Question about Sharp 13VT-R100 13 in. TV/VCR Combo
V-Chip the v-chip is activated and I don't have a remote control or manuel. Is there a way of turning it off?
    Genius:
  • 1,074 Answers
Some one have entered some code numbers into your tv you will have to take the tv to a tech to have them lift up the eeprom from out of the set to reset itself there after solder it in back.that will get rid of the vchip.good luck.
Posted on Apr 19, 2007
Harmony 550 question. I set up my devices (tv, cable box, sound bar and blue ray player), and set up the watch tv activity. When I try to do the activity, the tv turns on, the sound bar does not, and the...
I know it may not be this simple, but I have set up like 5 of those remotes for clients, I always have to remind them to make sure everything is off before starting from scratch trying a function.
That way they are not doing the opposite (On/Off) of what they are supposed to do.
Don
Dec 28, 2014 | Logitech Harmony 550 Remote Control
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
I accidentally turned on the fpa lock and don't have a remote. What now?? Any hope? I also could not get the CC up before I got locked out.
Hello
To turn out FPA lock with RCA TV, you must have its original remote control handset. If you haven't one, just buy a new one of borrow it from your friends or relatives, who own the same model of RCA TV. After unlock, you can use any other remote control. If you are using the original remote control, do the following to unlock it.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
Sep 01, 2011 | RCA TruFlat 27F520T 27" TV
How do I set the sleep timer? We got the tv from a friend and it had no manuel.
Programming the Sleep Timer:
  1. Press and release the TV key.
  2. Press and hold the SLEEP key for three seconds. The illuminated component name turns on.
  3. Release the SLEEP key.
  4. Using the number keys, enter the desired time in minutes (from 1-99 minutes). To set the timer to an umber under 10 minutes, first press 0 and then the desired number (e.g.,05 for five minutes). The illuminated component name blinks with each key press.
  5. Once the second number is entered,the illuminated component name turns off.
    Tip Any key press other than the number keys is ignored. If you don't enter the sleep time within 10 seconds after pressing the SLEEP key, you must start over at step 1. The illuminated component name blinks four times and then turns off, indicating your attempt to program the Sleep Timer has been unsuccessful.
  6. The Sleep Timer is now set.
  7. Leave remote aimed at the TV. Once the Sleep Timer is set, you can continue to use the remote without affecting the Sleep Timer. However, because the timing mechanism for the Sleep Timer is built into the remote itself, the remote must be in TV Mode and pointed at the TV to activate the Sleep Timer.
    Note: If the ON·OFF key is pressed, the Sleep Timer is canceled.
Aug 19, 2011 | RCA Rcr461 Remote Control
My rca is locked don't have my owners manual how
Hello
If you have its original remote control, you can unlock it by one amoung the following methods. If you don't have its original remote control, try to gather it from any of your friends or relatives to get the lock out. Then you can use any other remote controls.
4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
Jul 05, 2011 | RCA Televison & Video
There is a lock in the corner off the screen., how can i get it away. I dont have a manuel.
Hello
I think your TV has been locked, and you have forgotten the four digit V_Chip code you have entered earlier. If so there is a method to refresh the V-Chip code. The orginal code for the V-Chip, when the TV exits the factroy is set "0000".
You can set to this code by the following method.
Press the remote control keys in the following sequence, which reset the pin to "0000".
POWER OFF==> MUTE==> 8==> 2==> 4==> POWER ON.
TV will come with a fresh V-Chip code "0000", which you have to readjust to block any channels if you wants. Ok.
Nov 06, 2010 | Samsung TXM3296HF 32" TV
Directv tech support told me to turn off the V-chip on my Sony Bravia TV to program the tv to my Directv remote. How?
SETTING V-CHIP
This TV is fitted with a V-CHIP controller which provides you with channel viewing access controls
and restrictions. This function is to prevent your children from watching violence or sexual scenes
that you may choose to exclude.
Press the MENU button and press the SET + or – button to select the V-CHIP SET option,
then press the ENTER button.
Enter your password (4 digits) using the Direct channel selection buttons (0-9).
In the event of entering incorrect password press the RESET button. Then press the
ENTER button.
Enter the same password for confirmation, then press the ENTER button.
Press the SET + or – button to select the V-CHIP option.
Press the ENTER button to select the ON.
Press the SET + or – button to select the TV RATING or MOVIE RATING option. Press
the ENTER button.
Press the SET + or – button to select the desired rating for the applicable video or TV
channel. Press the ENTER button.
And to change or put in a new password:
NOTES:
• If you want to change password, follow steps 1 and 2 and select "CHANGE PASSWORD"
option then enter your new password.
• The V-Chip function is activated only on programs and tapes that have the rating signal.
• Once you block a program using the V-Chip function, the blocked program cannot be watched
based on the content of the show. When the program starts, the "INPUT PASSWORD" will
appear on the screen. When you want to release the V-Chip temporarily, enter the password.
If you change the channel or turn off the TV while the V-Chip function was temporarily released,
the original setting will be resumed. If you return to the channel you were watching you must
re-enter your password to temporarily release your V-Chip function again.
• When you watch the TV from the cable box or the VCR with the RF Modulator, then you release
the V-Chip temporarily, the V-Chip setting will not be resumed until you turn off the TV. The
TV channel is not used in this case.
• When changing the channel with the cable box or the VCR, approximately 10 seconds will
pass until the program appears.
Jan 21, 2010 | Durabrand DU1301 TV
Need manual for invoca 3.0 remote can anyone help
just google invoca and go to the manuel
then just print it thats what I did for the one I bought for $0.85
Dec 28, 2008 | Invoca 326348 Remote Control
New settings on tv remotes
Hello Slffvo:
Here are a few web sites that may help you out.
http://www.hifi-remote.com/ofa/devices-tv.shtml
http://www.universal-remote.net/philipsmagnavox.html
Aug 14, 2008 | Philips Magnavox Learning Universal Remote
Sharp 13VT-R100 13 in. TV/VCR Combo Logo
88 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
