Question about Microsoft Xbox 360 Console
Red lights on the exbox
My exbox is lighting up with the red lights but only 3 out of the 4? what does that mean?
  • 709 Answers
This is the classic 3 Red lights of Death(3RLOD), Typically meaning the processors did not pass the Power on Self test (POST). Do not do the towel trick, it will completely destroy the motherboard.
So many websites are posting procedures for X-Clamp mod and I believe most of them are not thorough enough to solve the problem. Contact Info@PlaystationClinic.com on this issue. You need a X-Clamp modification, or send it back to Microsoft.
Posted on Dec 26, 2008
The power button has a blinking red light, what does this mean?
4 flashing red light = av cable not connected. double check id av cable is connected properly. try using different av cable.
3 flashing red light = hardware problem . may require repair
2 flashing red light = overheating
1 flashing red light on bottom right LED with error code = hardware failure may require repair
Jul 04, 2011 | Buck Legendary: The Box for Xbox 360
Red rings
Depending on how many you have it means different things:
1 red light - scaler chip E74
2 red lights - overheating
3 red lights GPU and CPU have burnt out
4 red lights - the AV cable is not in correctly
You can fix all of these errors yourself or you can send it in to have it repaired
Dec 23, 2009 | Microsoft Xbox 360 Console
What do i do when one red light flashing on exbox 360
1 red light happens because the scaler chip is getting too hot and you will need to fix it you can do this yourself or you can send it in to have it fixed.
Dec 19, 2009 | Microsoft Xbox 360 Console
When charging battery green light flashes then red 3 times
KODAK Easyhare digital camera light status
1. Blinking green light(or blinking blue or white light in some models) - Means camera is performing a power up procedure. Note: Wait a few moments to see if the camera displays a solid green (or blue or white) light or a blinking red light.
2. Solid green light(or blinking blue or white light in some models) - Means Camera has sufficient power
3. Blinking red light - Means camera batteries are weak or need replacement; If battery are new and still red light camera needed to be repaired
For futher assistance contact Kodak support line 1 800 235 6325 (23KODAK)
Nov 21, 2009 | Kodak EasyShare M863 Digital Camera
3 red lights are on the front of the xbox and i cant play help
This means you left your XBOX on too long and it over heated. This is any easy fix, leave your Exbox 360 off for about Half an hour, and It should be fine. If you like playing for Long periods of time, I prefer getting a stand for it, it has a switch thats will blow a fan into the xbox.
But also, don't mess with your exbox to much when the 3 lights come on, you might make a spark and 4 lights will show. By then, you would have to take it to a shop or get a new one.
Apr 09, 2009 | Microsoft Xbox 360 Console
Exbox 360
You can check out the informative blog post at http://www.fix-xbox360.info/2008/09/11/xbox-360-disc-read-error-e74-error-no-video-problem/
This post describes the E74 error with one red light problem.
hope it helps...
Jan 05, 2009 | Microsoft Xbox 360 Console
Exbox 360 elite with 2 red lights blinking
Your xbox is overheating, and needs to be sent in to microsoft.
Dec 02, 2008 | Microsoft Xbox 360 Console
Beep 3 times turns green yellow then blinks red then turns to a solid red wont turn on wont give me game
3 Solid Red lights usually means that a cable is unplugged. Check all cables (unplug and plug back in)...you may need to replace power cable if issue is still ocurring. If it is 3 Flashing red lights, this is known as the Red Rings of Death, i.e. your XBOX is dead and needs to be completely replaced.
http://www.xbox360forum.com/forum/xbox-360-console/64180-what-do-three-solid-red-lights-mean.html
Jun 16, 2008 | Video Game Consoles & Games
Exbox 360 4 red ligths
4 red light is a problem with your AV cable.
THINGS TO TRY
  1. Make sure that the AV cable is correctly connected to the xbox 360
  2. Disconnect the AV cable from the Xbox 360 console, and then reconnect the AV cable to the Xbox 360 console.
  3. If the four flashing red lights continue to flash, try wiping the metal area of the AV pack with a dry cloth. The metal area is the end that plugs into the console. Wipe the metal area thoroughly, and then try the AV Pack again.
  4. If the AV cable is correctly connected but the four red lights are still flashing, substitute a different AV cable if you have one available.
    You can also check to see what the error code is yourself if your not sure whats wrong with it.
    To do this, you turn your x-box on, press the Connect button on the console itself and hold it in. Now press the DVD eject button to and look at the lights. it should be flashing 1 light, 2 lights, 3 lights, or 4 lights. grab a piece of paper and write down how many lights are showing. While still holding the connect button, press the eject button again. Write down how many lights are showing again. Then press eject again, and write it down. Then do it one more time and write it down. After you do this, then come back on fixya.com and let me know what error code it is.
    1 Red light = 1
    2 Red lights = 2
    3 Red lights = 3
    4 red lights = 0
    so an example of what you might write down would be:
    0
0
0
which would be 0001.
If you figure out the error, you can also visit the following website and determine what it is and if you can fix it yourself:
http://www.llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Feb 24, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
55 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
