Question about Casio 76 Key Smartmedia Keyboard
Does not fully poweer up
Casio WK-3000 Keyboard. When I turn it on, the screen lights up and barely says Please Wait and never fully powers up. Difficult to turn off. Can it be fixed and is it worth it?
    Problem Solver:
  • 8 Answers
I had the same problem. You might try the keyboard on good fresh high quality batteries. If this solves the problem, buy another ac power adapter. Good luck!!
Posted on Jan 08, 2010
It wont power up
Do You use original CASIO power adapter for this keyboard?
Some CASIO (CTK-5000) models require inverse voltage polarity than most of others adapters have!!! RISC OF BURNING OUT ELECTRONICS!!!
Dec 09, 2012 | Casio Wk500 Wk-500 Keyboard Workstation...
I have a casio keyboard WK 3000 and when it is powered up, the screen is frozen. When the keys are pressed, no sound comes after. Also when i try to shut the power off, it doesn't turn off. The only...
Make sure you use ONLY the correct adapter for power. Too small an adapter might cause it to light up but will not operate the unit. The correct adapter should say AD12 on it. It is a 2 volt, center pin minus, and probably 1 or 2 amps capability. Nine volt adapters used with pedals or universal adapters will NOT work with the WK3000.
Jun 26, 2011 | Music
Hi, i have a problem with my casio wk 210 keyboard. when i push a key then the note keeps playing and doesn't stop. i have tried turning off the power and turning off reverb and none of them fix the...
It sounds like the sustain is stuck on as if a sustain pedal is active. You don't mention if you have one, however if you MIGHT have one and you have used a Roland pedal, that brand is reverse sensed and would cause note to remain on.
Jun 14, 2011 | Casio WK-210 PACKAGE 76 Keys Electronic...
I have a Casio CTK 551 Keyboard, when the AC adaptor is connected and power is turned on, the Keyboard lights up for a few seconds then turns off. I noticed no red light lights up when the AC adaptor is...
The adapter has a problem... likely a poor connection of input power that briefly contacts building up some voltage that is then stored in the capacitors in the adapter which then discharge quicklly when you turn on the Casio. The adapters with FIXED blades OFTEN have problems contacting the connections in wall receptacles and extension cords. You may need to bend the blades slightly or use a better receptacle like connector. IF your adapter has a three wire cord from it to the wall receptacle, those SOMETIMES don't seat well...
Apr 10, 2011 | Casio Ad5mr Power Adapter Lk Ctk Wk New...
When you turn on the wk 3000 the lcd reads pls wait after a few minutes it goes blank no sound no responce
This ONLY applies if you have a floppy or hard drive in your unit...
SOME of these synths hang up during boot if the floppy or hard disk isn't recognized as working...
Also verify your power adapter is producing the right voltage and is the original.
Jul 19, 2010 | Casio Music
I have a casio wk-200 piano. I bought headphones
The keyboard has a mic jack that is the same size as the headphones. You probably put the headphone plug into the wrong jack is all.
Jan 10, 2010 | Casio Music
How to save setting changes on Casio WK-500 keyboard?
This is a link to WK-500 owners manual.....SD Card information is on pages E-59 thru E-64...
Oct 22, 2009 | Music
SMF converter for wk-500, Does it exist?
I have a Wk-8000 & a CDP-200R, the later is the same as wk-500 but with 88 weighted hammer keys.
Since wk-500 can play SMF (Midi 0 & 1) format directly from a SD card and there is enough polyphony to play anything, I don't find any real reason to convert SMF to any "Casio Format". Just get a 2GB SD card and put your SMF files in the MUSDAT folder for the SD CARD using your PC/MAC.
Dec 31, 2008 | Casio Lighted Keyboard LK90STADMC
Casio 76 Key Smartmedia Keyboard Logo
492 people viewed this question
Top Casio Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Casio Music Expert? Answer questions, earn points and help others
