Toshiba top load washers have standard error codes. Depending on the display (2 or 3 digits depending on the model) it will either show E21 (or E23) or alternate E2 and -1 (or E2 and -3). Here's a list of most Toshiba washers error codes;
E1: Water doesn't drain in time or not at all
E21: Lid open
E23: Lid not locking
E31: Load imbalance
E32: Check E1 and/or E31
E5: No water coming in
You can try resetting to factory default by following the procedure: Power OFF, then pressing and holding the Super Spin Dry button, press power ON and it should beep 3 times. E2 error code aw 8990st toshiba wash Washing Machines
This is an error code that something is wrong with the water pressure. Possibly a water filter is plugged up, water pressure coming into the machine may be too low. Or maybe, if you have moved the machine you may have kinked the inlet hose to the machine.
E1 is the drainage hose error, check the drainage pipe hose is not blocked damaged or filled with water or frozen, or maybe the return sensor for the hose is switched sensing something is wrong with the pipe but isnt. check the drainage hose ensure all water is out of the hose. open and close the lid one, then press the start/hold button this should reset the error alarm.
Means you are not getting cold water into unit..Either cold water hose is connected to the wrong hose or cold water faucet is not turned on..You can solve this by connecting hose to cold water faucet and cold water inlet on washer..
