONNECTING ACER TO THE TV
Please tell me what operating system you have installed and what the specs your machine are,
Can you also discribe to me how you have the computer connected to the tv thanks
This will help me understand your problem better thanks
Sep 06, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
50 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
