Question about Pelonis HF-0019 OSCILLATING HEATER - OFF WHITE
Pelonis HF-0034 turned off 10 sec after starting; won't restart
My Pelonis HF-0034 turns off after a few seconds; won't restart. When unplugged for a period of time, it will repeat the same problem. Any idea what the problem is?
Thanks.
  • 4 Answers
I've been through 4 or 5 of these (and similar models) with the same problem after anywhere from 3 months to 1 year of use. It appears to be an overheat condition. Unplugging for about 10 minutes resets the overheat protector, but it will overheat again after running a short time.
Sometimes you can extend the life by blowing out the heater with compressed air, especially around the electronics at the very top and the contact points at the top of the circular heating element.
I'm currently trying a Lasko 755320 from amazon.com -- cheaper, more features, better user interface, more heat, and it almost has to be more reliable than the pelonis.
Posted on Nov 28, 2009
We had one of these heaters also. Used for one year for short periods of time to heat an extra room. Went to plug in and nothing. My husband took the bottom plate off to see if there was a blown fuse and instead found a burnt wire, which had melted part of the plastic disk. If I were you, I would throw it away and get something else. This model is discontinued and I am sure for many reasons. I would look for a different manufacture also. I called customer service and after being told to bad, the man hung up on me. Great customer service. :(
Posted on Feb 05, 2009
  • bradleyjacki Nov 24, 2010
    Thank you this is very helpful.:)
    Problem Solver:
  • 14 Answers
I had the same problem with this pos a few seconds ago. Try shutting off the oscillation (red/orange OSC switch) and spin the unit incrementally on its base while trying to turn it on. It seems to be some problem with the oscillation pulling wires loose or something.as once I shut of the osc and spun it a little it lit back up and started working again. If I turn the osc on again the problem recurs once it spins far enough. It's probably a defect as the model was discontinued. Unfortunately mine and likely yours are out of warranty. Hope this helps, but you and I should probably just buy a new one instead of potentially burning the house down due to arcs from loose wiring.
Posted on Feb 04, 2009
"and after being told to bad, the man hung up on me"
You were told to bad? How does one "bad", exactly? I didn't know that was a verb.
Posted on Mar 25, 2010
  • Naurion Oct 19, 2010
    Sure she meant 'too bad'
  • jplin1 Jun 14, 2011
    Michael Jackson can bad like nobody's business!
Where can I find a manual for the Pelonis HF-0034 model? It did not come with one when I bought it.
Here is the factory number. In the event of a warranty claim or if service is required for this heater, please contact us at
the following:
Tel: 866-876-4332
Aug 06, 2018 | Pelonis Heating & Cooling
I have a Pelonis oil-filled electric radiator heater that will not turn on even when plugged in to a good outlet. The switch seemed a little erratic but worked but when I bumped into it this morning i
Unplug it, then open it and inspect for a loose wiring connection. If that doesn't help, then jumper across the tip-over switch to see if the switch is bad.
Jan 25, 2014 | Pelonis Disc Furnace Heater
HF-0020T Fan Forced heater
If the symptoms are as described, the heater probably has failed completely.
Nov 01, 2012 | Pelonis Heating & Cooling
Nokia e72 auto restart problem in 10 sec
Sep 06, 2012 | Nokia E72 Smartphone
02 SILVERADO. AIR ONLY BLOWS OUT DEFROST VENTS. REPLACED CONTROL PANEL. NO LUCK
I had a similar issue on an 05 silverado. Air would only blow out of defrost vents. But this worked for me:
1) Unplug HVAC fuse for 10-30 seconds
2) Start truck
3) A/C comes out defrost - wait about 10 to 15 secs
4) A/C then starts coming out the floor vents for about 5 seconds
5) A/C then starts coming out the dash vents.
6) While the A/C is coming out the dash vents, turn A/C OFF (otherwise it cycles back to defrost for good).
7) Turn truck OFF
8) Restart truck and it should work fine
(Found solution on another forum from user "ccurran")
May 15, 2011 | 2001 Chevrolet Silverado 1500
I do not have the manual to my fan forced heater (model HF-0034) and I am not sure how to work it. It keeps shutting off after a few seconds of heat. Then it will turn on again in 10 minutes and back off...
A lot of this, may be caused by the temperature setting and where the heater is placed. If the temperature is not set high enough, as opposed the ambient room temperature, it probably only turns ON briefly. Also, if the heater is placed near a heat source or in direct sun light, it's sensing the temperature from those sources, rather than the room air.
Try moving it to a another location and setting the temperature on the unit a bit higher.
Hope this helped you to solve the problem. Please let me know.
May 06, 2011 | Pelonis Heating & Cooling
I HAVE AN hp 0034 AND I CAN NOT GET IT TO RUN OR HEAT?? I DO NOT HAVE AN INSTRUCTION BOOK SO WHAT SHOULD I DO? I THINK IT MAY HAVE SOMETHING TO DO WITH THE TEMPERATURE CONTROL IRENE
Have you checked the outlet that the heater is plugged into, to be sure it's working. Unplug the heater and plug in a lamp. If the lamp doesn't turn on, than the problem is in the wall outlet or the circuit breaker has been tripped. Unplug the lamp, reset the circuit breaker and plug the lamp back in first. If the lamp works and doesn't trip the circuit breaker, unplug it and plug in the heater. If the heater trips it when you turn it on, there's an electrical problem in the heater.
Lowe's & Home Depot stock and sell this heater. See if either has one in stock. If they do, take it to the Customer Service Desk and they'll gladly make you a copy of the Owners Manual from the one in the box,
Hope this helps. Please let me know.
Feb 07, 2011 | Pelonis Heating & Cooling
My compaq is stuck on the compaq logo screen
hi there..
turn of your computer before you do anything ....
unplug all the cables.. i mean everything..
then we are going to a proceedure called as powercycle..
after unplugging all the cables..
press and hold the power button for 5 - 10 secs..
or you could leave the computer for 30 secs.. without connecting the cable..
connect only the basic cables. .such ... keyboard. mouse. monitor.. cpu and restart your computer..
this should work
if not please do let me know ..
Aug 20, 2009 | Computers & Internet
Hf-0022
tap the heater gently. i say GENTLY, in the area of the on switch. try this several times. usually the tip over mechanism will stick. i say gently.
Nov 21, 2007 | Pelonis HB156T Ceramic Compact Heater
Pelonis HF-0019 OSCILLATING HEATER - OFF WHITE Logo
2,878 people viewed this question
Top Pelonis Heating & Cooling Experts
Paul Carew
Mack Baxter
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Pelonis Heating and Cooling Expert? Answer questions, earn points and help others
