Question about X2Gen MV20T TV
Goodmans LD1575D not finding any digital channels
Hay everyone my friend has a goodmans 15 inch tv with built in free view, during install the free view will not find any channels, the ariel is new. I have attached another freeview box between the aerial and tv which works fine. The internal digital channel unit doesn't seem to be Normal tv channels are working but we'll lose them soon and was wondering if anyone else has had the same fault?
I have an indoor digital aerial connected to a free view box but when I automatically tune the TV it comes up with no channels found check aerial connection
Possibly. Try rotating the antenna a little bit and retry tuning. Keep on doing this until you get your channels. If this doesn't work, raise the antenna as high as possible and try again.
Dec 20, 2014 | Goodmans GTVL19W17HDF 19 in. LCD TV
Freeview in Goodmans LD3266D
you must adjust from the Moden with r.control from your supplier cables company, Not from the TV. The tv had capacity for to see any channel.
God bless you
Jul 19, 2013 | Televison & Video
I have a goodmans anologue tv in my bedroom I've
Refer its service manual and make a factory reset to it. To downlaod the service manual, google it with its brand name. I don't think there will ba a free download site for this brand TV. All download sites will be paid.
Apr 27, 2012 | Televison & Video
Need user manual Goodmans LD1575D
You could try
if you need a user manual
if you want the schematics etc
We've used them in the past and found them very good.
Also if it is not listed then ask via the link and they
will probably be able to get it for you.
Jul 06, 2011 | Goodmans Televison & Video
Problem with digital tv
The Antenna may be in a weak signal area heres a quick cheap fix
Get a Freeview Box and connect it via SCART LEAD to your tv, if the Box picks up a good signal then your tuner may be very weak..
You may want to try a BOOSTER to the TV first, and if that fails go with an external freeview. My neighbor has a 42 and the freeview box WITHOUT an antenna attached resolves all the give that a try. I have a goodmans too with a slow tuner and I have to retune it sometimes even though it gets a good signal from the antenna. I will be getting an external tuner freeveiw box.
Apr 15, 2010 | Goodmans GTVL32W27HDF 32 in. LCD TV
Goodmans TV needs re tuning
Very likely that where you are the over the air signals are now broadcast in digital format and you need to by a converter box to use an older television. Check places like Walmart or Best Buy or Radio Shack
Apr 13, 2010 | Goodmans 15.4 in. LCD TV/DVD Combo
I have had a 32" sony LCD Digital TV with built in free view tuner. I am experiencing a problem where on certain channels the TV keeps switching itself off to standby. Is this a TV fault or a signal one,...
if it says no signal or video not available then signal if its just turning itself off then tv i would go to the shop and get it checked out or replaced.
Dec 04, 2009 | Goodmans GTVL32W27HDF 32 in. LCD TV
How do I retune my goodmans television for
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit
For specific model information visit
Oct 01, 2009 | Goodmans W280NS Television
Cannot get my goodmans 289ns to accept the virgin digital signal
Will the TV go to channel 3? if not you need to reporogram the TV to sence channel 3 or go into the setup and undelete channel 3. Channel 3 is the channel your digital box is set to boradcast to the tv itself.
Apr 22, 2009 | Goodmans 289NS 14" TV
No sound
goodmans GTV51NZ2DVD i am trying to connect a play station 2 put have no remote control so how can i find the av channel can any one help please
Jan 22, 2009 | Goodmans 289NS 14" TV
X2Gen MV20T TV Logo
182 people viewed this question
Top X2Gen Televison & Video Experts
Computer Repairing
Computer Repairing
ray gallant
Are you a X2Gen Televison and Video Expert? Answer questions, earn points and help others
